Question about Xerox Phaser 8500/DN Printer
Phaser 8500 reservoir heater took too long 13,266.44 error
After a power outtage my Xerox Phaser 8500n will not complete startup because of a 13,266.44 error. The service manual says that "the printhead reservoir heater took too long to reach its setpoint".
In service mode when I turn on the heaters and watch the temps, the first 3 sensors measure the head heating up to 140C then maintains 120C or 130C I think. The fourth sensor has a malfunction I think. It reads the correct temperature but sometimes jumps to 200C or drops to 20C for a second or two then goes back to normal.
I'm trying to figure out if there is a software problem because of a power surge or if there really is a problem with the print head since I hadn't restarted it in 5 months. I pulled out the print head and realized that there isn't an easy way to fix anything on the board since it is soldered to the metal head.
Any help would be greatly appreciated!
  • SibylSys May 11, 2010
    Since you are getting the error from the onboard lcd display you can rule out a software issue. IS it still under Xerox warranty?
    President:
  • 2,072 Answers
Most likely you have a bad print head. There is an outside chance that the electronics module is bad, but with the monitors acting as you describe, I would say the print head heater is malfunctioning of the sensor is defective. Either way you have to replace the print head. No uncommon.
Posted on Feb 02, 2009
:I have a Xerox Phaser 8500 with the following error: 13.323.47:31989. Any ideas what this is?
This fault code is saying that the printhead reservoir thermistor circuit is open. Unfortunately, only a printhead replacement will solve this problem.
Jan 09, 2011 | Xerox Phaser 8500N Printer
Xerox phaser 8500 fault 37,018.45:7725
37,018.45: Head Maintenance Clutch Disconnect. The Head Maintenance Clutch is not drawing the expected power from the supply.
You'll probably need service.
Jun 20, 2010 | Xerox Phaser 8500N Printer
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
Here is your problem.
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Phaser 8500dn error code 13,266,44
You have either an intermittent Electronics module or a intermittent print head. Lowest cost new from Xerox is $750.
Phaser printers are expensive.
May 05, 2009 | Xerox Phaser 8500/DN Printer
Print-head is shot... You'll need a new one, I see power spikes wiping them out quite often, Leaving your Xerox Phaser Solid-Ink printer on all the time usually isnt a problem.. but be smart about it... if a storm is comming or the forcast says lightning, shut it down :)
Jan 20, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8500N Printer Error 09,037.45:9085
You have to go into Diagnostics. Once in Diagnostics arrow down to function menu.
Then select
Then arrow down to ClearISCfaults hit OK
follow instructions on screen.
Nov 24, 2008 | Xerox Phaser 8500/DN Printer
Xerox Phaser 8500 does not turn on at all
Most likely the electronics module has gone bad.
Sep 11, 2008 | Xerox Phaser 8500N Printer
That is a yellow ink stick fault.
One is most likely stuck. cracked or otherwise not advance to the front of the ink loader. Check the sticks
May 27, 2008 | Xerox Phaser 8500/DN Printer
Phaser 8500N color problem
There is a process called TEKCOLOR correction.
It is on the xerox.com site.
Search for phaser 8500 under the support, in support in the search area enter.
Solutions for Colors are Off or Wrong
This will take you through the process in the correct steps to resolve your issue
Nov 07, 2007 | Xerox Phaser 8500N Printer
Fault 37,008.44:6069
That is a pre heater fault.
Most likley the pre heater needs to be replaced
Aug 29, 2007 | Xerox Phaser 8500N Printer
Xerox Phaser  8500/DN Printer Logo
174 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
