Question about Exercise & Fitness
Unable to reduce resistance to zero on proform crosstrainer 56 - even removing batteries doesn't help
Problem started when replaced batteries.
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: My Proform 100 ZLX Exercycle is stuck in low/zero pedal resistance, and doesn't respond to console settings. Can this be economically fixed?
follow the steps, and fix it. God bless you
Be aware that the resistance is often the part that requires repair. Resistance is managed magnetically, so often if the machine is working, but the resistance isn't setting correctly or at all, check the bolts that secure the magnets. If they are loose, the resistance will slip. If the bolts are fine, check the magnets themselves by using a refrigerator magnet and see if it is attracted or repelled by the your fridge magnet. If not, the magnets have de-magnetized and need to be replaced.
Posted on Dec 05, 2012
Proform 560 crosstrainer treadmill powers on belt won't turn
LUBE THE deck belt+ rollers bearing too. God bless you
proceed according with the video attached.
Jan 07, 2013 | Proform Exercise & Fitness
Dec 05, 2012 | Exercise & Fitness
Proform Crosstrainer 5.0 Treadmill
ICON CALIBRATION INSTRUCTIONS- INCLINE
1) Press the Stop and the Speed Up keys down while inserting the safety key. If this doesn’t work, click on the help topic entitled “Alternate Calibration Codes” for key sequence instructions to enter calibration.
2) Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test.
3) Press either incline key and the incline will calibrate automatically.
4) THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED.After completing calibration of incline, press the Stop key and then remove the safety key.
Jul 15, 2010 | Proform Exercise & Fitness
The magnetic resistence level seems to be the same
This unit incorporates an adjusting motor for the magnetic boot. This unit also uses batteries for the upper console functions I would check the batteries first and replace them, if you haven't done so before.
If this does not resolve the problem then it could be the adjusting motor, then you will have to pull the the side panels in order to apply a 6v dc to the motor and see if it moves smoothly, if not then replace motor.
Jun 26, 2010 | Proform Exercise & Fitness
Need a replacement manual
Go to inconservice.com click on manual here is the info you need to input
PROFORM 675 CROSSTRAINER TREADMILL (PFTL66906)
May 21, 2010 | Proform 675 Crosstrainer Treadmill
Treadmill starts instantly, no belt ramp up
HAS A SHORTED MOTOR CONTROL BOARD NEED TO BE REPLACED.
GO TO iconfitness.com then to customer service then parts repalcement
Feb 21, 2010 | Proform CrossTrainer Treadmill
Need to replace 15 amp fuse on ProForm Crosswalk Treadmill model 831297304. Is this a ''standard'' fuse or do I need to order?
Remove the fuse and take it to any auto parts store where they will match it up for you. Regards, Joe
ps - kindly rate my answer. thank you.
Feb 04, 2010 | Proform CrossTrainer Treadmill
My Proform 650v treadmill stop when running after couple of miles
Most likely a bad drive belt. Take the cover off the motor area. If you see black dust near the left side of the motor, replace the drive belt.
Oct 29, 2009 | Proform CrossTrainer Treadmill
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
