I have a bush cht101dvd home theatre kit and i cannot get any sound
I cannot get any sound and all the connections are correct even the sub woofer don't work
I have a 55" Westinghouse flat screen t.v. LCD first got it the sound worked but when we hooked our soundbar and sub woofer still no sound from tv only soundbar what do we do next? Please answer
This is correct. When you connect a sound bar or a home theatre system, the cheap inferior speakers in the television are muted so you can hear the wonderful quality of your new audio. They are made to do that, but sometimes, you will find a settings in Menu - Audio that will over-ride this.
Feb 29, 2016 | Westinghouse Televison & Video
Hello Guys,Can you please help? can I replace the sub woofer on my sony home theatre system DAV-DZ231 with a Celestion sub woofer s10
Presumably, the Celestion subwoofer is self-powered in which case it would connect to an RCA subwoofer output on your Sony system if there is one.
Oct 30, 2014 | Audio Players & Recorders
Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
Jul 23, 2009 | Onkyo HT-S780 System
I just replaced the cord running from the sub to the dvd player. now my sub will not turn on
hi,
steps to trouble shoot for sub-woofer detection :
1. please check whether the cord is securely connected at both the ends.
2. check if there is transmission through the cord (there'll be a small static through the cord if there is transmission.)
3. reset the dvd-player to default audio-output and then choose the 5.1 sound system which is the correct setting for the th-c6.
4. also check the settings in the th-c6 whether it is in 5.1 mode(whether it includes the woofer-as it can also simple use the stereo speakers)
5. now check the sound output in all speakers by playing any original home-theatre system enabled dvd.
the system will work perfectly if the cord is in good condition, otherwise please replace the cord again, and this time check it at the store.
cheers
Jul 17, 2009 | JVC TH-C6 System
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
Want to attach a extra subwoofer
If you have a "subwoofer-out" jack on the back of the receiver, you can put a y-cord on it and connect it to two powered subwoofers. Don't expect a big difference in the sound, however. You may even get less bass depending on where you position the sub-woofers.
Apr 29, 2009 | Audio Players & Recorders
Home Theatre for Acer Aspire6920
i would like to change the language on my pc
from japanese to english
Aug 19, 2008 | Acer Aspireā„¢ T180 PC Desktop
I have no sound coming from home theatre system
I would check see if you can hear any hissing coming from the speakers if there's no sound then check to see if this product has output protection fuses and if so see if they are in tact if this doesn't solve the problem you may have dead outputs. If there is hissing coming from the speakers check your audio source to make sure it is feeding sound to your amplifier without looking its hard to say in these case's there's a lot to go wrong
Nov 26, 2007 | Wave Audio CS801 Speaker
Installation Help
This means that you have purchased a three piece home theatre system. Two tweeters and a sub-woofer. Assuming you are using a Stereo player (Tape/CD/DVC)you have to connect the Left Output of the Stereo placer to the Left Input at the back of the Sub-Woofer and the Right output to the Right input of the subwoofer by cables. Then take tweeters and connect them to Right speaker and Left speaker output at the back of the sub-woofer ( note if the speakers are marked L/R, then connect them to the subwoofer output accordingly. In case you are using a 5.1 player, then only connect the front right and front left to the Right and Left input at the back of the subwoofer. You are and you can now start playing your music or movies and and you will get theatre quality sound.
Aug 22, 2007 | KLH (AT2100) System
196 people viewed this question
 Grubhead
Grubhead
