Question about Air Tools & Compressors
I have a puma 4025 direct drive the fan turns but compressor does not
2 Suggested Answers
seanpwright
  • 2030 Answers
SOURCE: 3 phase air compressor wrong rotation
yes it will you need to make sure you have the proper wires connected to get either clockwise or counter-clockwise rotation.
try changing the hot wires around to correct your problem
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Posted on Mar 31, 2010
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
Feb 26, 2015 | Puma Air Air Compressors Puma Air PK6060V...
How do I fix my pressure switch on my puma 6060 compressor
Need some details, exactly what is it doing or not doing incorrectly.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/oscar_403cc49e0f00cda7
What compressor oil do i need for my puma air compressor
Any name brand compressor oil will be fine, just make sure to drain the old first, and then refill
May 30, 2014 | Puma Air Air Compressors Puma Air PUK5520G...
I need to convert mu Puma PPH 30-10 air compressor from 220 Volt to 110 Volt wiring, but I do not have the owners manual or a wiring diagram for it. The Motor is a GE
If this is a 3HP I don't think you can switch it. However there is usually a wiring diagram under the square box on the side of the motor.
Sep 29, 2013 | Puma 3-HP 60-Gallon Belt Drive...
I have a Puma air compressor model # DD-2004v. I have replaced the piston in the compressor because I was told the one had gone bad. In order to get the new piston up in the compressor I removed the fan...
Hi cleancutc844...
Sounds to me like the fan is running in the wrong directions and not cooling the motor as intended.
Reverse your wires to to reverse the rotation of the fan motor and make sure it is pushing air over the motor to keep it cool while running.
Please take time to rate me
Sep 17, 2011 | Puma Air Tools & Compressors
I have a PUMA air compressor that has been running fine until this morning, it will not run, I have power (220 ) to the wires at the pressure switch and the reset button was not tripped, motor and...
If you remove the fan belt and the motor runs without a load,
one of your motor capacitors is bad. some motors take one
capacitor, some take two. the capacitor is what helps the
the motor give that extra torque to run the compressor pump.
good luck!
Jul 17, 2011 | Campbell Hausfeld 5HP 20 Gallon Single...
My puma air compressor after use will get hot and shut down then i have to wait until it cools down (half hour )then i have to hit the reset button on the electric motor
the motor is working too hard or the power source is not adequate or you are using a extension cord never use a extension cord for a air compressor you will destroy the motor over time use longer hose and plug it in to the outlet directly
Jul 06, 2011 | Puma Air Tools & Compressors
Mar 31, 2010 | Air Tools & Compressors
Air Tools & Compressors Logo
13 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
