Question about Carrier 38CKC042 Air Conditioner
Furnace runs but no heat
The red LED blinks three times fast- then three times slow. The only way to stop the gan is to unplug the unit. ???
    Genius:
  • 2,920 Answers
You need a new board. we just went through that with our heater which is electric and the board was bad.they also replaced our thermostat at the same time
Posted on Jan 20, 2009
Protech 62-24084-02 troubleshooting
62-24084-02 LED CODES
POWER LED - GREEN
ON - Normal
OFF - No power to board
OK LED - GREEN
One Blink - One hour retry delay
Two Blinks - Pressure switch failure (remains open)
Three Blinks - Limit switch fault
Four Blinks - Pressure switch failure (remains closed)
Five Blinks - Twinning fault
FLAME LED - YELLOW
ON - Good flame
Rapid Blink - Flame present with gas valve de-energizing
Slow Blink - Marginal flame
Jan 01, 2014 | Protech Rheem/62-24084-82-1PK - Integrated...
York p3hu furnace isn't blowing air
Look at the back of the service panel to the unit. It should have the troubleshooting led codes on it.
Dec 14, 2013 | Tools & Hardware - Others
Led blinks three times and no ignition.
ignitor is bad or board not feeding it power or air switch is bad or draft motor not running fast enough
Nov 02, 2013 | Carrier Honeywell Gas Furnace Control...
Bryant furnace plus 90 led code is blinking once then 3 times fast. What does it mean?
these codes are on the inside panel of the front cover of the furnace. lift off and look inside.there should be a code explain chart on the panel by the light. this panel will need to be replace correctly for the furnace to work as there is a door switch.
Jan 31, 2011 | Heating & Cooling
Red led blinking three times, furnace kicks on, runs about 10 seconds gas flow stops and it recycles, heats up runs for ten seconds
check flame sencor is clean or loose connection , or it could be the pressure switch try jumping it out and see if it stays on ,
Nov 10, 2010 | Goodman GMS90703BXA Heater
I have to unplug wait for the power light to stop flashing red multiple times before it will come on
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
Dec 06, 2009 | Philips 50PF7320A 50 in. Plasma HDTV
Carrier Gas Furnace runs fine randomly stops blowing LEDs flash
That blinking light may be the diagnostic light. Count the blinks next time it fails. Carrier units will have two different blinks depicting the error code such as one blink followed by a pause than 3 blinks giving you an error code of 13. Then look at the wiring diagram, it will have an error code chart telling you where to start with your diagnosis. You already know that if you remove the cover it erases the error code, so look thru the small window first.
Nov 30, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Induced Draft Blower Not Blowing- 3 Blinks on LED
Your doing well just right. When the call for heat is on the draft motor gets a call from the board to come on. When this happens if no voltage is present at the motor then you ahve abad baord. Replace it.
Nov 28, 2009 | Heating & Cooling
Coleman outdoor furnace/AC blower speed too fast
You are right slow for heat and fast for A/C. Here are the blower speeds black is high blue is med. and red is low if you have orange it would be med low. Look on the control board and see what color wire is connected to heat and let me know if you have something other then control board. You can take the wire that is on park and swap them around. ken
Jan 11, 2009 | Heating & Cooling
HD50PLW164 Blue LED blink 10 times fast 1 time slow , TV restarts
For clarification of code/blinks significance you should check at mfg web site .
Sep 15, 2017 | RCA HD50LPW164 50" Rear Projection HDTV
Carrier 38CKC042 Air Conditioner Logo
78 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
