New hp compaq laptop. unable to access dlink connection. shows that signal is there but says "limited access" or something like that. this set up is in my daughter's house. Anything you can suggest?
  • Jay
    Jay May 11, 2010
    this usually happens when your router cannot detect any DSL or Broadband signal.
    Try this:
    Click on start > run then type in "cmd" without the quotes.
    once the command prompt window launches type in:
    "ipconfig / flushdns" then
    "ipconfig / release" then
    "ipconfig / renew" then
    "exit"
    your Lan connection will try to establish a new connection if it does try if you can access the internet.
  • 34 Answers
This can occur if the network has a password or WEP key or encryption key on it and you either don't have a password entered or you have it miss spelled.
Check with her and or the person who setup her network for the key.
Posted on Jan 20, 2009
Hi i Just bought dlink 600 i am using compaq and has iphone and internet tv all of them cant connect by wifi my compaq can only connect with a cable. on my tv it says internet connection failed. and btw cm...
ok first prep. we need to configure your router. to do that we need your compaq laptop directly connected to the dlink via ethernet cable. after securing the connection, try to open a browser, whether internet explorer or mozilla firefox. go to the address bar and type in, 192.168.1.1 it would ask you now for a username. username is " admin " password is " password " if it wont let you in, try "admin" for password. if it still cant, try to live it blank and just click on login. it would take you now to the dlink router page. there you can configure your wireless connection and set your network name. make sure to click apply settings after configuring it. then try to check your wireless connectivity again. this should work.
Sep 02, 2011 | D-Link DIR-600 Router
When i switch on my ADSL modem which is connected thro the dlink wireless router,my laptop shows"No internet access" in the task bar,but the signal zebra-band is visible-excellent signal...
Check your ip settings in your pc and make sure they are set to get dynamically. Also check under wireless lan settings that you have dynamic ip turned on.
Otherwise you will manually have to set your computer ip address to the range set in the router/modem
Oct 23, 2010 | D-Link Computers & Internet
I got d-link dir-615 wireless router and a 2wire modem 2071-a and when i set up the d-link router my desctop computer that is pluged into d-link cant get internet im 11 and got no idea wat to do oh and the...
does the computer that's directly connected to the modem connect to the internet? If not then make sure your settings are well set, your service provider (ISP) and all the other settings that your ISP supplied you have not been tempered with or modified.
Does you WDS and router communicate? Have you changed the IP addresses form the default ones that came with your devices? They usually begin with 192.. at times the default IP addresses don't work in some institutions. You can configure most DLinks using internet explorer by typing in the DLink IP address bar.
Considering your age, you need someone to show you how these things are done.
Aug 24, 2009 | D-Link 802.11g 54Mbs Cable/DSL...
Compaq NC 6000 on XP SP3 - Ethernet Drivers & Wireless Drivers
Limited connectivity means your pc not able to connect to the preffered network.................
wi-fi also not working....................
there is a problem with your router not from pc.
Apr 05, 2009 | HP Compaq nc6000 Notebook
My Hp Laptop is unable to be connected to the internet
sound like u might need to find the drivers for the cable modem even tho it worked on another pc i would try this first
Mar 24, 2009 | HP Pavilion dv6000z Notebook
Hp Pavilion dv6929nr not connected with D-link DI-624
There are a number of factors that can cause the signal of your access point to deteriorate and the performance of your network to fall under par. Practically any appliance that operates on the same frequency level (2.4 GHz) as 802.11b or 802.11g can cause interference with your wireless network. Be sure to keep cordless phones, microwaves and other electrical equipment at least 1m away from the access point. Try changing channels on the access point and test it out on one of the clients. To change the radio channel on the access point login to the configuration (usually a web based interface) and go to the Wireless Settings (will vary depending on vendor) section, select a different channel and save settings. On the client, go to Device Manager, right click your wireless network adapter and go to Properties. In the advanced tab select the Channel Property and change the Value to the same number as the one you chose on the Access Point. Disable and then re-enable the wireless connection. Also you can try by select the speed manually 802.11b or 11Mbps on your laptop wireless properties.
PLZ GIVE RATING BY CLICK ON YES or NO.
Mar 21, 2009 | HP Computers & Internet
Cannot connect dlink 1150 access point to my HP 550 laptop
go for the default ip address like 192.168.1.1 or 192.168.2.1 or 192.168.0.1 this default ip address you just try to go the router or access point page and then just configure it through the user manual in the CD try it.
Mar 12, 2009 | Computers & Internet
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
I have receintly bought a dlink wireless notebook adapter so i could set up my wireless wifi network at home to connect my compaq presario 900 to from a PC. I have installed everything and im getting a...
Does it say limited connection to network? You're connecting it through a wireless router right? Do you see your wireless router when you search for networks?
I had similar problem with my previous Dell laptop. Wireless use to work untill one day it just stopped, found the networks, but kept giving me limited connection whenever i tried to connect. I found out the problem is linked with the driver. Dell laptop i had was also on XP OS.
Maybe try reinstalling the drivers. After I formatted my computer and reinstalled drivers, it started working again.
Hope this helps.
Jun 21, 2008 | Computers & Internet
I am unable to set up wireless.
What model router do you have? Are any other computers connected to this router? Can you see the SSID for your router when you attempt to connect?
Dec 20, 2007 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
David Payne
David Payne
