Question about Nintendo Wii Console
Can't get my Wii to connect to internet via LAN Adapter.
I have a Homeportal 1800HG DSL modem that the ethernet cable is going into. The most frustrating thing is that Im just taking the ethernet cable that is connecting my PS3 into it and switching it over to the Wii LAN adapter. In other words my PS3 works just fine with internet access, whereas the Nintendo Wii will not. An error code of 51420 is what I end up getting with the Wii.
  • cubbyblue198 Jan 23, 2009
    Yeah I do have the adapter and have gone to nintendos site. I guess I should just admit defeat and give nintendo a call. thanks
  • Anonymous Jan 27, 2009
    I have VERIZON FIO internet and i have model MI424WR I have tried so many times to get it working. I have wireless too and it doesn't work i don't know if its compatible or not. I also want to get WIFI on my DS but still nothing. I don't know whether to get the LAN adapter or not since once you open you can't return it.
    Problem Solver:
  • 14 Answers
First thing to verify is that your using the licensed wii lan adapter, then you can go to www.nintendo.com and click on the support link to look up the error codes your getting. Have you called into nintendo to ask if you have a compatible router? may want to try that as well.
Posted on Jan 20, 2009
I m trying to connect Internet but I m getting the error code 51422 Please help what should I do?
1. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
2. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
3. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
4. If possible, try another Wii LAN Adapter.
Aug 23, 2011 | Nintendo Wii Console
Error code 51420 on my wii console. I am trying to establish a connection to the internet. I have a router which is working properly because i can get on the internet now. I have ran my ethernet cable...
Error Code: 51420 The Wii console is not able to connect to your wired router or modem.
  1. If your connection worked previously, check to see if there is a Wii System Update that you have not aquired. To get the latest Wii System Update:
    1. From the Wii's main menu, select the Wii icon along the bottom left of the screen.
    2. Select "Wii Settings".
    3. Click the left arrow to get to Wii System Settings 3
    4. Choose "Wii System Update"
    5. Choose "Yes" to connect to the internet and perform a Wii system update.
  2. Make sure that you are using the Wii LAN Adapter made by Nintendo. LAN adapters not made by Nintendo likely will not work with the Wii console.
  3. Check to make sure you are not running the Wii LAN Adapter from a USB hub (a device that connects multiple USB products through a single device), as this will likely not work. Connect the USB Connector directly to the modem or router.
  4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off.
  5. Check to see if the ethernet cable you are using is not working properly, by connecting another ethernet cable from your router/modem to the Wii LAN Adapter. If the connection works using a different cable, then the problem was with the first cable.
  6. If possible, try another Wii LAN Adapter. If you are unable to try another Wii LAN Adapter, or are still receiving this error code, please call 1-800-255-3700 for assistance.
Jun 22, 2011 | Nintendo Wii Console
I have internet through cable.it runs through the sb5101u surfboard motorola modem. i bought the lan adaptor to go to the wii, for netflix, but it won't connect to the internet. error code 52020
Here is the solution from nintendo:
  1. Power off the Wii. Connect the official Nintendo Wii LAN adapter to the Wii, and insert a working ethernet cable into the official Nintendo Wii LAN Adapter.
  2. Unplug all devices from your modem. Most modems are unable to support more than one device at a time.
  3. Power cycle your modem. To do this, unplug the power from your modem and let it rest for 20 seconds. Plug the power back in. Connect the Ethernet cable from your Wii console to the Ethernet port on your modem.
  4. If the connection test fails, try a "Manual Setup" with the Wii console (how to), using your network's IP address, Default Gateway, Subnet Mask, and DNS information. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input theseexactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
  5. If you are still unable to connect and you are using broadband Internet, then your ISP likely uses PPPoE to establish a connection to their network. The Wii is not compatible with PPPoE. Contact your ISP for more assistance.
May 05, 2011 | Nintendo Wii Console
How to set up nintendo wii internet
  • 1 In order to set up your Nintendo Wii internet connection, you need to have high speed internet service, such as DSL, cable, or fiber optic.
    If you want to use a wired connection for your Wii, you will need to purchase the Nintendo Wii Lan Adapter and a long ethernet cable to reach your router or modem. The Wii Lan adapter is available from many sources for about $30 and the cable will cost you around $10 or more. If you want to plug in your computer and Wii at the same time, you will need a router. You do not need a router if you are planning on unplugging your computer when you use Wii over the internet. Honestly, wireless routers cost about $35 and don't require a cable, so I purchased a wireless router instead. Plus, I don't want an ugly cable running across the room.
    If you still want to use the Wii Lan adapter to connect to the internet, here are the steps to connect your Wii Lan adapter to your Wii game system:
    Make sure your Wii game system is turned off.
    Attach the Wii Lan adapter to the USB port on the back of your console.
    Connect the other end to an ethernet cable that goes to your router or modem.
    Turn your console back on.
  • 2
    If you are using the Nintendo Wii Lan Adapter to connect to the internet, follow this step. If you are connecting to the internet via a wireless router, skip this step and go to step 3.
    To connect your Wii via a wired connection:
    Go to the Wii Menu.
    Click on the round Wii button on the lower left corner.
    Click Wii Settings.
    Click the right arrow to go to page 2.
    Click on the Internet button.
    Click Connection Settings.
    Click Connection 3.
    Click Wired Connection.
    Your Wii will do a connection test and hopefully everything will be all set. You are now finished.
  • 3
    To connect your Wii via a wireless connection:
    Go to the Wii Menu.
    Click Wii Settings.
    Click Connection 3.
    Click Wireless Connection.
    Select Search for Access Point. Click OK.
    Select the access point you want to use. Click Save and OK.
    You may be prompted to enter your password.
    Your Wii should now be all connected.
  • Nov 28, 2010 | Nintendo Wii Console
    I'm trying to connect my Wii to the internet with the "Nintendo Lan Adaptor". I plug the ethernet cable at the back of my cable modem (motorola SB5100). I get errors 51420, 52020 and 50299 Help...
      Connecting directly to a modem:
      3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings, including the settings listed above. Input these exactly as they're listed into the "Manual Setup" of the Wii console's internet connection.
    Sep 13, 2010 | Nintendo Wii Console
    Unable to connect to internet
    2. Make sure that you are using the Wii LAN Adapter made by Nintendo (click here for a picture and connection steps). LAN adapters not made by Nintendo likely will not work with the Wii console.
    4. Ensure that the Wii LAN Adapter setup is correct, and that the Wii LAN Adapter was connected with the console turned off. For step by step connection instructions, please click here.
    Jul 06, 2010 | Nintendo Wii Console
    Error code 51420
    Fiend your solution direct from nintendo. Here is your solution....
    http://www.nintendo.com/wiiconsole/prob676ijt65/solution
    oishuk13
    Dec 26, 2009 | Nintendo Wii Console
    Error code 51420-- wii is hooked via usb to modem and unable to connect
    This is directly from the Nintendo Tech Support Site
    1. If your connection worked previously, check to see if thereis a Wii System Update that you have not aquired. To get the latest WiiSystem Update:
    3. Check to make sure you are not running the Wii LAN Adapterfrom a USB hub (a device that connects multiple USB products through asingle device), as this will likely not work. Connect the USB Connectordirectly to the modem or router.
    6. Ifpossible, try another Wii LAN Adapter. If you are unable to try anotherWii LAN Adapter, or are still receiving this error code, please call1-800-255-3700 for assistance.
    If you need step by step instructions on how to set up the Wii LAN, click this link
    Installing the Wii LAN Adapter
    Dec 08, 2009 | Nintendo Wii Console
    How do i get connection 24 on my wii?
    When you are not able to connect with Internet from Your Wii, means there is something wrong with the settings. You may go to Wii Fix Guide and check out the guide available there, This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge.....
    Mar 09, 2009 | Nintendo Wii Console
    Wii wired internet connection problems
    if you have all of these
    Requirements to Connect the Wii Console Online with a Wired Connection In order to connect the Wii console online with a wired connection, you will need the following:
    • A Wii LAN Adapter (where to buy)
    • An active broadband internet connection, such as DSL or Cable.
    • A compatible Internet Service Provider (ISP). Some ISPs require a sign-in every time you connect online, or are otherwise incompatible. Contact your ISP for more information.
    • Either a cable modem or wired router with an available ethernet port. (DSL users: while some DSL modems may be compatible, our experience has shown that many are not. We recommend using a router.)
    • An ethernet cable.
    then go here for more information
    http://www.nintendo.com/consumer/systems/wii/en_na/connectingOnline.jsp?entryId=wdRouter
    this information was found on nintendo's customer service website
    I hope you find it useful
    Dec 29, 2008 | Nintendo Wii Console
    Nintendo Wii Console Logo
    146 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Troy Gorman
    Troy Gorman
    phil
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
