Question about Water Heaters
Vaillant ecotex 828/2 is showing error F25 - low water pressure
3 Suggested Answers
  • 30 Answers
SOURCE: I can't turn the bar pressure up on my Vaillant VCW 221 Boiler
on the pipework below there may be a silver braided hose with one or two valves on the end. turn the valve(s) so the handle is inline with the pipe this will allow water from the mains supply into the heating circuit , remember to keep an eye on the pressure gauge. fill the system to 1bar cold then shut down the valve(s). turn on the boiler and it should be ok, if you lose pressure again then you may have a leak somewhere which needs to be found.
Posted on Mar 30, 2009
mrhotandcold
  • 248 Answers
SOURCE: Vaillant boiler no heating or hot water
refere to manual check for override switch loss of pressure no problem re-pressurise and check for leak top of rad valve good place to start
Posted on Oct 11, 2009
Fit a new Water pressure sensor to a 615 Vaillant boiler
Permanent water pressure gauge is usually installed on cold water line.
temporary pressure gauge can be installed on drain valve.
Also call manufacturer.
http://waterheatertimer.org/Repair-water-heater-valve.html#pressure
gene
Aug 27, 2014 | Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Vaillant boiler ECO Max 824E F 20 error
Did you bleed the air from the pump ? Sounds like a air lock
Jul 14, 2017 | Water Heaters
Oct 10, 2009 | Water Heaters
I can`t turn the bar pressure up on my vaillant boiler
filling loop valves may be faulty or new pressure gauze may be required
Sep 30, 2009 | Water Heaters
Vaillant ecoMAX 828/2boiler goes on & off when running hot water!
water must be set at 3lts a min ,check diaphragm valve move when hot tap is on, check microswitch ,best of luck
Aug 09, 2009 | Water Heaters
Mar 25, 2009 | Water Heaters
Vaillant Mag 325 warm water only full pres. cold low pressure
you need a certain amount of water pressure for the water heater to turn on this is actaully one of the biggest problems that all manifactures forgot to tell anyone it is normal for the computer to shut down beings it is designed to heat water at a fast rate when you turn the water down, it's not enough pressure for for sensors to turn on to heat the water so turn on the spigot a little more and enjoy
Jan 26, 2009 | Water Heaters
Water Heaters Logo
195 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
