Question about Century Welding Tools
Need fan motor for century buzz box 230 amp welder part no. w489947
Need fan and motor where can i find it
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
  • 413 Answers
SOURCE: welder wheel motor not working ,no power
I would look for a blown fuse....
On or in the main box of the welder.
Posted on Jun 06, 2009
SOURCE: lincoln mig welder 180, 230 volt 20 Amp Input.
Inspector is correct! In wall or conduit wiring awg will always be greater than "open air" wiring. IE: the size of wire coming from your pole ... it's smaller than from your service riser into your meter. Code allows the cord to heat up... open air will cool it down.
Posted on Dec 13, 2009
luxur4
  • 92 Answers
SOURCE: Does anyone know where I can find a how to manual
There a hundreds of books published on the subject, if you live in the USA contact Hobart, lincoln, Esab, all publish books and manuals.
Posted on Jan 27, 2010
  • 4 Answers
SOURCE: i have an 80 amp century welder it arkc without
sounds like a relay is stuck closed. locate it and tap with a screwdriver handle.
Posted on Oct 17, 2010
Will my century 230 ark/tig welder switch from ac to dc
Your question is not clear, but if it is, your welder should have an handle to switch from dc+to dc- and ac, it wont do it on its own
Sep 23, 2014 | Welding Tools
230 volt welder
Breaker must be 50A and the size wire should be a 8/3.
Feb 23, 2014 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
I have a marathon 3hp motor wired for 220 on a campbell hausfield air compressor. It has a white, black, and green wire coming out of the motor. I am using a no. 12 wire with ground. how do i wire it up to...
Hi! sims146
The Green wire from the electric motor is ground. Check the compressor motor, make sure it is wired for 220-230 Volts. If it has a white wire it could be wired 120 Volts. There should be voltage and current ratings on the motor plate. I always double check these connections. At 230 Volts this motor should be 17 Amps full Load. A 25-30 amp fuses are required to protect this motor circuit. Otherwise up to a 42.5 Amp Inverse Time Delay Breaker could be used.
The welder circuit should have 230 Volts between the Red and Black wires. The white wire is Nutral / Ground. Hopefully this is a 30 to 40 Amp circuit. The Four prong air compressor outlet, White is Neutral, Black and Red 230 Volts, Gray should be ground. Please check with Voltmeter, as some times people swap colors.
InMrFixIt
Jun 25, 2011 | Garden
We need to know how to get an owners manual for this Welder~Century Welder 230 amp ac #84234
This manual is available for download for $8 at:
http://www.centurytool.net/Century_82021_25_Amp_Plasma_Cutter_Owners_Guide_p/811-656-000.htm
Feb 07, 2011 | Century Portable Plasma Cutter 82021
I have a Dayton 230 amp buzz box and cann 't find a replacement fan motor anyone know where to look
Try Grainger.com/Dayton-Motor. I've had good results with grainger . Just have model number and part number if possible. They aren't the cheapest but I like dealing with them. Good luck and hope you have a good year.
Dec 30, 2010 | Lincoln Electric K1297 AC/DC 225/125 Stick...
Welder wheel motor not working ,no power
Jun 06, 2009 | Welding Tools
Welding Tools Logo
Top Century Welding Tools Experts
Bill Boyd
Are you a Century Welding Tool Expert? Answer questions, earn points and help others
