Question about Linksys WRT160N Wireless Router
Lacking correct cable
Don't have ethernet cable on my computer to plug into WRT160N router. Can my modem to the router with cable supplied with router, but what must I connect from computer to router?
  • 306 Answers
Simply an RJ45 cable connector. Routers are broadband and a dialup modem will not work. You need an ethernet card. They are cheap and easy to get. Steve
Posted on Jan 26, 2009
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
Ethernet lights not lighting
Make sure your ethernet cable is not damaged in any way. If you have a secondary ethernet cable somewhere around your house then try it with that. Ethernet lights light up only when there is a power signal coming from either side of the cable. Most likely one of the wires inside the cable got damaged and is not letting the router know that it has something plugged into it.
If you dont have a secondary ethernet cable then switch the cable that comes out of your internet modem into the router with the suspect cable and see if you get a internet light on your router. You can further test this by directly plugging into your computer and see if it gives you a connection of some sort. If your computer continues to say that there is no network cable plugged in then you have a bad cable.
Apr 15, 2011 | Linksys WRT160N Wireless Router
I can't install the router from the CD to my computer, I follow the steps, but when it says please wait reconizeing your router, it want reconize it says check the ethernet conections.
You don't need to install a wireless router. unplug your modem, connect the ethernet cable from your modem to the port on your router labeled internet or WAN, and then plug in the modem and router. Connect your computer to the network and you should be online.
Mar 04, 2011 | Linksys WRT160N Wireless Router
Wireless router will not work without my ethernet cable connected
you need to go into the router settings and turn the wireless on and then it will work
Jan 12, 2011 | Toshiba Computers & Internet
Unable to connect to internet through Linksys WRT160N router. Can unplug it and internet is fine. Tried power cycling the modem and router. Linksys comes up with all lights flashing and will not...
If I understand your problem correctly, you are able to connect to the Internet when you hook the computer directly to the modem, but not when the router is connected to the modem.
If this is the case, then you need to do a power drain on the modem. Power cycling the modem is not enough to clear the NVRAM of the MAC address of your computer. You have to unplug the power cord of the modem for 15 to 20 minutes in order for the NVRAM to reset and allow the modem to recognize the MAC address of the router.
After the modem has been unplugged for 15 to 20 minutes, disconnect the power cable from the router and then connect router to the modem using the Ethernet cable.
Next with the router power cord still disconnected, plug in the power cord of the modem and allow the modem to sync to the network.
Once the modem is finished with its start-up, plug-in the power cord of the router and let it sync to the network.
After the modem has completed its start-up, it should now be connected to the internet.
Good Luck
Dec 30, 2010 | Linksys WRT160N Wireless Router
Router quite working. Wireless does not work nor
Follow this procedure :
  1. Turn off all components on your network - computer, router, modem, printers and any wifi laptops
  2. With the ethernet cable connected only between the modem and the router TURN THE POWER TO THE ROUTER ON and let it boot up.
  3. Turn on the modem and let it boot up to all lights on.
  4. Connect / boot up any and all other components on your network.
Keep this order handy in case of a power outage. Best of successes!
Dec 04, 2009 | Linksys WRT160N Wireless Router
When I connect the wrt160n in the pc it says network cable unplug
Check the Ethernet adapter status under network adapters in devicemanager.
right click my computer-properties-hardware tab-device manager-network adapter.etherrnet should be green
Jul 12, 2009 | Linksys WRT160N Wireless Router
My laptop has vista installed via usb from virgin cable modem.what must i do to install a belkin wireless g mimo router using ethernet connection?
Huh? You installed Vista through your Virgin Cable Modem? What on earth does that mean?
Are you trying to ask "How do I install my Belkin Wireless G Router?"
If that is the actual question, here is the answer:
1) Unplug your cable modem from your computer.
2) Plug the cable modem into the router using a Ethernet Cable.
3) Plug the router into the computer using another Ethernet Cable.
4) Plug in the power supply for the cable modem and then the router.
(If your cable modem is ONLY USB, and doesn't have a spot to plug in a Ethernet Cable, you'll have to call Virgin and replace the modem with a model that does)
Once everything is up and running, you should be on the internet as soon as the computer starts.
(You may want to log into the router and disable the "Wireless" settings if you aren't using them to stop others from gaining entry to your network)
Oct 23, 2008 | Belkin Computers & Internet
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from to save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Linksys WRT160N Wireless Router  Logo
41 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
