Question about Kitchen Ranges
Whirlpool Retractable (pop-up) downdraft vent system. Why is it stuck down with the filters out?
  • idongli
    idongli Jan 02, 2016
    Hi, have you figured out a solution for the issue? I have exactly the same problem as you, my whirlpool downdraft vent system is stuck down with one of the filters is out. Thanks.
SOURCE: Kitchenaid downdraft retractable vent
Your drive motor arm is not making contact with either of the two limit switches at 6 and 12 positions. Your arm may be loose, gear stripped, broken bracket. Turn off the power at the breaker panel and remove the vent pipe cover box (4 nuts) see what is going on inside. Tellstar
Posted on Feb 03, 2010
SOURCE: my viking downdraft vent isn't working. I didn't
The halogen light have all gone out (3) is there a fuse and is it hard to find or replace
Posted on Feb 08, 2010
SOURCE: Downdraft vent won't stay down. Push the button
check your bottom limit switch - i'm guessing its bad. the unit doesn't stop operating til it trips a (working) limit switch, if the switch is bad it'll cyle right past it and go back up until it hits the top limit switch (again).
Posted on Mar 20, 2010
SOURCE: Kitchen Aid downdraft hood stuck in retracted position
The filters need to be seated properly to complete an electrical safety circuit. This keeps the unit from operating without the filters. The best way I have found to fix them when they get dislodged in the closed position is by using two spatulas. The first is used to move the filter forward a bit and the second is used to keep it pushed tightly forward to complete the circuit.
Posted on Nov 25, 2010
alicantecoli
  • 22326 Answers
SOURCE: I have a 1989 model
check in the hood pipes for a rubber seal thats come adrift as something isloose or come apart allowing the hood to come too low so it passing the microswitch for the fan ,between teh tubes is a seal and suspect that one of these has collapsed allowing the hood to come down lower ,its a take it apart type job and see ?
Posted on Jan 17, 2011
KitchenAid Retractable Exhaust Fan problem when rising. When button is pushed, unit rises up about an inch. Requires 10 or more presses to extend fully. Otherwise fan and retraction is normal.
Kitchen Ventilation ' Kitchen Hoods and Fans ' KitchenAid
www.kitchenaid.com/major-appliances/hoods-and-vents/
KitchenAidShop and find how our hoods and ventilation systems clear the air in your ...Retractable Downdraft Design ... Telescopic Downdraft System in Stainless Steel.
30" Retractable Downdraft System, 600 CFM (KXD4630YSS ...
www.kitchenaid.com/shop/-[KXD4630YSS].../KXD4630YSS...
KitchenAidLearn about features and specifications for the KitchenAid 30" Retractable ... This 30-inch retractable downdraft vent rises 14 inches to help filter steam from ... 14" Rise. Enhances overall capture above the cooktop for more effective ... Makes it easy to select and adjust fan speed depending on your ventilation requirements.
KitchenAid® 36" Retractable Downdraft System, 600-1200 ...
Jan 10, 2016 | KitchenAid Dishwashers
How do I fix KitchenAid Retractable Downdraft Vent System?
No model number but they are pretty much all the same you have a failed micro switch behind each filter screen is one rarely see them go bad but filters have to be in place for unit to work, depending on model there are either two or three switches around the motor they are pretty aggravating to get to they are located in the panel below the cook top some models require the removal of the blower motor and housing and depending on the install still my not be able to remove the main panel if you can get past all of this to the switches don't waste time testing them just change all of them they get grease in them which won't allow the contacts to mate
Jan 23, 2015 | KitchenAid Dryers
Kenmore retractable vent keeps randonly going up and down , sometimes for 6-7 times before it will stop.How do we fix it?
I hope you have the $400 appliance insurance. I had the same problem in a new house purchase. First the downdraft wouldnt work, and then wouldnt stop.
It was a micro switch and motherboard issue. Took four visits by the (insurance paid for) techie to get and fit the right part. Good luck
Mar 08, 2014 | Kenmore 36" Telescopic Downdraft Range...
JVB37H1BB downdraft ventilation system stuck
Folks, I have experienced the same problem several times - in all of my cases the problem was solved by simply opening the back panel and taking out the motor assembly and re-aligning it. Check out this URL for a blow up of what's inside and parts list - http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5130126
The problem is that the arm tends to slip out and therefore won't raise or lower the hood anymore. Be careful when aligning it can be a little tricky - carefully observe the how the motor works outside of the housing via the switch and you will get the idea.
Jul 26, 2010 | GE Profile JVB67HWW 36" Telescopic...
Retractable vent stuck
after struggling for hours to remove vent for cleaning, I just happen to pull frong panel forward, and that release the vent so that i could clean it. No big deal. Simple
May 29, 2010 | KitchenAid KIRD861HSS Kitchen Hood
My viking downdraft vent isn't working. I didn't
Dec 20, 2009 | Viking Kitchen Ranges
GE Profile Telescoping Downdraft system gets stuck.
try to remove your cooktop and see if the vent unit is in your countertop too tightly. by removing the cooktop it will give the vent more space. if it works that way, then you might have to make more space for both to fit properly. i have seen this happen before and its probably what is causing it to bind and then drop suddenly. i hope you dont have a marble, slate or rock type countertop as they are very hard to trim just a little off to get everything to fit.
Jan 07, 2009 | GE Profile JVB67 36" Telescopic Downdraft...
Downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Jul 09, 2008 | Jenn-Air JED8230 Electric Cooktop
Mar 01, 2008 | KitchenAid KHTU165RSS Stainless Steel...
Kitchen Ranges Logo
329 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
