Question about Sony Cyber-shot DSC-W50 Digital Camera
Compatible memory sticks
I have a Sony Cyber shot DSC-W5O, was using a Sony Memory stick Pro Duel, was given a HP Photosmart a510 printer , which is saying that memory stick isnt recognised.It states it will take: CompactFlash type 1 & 2 Memory Sticks Microdrive MultimediaCard Secure Digital SmartMedia xD-Picture Card. When i checked what Memory cards were compatible with the Cyber shot, none of the above were listed, is this correct? I thought it would take most types, does this mean i wont be able to use my printer with this camera?
  • 944 Answers
Memory stick pro duo is unfortunately not back compatible with plain Memory stick, so you wont be able to use that stick with both the camera and the printer. Here's the manual for the printer if you need it - you are correct with your list of compatible stuff; http://h10032.www1.hp.com/ctg/Manual/c00702867.pdf you are also correct about the cyber shot, it wont take non "pro" or "duo" sticks check the user guide page 95 downloadable from this link; http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCW50®ion_id=1 However, the camera and printer are both "Pict Bridge" capable, which means you can connect them together directly with a USB cable. Check the camera manual page 73 and 74 for instructions and a good description of the cable, page 25 of the printer manual for essentially the same info. You could also download the photos to your computer and either print from there or save them on a printer compatible type of memory stick/card. Unfortunately without a computer, neither are possible. If you want to order a usb cable direct from Sony if you don't have one; http://servicesales.sel.sony.com/web/productSearch.do?searchOperation=modelSearch&searchText=DSCW50 (unfortunately it is $38)!!!!! I think most camera stores would stock it also. If you want more info on memory sticks and what the differences are; http://www.memorystick.com/en/ms/variety.html Hope this helps :)
Posted on Jun 28, 2007
That's right. If the printer doesn't use the existing stick, you can't do a direct print. Do it thru the computer: plug the stick into the pc and then print the photos out to the printer.
SOURCE:
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
DSC-H2 will not accept memory card
The DSC-H2 works with Memory Stick Duos, not with Memory Stick PRO Duos.
Nov 26, 2013 | Sony Cyber-shot DSC-H2 Digital Camera
I have a Sony DSC-S75 camera and I am having a problem finding a memory stick are any of the SDHC cards compatible/
The only memory card you can use are the Sony Memory Sticks. You cannot use a Sony Memory Stick Pro, so you have to find one that is under 512MB capacity and does NOT say "Pro" on it. You cannot use any other format memory card such as SD or SDHC.
Thomas
Sep 07, 2011 | Sony Cyber-Shot DSC-S75 Digital Camera
Bought used camera Sony Cyber Shot Model DSC-P32. What Memory Stick do I need?
You can use Memory Stick standard, pro or pro duo up to 2GB with the Camera.
    A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo™ or MagicGate Memory Stick Duo media.
I have provided the Memory Stick compatibility chart for your reference.
http://esupport.sony.com/US/perl/support-info.pl?&info_id=12&mdl=DSCP32
Feb 09, 2011 | Sony Cyber-Shot DSC-P72 Digital Camera
Where to purchase a memory stick for Sony Cyber-Shot DSC-P71. Every card I have seen is not the same size as the current one I have
The DSC-P71 Camera is compatible only with the 32MB / 64MB / 128MB Memory Stick Duo only. Standard Memory Stick media cannot be used with this Camera.
It's bit hard to find out these Memory Sticks as most of the Companies discontinued manufacturing low capacity Memory Sticks. However you can try contacting a Sony Store or any Sony dealers near your area to get one.
Aug 07, 2010 | Sony Cyber-Shot DSC-P71 Digital Camera
Have Sony CyberShot DSC-F707 Sony Memory Stick Duo Adaptor and Sony Memory Stick Pro Duo 4gb When installed get C:1301 error
In DSCT1 Camera, the C:13:01 error message indicates a Self diagnostic message. Each of these codes indicates the symptoms and resolutions of the Camera. In C:13:01, the issue is with the Memory Stick being used in the Camera.
The Symptoms are:
Memory Stick Pro Duo 4GB is not compatible with the DSCF707 Camera. Maximum capacity supported by the Camera is up to 128MB. Please try using a MS with 128 MB and check if it works. A dedicated adapter (MSAC-M2) must be attached to use Memory Stick Duo or MagicGate Memory Stick Duo media.
Thanks.
KenSolutions
FixYa
Dec 24, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Will DSC-T1 accept a MARK 2 memory stick?
NO, DSC-T1 will not accept such big memory card as its hardware supports maximum 2GB card memory that is more then enough for it because its 6 mega pixel camera.
Jun 26, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Can I use 4GB Sandisk Memory Stick Pro Duo in my Sony Cyber shot DSC N1 Digital Camera''
Yes, a Memory Stick Pro Duo is the right card for this camera. The manufacturer shouldn't matter.
Jun 05, 2009 | Sony Cyber-shot DSC-N1 Digital Camera
Memory card
Hi - no, the DSC-P7 isn't compatible with Memory Stick Pro, only original Memory Stick, meaning you're limited to 128MB/stick. Having said that, the P7 is only a 3.2MPixel camera, 128MB will hold quite a few pictures, even at full resolution.
Oct 26, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
136 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
