Question about Hotpoint RGB535 Gas Kitchen Range
Oven wont light I changed glo plug its fine gas is going to safety valve and coming out but wont light
I made sure gas was entering valve and coming out top to burner when I blow air on valve the burner lights very low for 2 sec then goes out
Krazytech
  • 725 Answers
SOURCE: Low flame
so you stove was converted from natural gas to LP using WB28K10043 KIT-CONVERSION L.P. ? is this correct?
Posted on Aug 25, 2007
  • 619 Answers
SOURCE: Burners wont come on.
Hi , try to check the power outlet , posible recock the breaker , check also the piower cord test with continuity tester both end of cord (diconnect before you test ) switch on knob if tester response , try to connect to power outlet test the electric stove.
Posted on Feb 14, 2008
dutchman05
  • 487 Answers
SOURCE: oven & broiler not working
Please follow this LINK for your manual
Posted on Jun 16, 2008
Master_Tech
  • 770 Answers
you ignitor is going out you will need to replace it the ignitor needs to draw a min of 3.2 amps in order to open the gas valve coil if short of this it will not open at thimes it may just have enough to open
Posted on Jul 09, 2008
  • 63 Answers
SOURCE: Replacing Igniter on Hotpoint RGB528PEAWW Gas Kitchen Range
you should have a broil glow coil at tol and one on bottom. to access the bottom, open the door and look to the back on the oven floor. ther should be a srew one on each side remove and lift bottom up. you should be looking at the glow coil. i would also remove the pan drawer for access.it would be abnormal for bth the broil and bake to fail at the same time. if this is the case i would confirm power is leaving control to the selected glow bar. they shoul pull about 3.2 amps. then i would focus on the valve. which is opened by the amp draw of the bar. one wire on the valve is common and the other feeds from the control through the valve to the glow bar
Posted on May 19, 2009
Magic chef troubleshooting
Have you checked the voltage to the gas valve?
Aug 30, 2014 | Kitchen Ranges
Oven will not light. the glow element comes on but the burners will not ignite to heat the oven
You could have a weak glo bar, that is common or the main oven gas valve could be bad.You have to trouble shoot and find out which it is.If you happen to have a seperate broiler in that range that has a separate glo bar you can use it in the lower oven to see if it will open the gas valve.Hope this helps.
Jun 03, 2011 | Magic Chef Ovens
Oven wont work but range top does
Your range has a small 3"x1"x1" metal box with a gas valve going into it placed right behind the broiler flame tube; this gas safety valve alows the gas to enter the "pilot" tube to be lit by an piezio electric ignitor: that is the clicking you hear when you try to operate the oven. this gas valve needs to be replaced as, it is not opening to feed gas to the ignitor. an appliance parts store will have the oven gas valve; it just screws into place. be sure to turn off the gas and, remove power to the range before you do any work on it.
Apr 06, 2010 | Magic Chef 31000 Gas Kitchen Range
I just replaced both the igniter and safety valve for the oven. When I plug in the oven, the oven comes on and stays on without setting the bake temp. The flame wont go out unless I unplugthe power
Your electronic oven control(clock) has failed in a short circuit mode.
Approximate cost is $120.
Go to repairclinic. com and enter your model number for a replacement electronic oven control.
Jan 10, 2010 | Maytag MGR4452BDW / MGR4452BDQ /...
Dynasty oven fails to get enough gas to light.
I think you are talking about the oven safety valve or thermal valve. before you change you oven safety valve, I would check the Amperage on the oven ignitor first, install AMP meter on one of the ignitor wire, it should draw above 3AMPs, if not then you have problem with the oven ignitor and not the safety valve. we hardly change the safety valve, I'll try to change the ignitor first. Have fun.
Mar 28, 2009 | Dynasty DGRSC 30 Gas Kitchen Range
The oven doesn't work ,the ignator doesn't light up. no gas coming oven doesnt work. it wont ignite. i smell no gas coming in. burners work fine
ok try your broiler if it lights change the glow bar in the lower oven the glow bar acts as a safty if it doesnt reach a certain temp the safty valve wont alow gas to enter the broiler and bake are on seperate ignighters if neither work change the safty valve
Feb 11, 2009 | Amana ARGS7650SS Gas Kitchen Range
Oven will not light
Hi!!! Even if your ignitor glows just change it it has a weak charge..Also if you change glow ignitor and it does not come on then your gas safety gas valve if shorted good luck..
Jan 04, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Dec 23, 2008 | Ovens
Frididaire gas oven won't light
Does the cooktop burners work? if they do then the problem is either the safety valve or the glow plug (even though it glows). Try tapping the safety valve. If the oven lights up change the glow plug.Otherwise change the safety valve
Regards
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Hotpoint RGB535 Gas Kitchen Range Logo
Top Hotpoint Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
