Question about Samsung RF197ABRS Bottom Freezer French Door Refrigerator
Space icemaker for samsung #RF217ACRS is not working
How can I fix space Compact Icemaker ?
SOURCE: Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Posted on Oct 26, 2007
relaga58
  • 158 Answers
SOURCE: Samsung refrigerator RS267LABP icemaker
it could that your thermostat is set too cold making the ice crack and brittle
Posted on May 06, 2009
  • 76 Answers
SOURCE: samsung rf267aars icemaker stops making ice
unfortunately it sounds like you have a broken tooth on the drive or driven gear of the ice maker, in this case you should replace the ice maker. The good news is that you can get a new one for about 85 bucks at your local appliance parts store.
Posted on Jun 23, 2009
rylee_smith
  • 8619 Answers
SOURCE: RS 2545SH ICEMAKER
Hi
Thanks for using FixYa. Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahrenheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary. Also, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
If still the issue is not resolved then r
emove the ice bin and wires from the auger motor. With the freezer door open and the door switch depressed, push the ice cube release and check for 120VAC between the motor wires. If there is 120VAC then the motor has gone bad. If there is no 120VAC then the control board (module time delay) has to be replaced.
You would need to unsnap (use a flathead screwdriver in the 2 little slots underneath the bottom frame piece to unsnap it) the front dispenser frame. Then look at support bracket to see if the little plastic pins are not broken that hold ice and water dispenser switches in place.
If that looks ok, then you would need to use an ohm meter to test continuity in ice dispenser switch. Replace whichever is required.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 22, 2010
  • 113 Answers
SOURCE: My Samsung Space Icemaker makes ice very slowly.
Yes, this is a "known" issue with the Samsung's refrigerators. You need to order a new icemaker. The icemaker will come with a brand new control board with new firmware. Replace both of them and this will fix problem. The control board should be located at the back of refrigerator under back panel
Posted on Sep 26, 2010
Testimonial: "Your answer was partly correct. I did have to replace the ice-maker but not the board. It was a simple pull the old one out and insert the new one"
Ice maker not working Samsung Ice Master
Chances are that your ice maker sensor has failed. Easiest way to fix it is to replace the icemaker. It's very easy to do, UNLESS you have a direct contact icemaker, the kind that has the refrigerant tube going through the icemaker. You must place the icemaker in defrost in service mode to thaw out, otherwise you will break the tubing and the refrigerator is no good, unrepairable. YouTube is often helpful to determine this. If you aren't 100% sure, don't risk it, call a professional.
Aug 06, 2015 | Samsung Refrigerators
How do I reset icemaker on Samsung model RS263TDWP/XAA
Make sure the molex plug has not been reversed.
Oct 06, 2014 | Refrigerators
Ps78139 icemaker not getting water to ice tray
Hello, Check the water line coming into the back of the refrigerator to make sure not kinked. First replace inline water filter. If that doesn't fix, then the icemaker will have to be replaced.
May 16, 2014 | Continental PS78111 Compact Refrigerator
Samsung (french door Space icemaker)-little white paddle arm that shuts off icemaker when tray fills fell off. How/where does it reattach?
You should find a small metal rod or something like that. It will be free and by itself. Simply slide the paddle back on. The paddle should have a hole in the end to slide back on the rod.
Jan 29, 2013 | Samsung Rf267aa Freezer Genuine External...
What would cause an intermittent buzzer noise from a Samsung RF217ACRS refrigerator? It otherwise works fine.
That's the icemaker cycling.Ifya don't have water connected,it's still think'n its filling trays and dumping frozen cubes and all that stuff.Turn off the icemaker.Rigger said that.C-YAAaaaaaaaaaaaa
Aug 28, 2012 | Samsung RF217ACRS - 20 cu. ft. French Door...
My Samsung Space Icemaker makes ice very slowly. I keep hearing a click-click-click and maybe a few cubes come out. I have taken the white box inside the icemaker loose but not disconnected it. I think...
Sep 26, 2010 | Samsung RFG297AA (285 cu ft) Bottom...
"space compact icemaker" cover fell off. How to put it back?
To replace this part, locate the two holes at the front of the top base of the ice maker, going up into the freezer ceiling. Place the two half-round 'pegs' at the top of the missing cover (above the vent holes) into these holes, then press the cover back into place. The peg protruding from the back of the piece should go into the hole in the ice maker housing, and the prongs will catch on the ice maker when you snap it into place by brute force. I wasn't strong enough to push it back on with one hand, but a stronger person did it in seconds once I explained how it should fit.
May 30, 2010 | Samsung RF197ABRS Bottom Freezer French...
My samsung model #RS2578BB AUTOMATIC ICE MAKER IS NOT MAKING ICE PLS ADVISE
TOOLS NEEDED:
Eyes (fair to good shape)
#2 phillips screw driver
Flashlight
Lets assume it was working at one time right? And the FREEZER temp is BELOW 20degs
REMOVE storage bin to see icemaker.
LOCATE test button on underside or rightside of clear motor asembly.
(should be black)
Press until icemaker starts, then release button. Watch the tray twist and return to upright the should fill with water.
If icemaker worked: ICE SENSOR MAYBE BAD> ORDER NEW ICEMAKER IF THE ICE DOES NOT EJECT AFTER 4
If icemaker did not Start by pressing the test button.: UNPLUG the frig or go the Main Service Panel to the house (BREAKER BOX) and shut off the power and verify NO LIGHTS INSIDE THE FRIG>
Remove the concealed screws holding the icemaker to the ceiling.
PULL the icemaker forward to release icemaker. Using the Flashlight
LOCATE the wiring harness on the ceiling. Look for the RELEASE and Squeeze and pull down. Inspect the electrical pins to make sure all pins are equal and secured. If all is well there?
THE PROBLEM COULD BE either: ICEMAKER or Main PC Board
I would order a Icemaker assembly first since it is the least expensive.
1-800-Samsung
Good Luck and Cheers!
Seen It B4
Your Welcome
Jan 02, 2010 | Samsung RS2578BB Side by Side Refrigerator
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RF197ABRS Bottom Freezer French Door Refrigerator Logo
22 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
