Question about Eureka 2961AVZ Bagless Upright Vacuum
Kicking out debris
This vac kicks out the back almost as much as it sucks in. I have to vacumn where I just vacumned. HELP
  • 32 Answers
Your vacuum will kick back dirt if there is a clog of anykind, or if the filters are dirty. First check the suction lines for any clogs, if none are found, take out your dirt cup, and take off the filters. Normally there is a foam prefilter covering a paper filter - replace both filters. The reason this happens, is that the filters allow the air flow at a specific rate, creating the suction and they cyclonic action you see when you are picking up debris. I hope this helps.
Posted on Jan 20, 2009
Can u put a video on how to put a belt on a Kirby vacumn
Try this YouTube video: http://youtu.be/At7tqnjD-Kc
Mar 01, 2015 | Kirby Vacuums
I bought a Kenmore 30012 Quick Clean Vacuum on 7/5/2011 it was working fine till just recently. Its not picking up anything off my rug, I've cleaned the filters, the belt is fine. It was blowing dust...
A clogged inlet. Something is likely clogging the opening where the dirt goes in. Paper, cellophane, or anything else light enough to get sucked in but too large to pass through.
Aug 18, 2011 | Kenmore Quick Clean 30012 Vacuum
Do you remove filter while vacumning water
nope. You leave it on. It is OK to do that. It also will rinse the debris out of it too.
Aug 12, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Our vacum isn't picking up @ all.we did have some thread around the brushes, about an inch wide. it has an odor like it is getting hot. the vacumn is about 1-1/2 yrs old. we need help. thanks BETTY COX.
Hi, The most likely cause would be a blockage. If you remove vac hose, does it **** on your hand? secondly, with the vac unplugged, Can you turn the brush reasonably freely ? Is the drive belt on?
Aug 31, 2009 | Vacuums
Vacuum is whistling and there is no suction through the hose.
Sometimes mine "wand" has no suction too. . . Make sure the vacumn column is clicked into the "standing" position, don't have it at an angle. Also you may have to play with the settings on the bottom part AND the power button together. I think this vacumn sucks (pardon the pun) mine turns off after 10 minutes of use, then I let it sit for an hour and then it'll start again. POS!
Apr 22, 2009 | Fantom Vacums XT450K Upright Vacuum
Fantom twister wont work light is on
When you say, "just stopped", did the MOTOR stop operating and there's no sound from it at all? Or, is the motor still working or sounds like it does, and it stopped vacumning?
If the MOTOR stopped, most likely there is a short somewhere in the connection at the motor. Think 'repair shop'.
If the motor still runs and there's no VACUMN ACTION, think Roller Brush which operates by virtue of a rubber belt. Turn the machine on its side and turn it ON, keeping FINGERS !AWAY! from the roller area. If the Roller Brush is not moving it may be that the belt has slipped off or is broken or simply too loose to turn the Roller. Also sometimes debris such as strings, long hair, carpet strands/fibers will become wrapped around the roller especially next to the roller bearing/brace points, to the point of binding so tightly that the roller will no longer be able to actually roll which would now prevent it from 'Vacumning' or sweeping dirt and such up into the vortex of the vacumn chamber. In which case, !!UNPLUG!! the machine, use small scissors to cut away the material wrapped around the roller paying particular attention to the brace point areas.
Apr 20, 2009 | Fantom Vacums FM780 Twister 700LX Upright...
My Dyson animal vacumn refuses to pick anything up, even a tiny piece of lint?????? It was working fine for awhile. I paid $500.00 for this cleaner at Target because I have 4 inside cats.
remove the vacuum debris recepticle and pull up on the filter cover..
You can:
1. quick fix..use a SHOP VAC and vacuum it thoroughly replace
2. wash and dry thoroughly and replace should fix problem
...I have a spare filter to use while other is drying..you can purchase off the Dyson site..
Caution be sure filter cover snaps shut before using
Dec 29, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
No wand suction
  1. i cleaned out my fanton and no suction in wand and still whistles
Aug 17, 2008 | Fantom Vacums XT450K Upright Vacuum
Bissell Healthy Home Vacumn
On the Healthy Homes Vac, did you check the switch for the vac, there are 2 on the handle, and the one could be open. Check the wiring at the motor, could even be the motor itself. If at the motor there is a thermostat, it could be bad, but comes with the motor.
Jan 06, 2008 | Bissell 3594 CleanView PowerTrak Bagless...
Eureka 2961AVZ Bagless Upright Vacuum Logo
274 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
