Question about Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades
Changing blade in rockwell model 346 6 3/4" circular saw
  • 497 Answers
SOURCE: craftsman 7.5in. circular saw model #31511880.
Is this a brushless motor?
Posted on Nov 06, 2009
rowdy45176
  • 2176 Answers
SOURCE: cannot remove blade from craftsman circular saw
without knowing the model number I can only assume that it is a circular saw and the blade is on the right hand side and then the bolt should be a standard thread. Hold the spindle lock in and turn the bolt counter clockwise to loosen. If other than it would probably be a left hand thread and do just the opposite. Let me know and if so please provide the model number so I can look at a breakdown for the tool.
Posted on Jan 31, 2010
consaka
  • 661 Answers
SOURCE: Instructions to install blade on circular saw
Once you have the right size blade it is really simple to change it.
You only really need two things.
1. locate the button that locks the spindle. It is usually located on the body of the saw. Your manual can show you a picture of it.
2. You will need a 3/8 drive socket that fits the spindle bolt.
I believe these are standard thread orientation and come off counterclockwise.
Posted on Mar 20, 2010
  • 2527 Answers
SOURCE: Can't remove blade on circular
This bolt is what called left handed thread so you need to turn it in the oppisite driction as a normal right handed bolt. righty tighty and lefty losey well its rigthty losey. A t this point you need to get this bolt out or the saw it junk you can try slideing something under the bolt something thin and try to get back force on it as you turn the bolt in the correct dericition and see if it will thread out if it dose then you will have to get a left handed tap the size of the bolt hole and retap the hole and also get a new bolt.The tap will cost 30 dollars or so well good luck
Posted on Dec 16, 2010
HansPP
  • 2510 Answers
SOURCE: cannot tighten blade on old craftsman circular
Is the washer/spacer in the blade too thick and you are perhaps tightening up on that instead of the blade. Also check the threads on the bolt, see if the bolt turns all the way in without the blade in position. It may be jamming up before gripping the blade.
Posted on Jan 24, 2011
Where do I find a guide rail for a Rockwell 4500 circular saw?
If I'm not mistaken, that model saw is already discontinued. I suggest you call or email Tool Parts Direct or Delta. I only have band saw machine, I'm thankful that bandsawparts.com makes aftermarket parts for all brands of band saw.
Jul 17, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
How to change blade
You can download manual on bandsawmanuals.com or try to search on google , make sure to key in the model number of your bandsaw. You can also follow instructions from this article. How Do You Change Band Saw Blade
Jul 10, 2014 | Delta Woodworking Delta Rockwell 14 Inch...
Need a power cord for a porter-cable circular saw model 146
All of Porter-Cable's circular saws have model numbers starting with a 3. Assuming your saw is a 346, Porter-Cable's part number for that cord is 330079-98. If your model number isn't 346 or you can't get that part number, most any nine to twelve foot 14-2 power cord will work on your saw.
Feb 24, 2013 | Porter Cable Saws
Where can I find a blade cover for a Rockwell Radial Arm Saw that is over 20 years old.Serial # 85Fo8158 I cannot find a model # but there is a parts# 438-02-314-0911 and there is a Cat. # 33-890
Any porter cable dealer/ repair shop. Will be able to tell you if its still available or obsolete by the cat# 33-890. This is the catalog # they did not use a model # per say.
Dec 22, 2009 | Saws
I need to get a replacement saw blade guard for an old Rockwell Delta Radial arm saw. 12'' Blade Serial # MX3 2843 I don't know what model number this saw is to get the right part.
you can try going to Dewaltservicenet.com and locating it that way but with only the serial number it would be impossible. Is there any numbers on it to indicate the model or partial model and you can pull up breakdowns that way.
Dec 10, 2009 | Delta Saws
Looking for user manual Rockwell Model 215
hey there i just bought a used 215 7-
1/4" saw it came w/ a manuel
maybe i could copy it for u and send it to you unclealhenry@ymail.com
May 16, 2009 | Saws
Wood like to clean & update my rockwell model 14 band saw need a download of this saw
try there web sight, if I'm not mistaken, Delta bought out rockwell and they should be able to help. I had an old rockwell table saw and the man shaft that the blade attached to was missing.I contacted delta with the model number of the saw and they faxed me a blue print of the shaft and we machined a new one and the saw still works great.
Jan 18, 2009 | Delta 28-060 14'' Band Saw Blade 93-1/2''...
Finding the lock button..changing a circular saw blade? "skill saw brand,usa" cannot seem to find it anywhere
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Jul 03, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Sears Craftsman 7-1/4 in. Circular Saw with LaserTrac and 5 Bonus Blades Logo
427 people viewed this question
Top Sears Saws Experts
Mike Squire
john h
Mike
Are you a Sears Saw Expert? Answer questions, earn points and help others
