Question about Kenmore 63942 Dryer
Gas dryer suddenly won't heat
I have a Kenmore dryer, model #11072802101 that will not ignite. I was told that there was a glowplug or something to that matter, I am not sure. I need to know how to locate this item. I seem to have only to the rear of thie dryer, does this sound correct?
  • Anonymous Jan 31, 2009
    Where is pilot light to be lit on dryer?
  • jenniferbris Feb 03, 2009
    My Kenmore 80 Series gas dryer will run fine but with no heat. Or it will start out working fine but go cold mid cycle. Is there a thermostat? What are your thoughts?
  • 979 Answers
There is an igniter that should create a spark. Can you see a spark at the pilot light area? Your orifices could be clogged or dirty. Check to see if the valves and burner area are free from debris.
Posted on Jan 20, 2009
  • parlapiano1 Dec 18, 2010
    you **** still did not answer WHERE AND HOW DO I GET TO THE GLOW PLUG
Kenmore elite gas dryer he3 model 110.95862402 won't heat
Since it is gas, you need to find out if the ignitor is coming on to ignite the gas (if you have gas getting to the burners). If you have gas, but the ignitor is not coming on, then you have to determine if the electronic contol is sending a signal for the ignitor to ignite. The most likely cause is the ignitor
Jan 16, 2012 | Kenmore Dryers
Have a kenmore 11072802101 gas dryer. it will heat for about 5 min & THEN BLOWS COLD.I replaced thermal fuse.IS IT THE REGULATOR?? OR THE OPPERATING SENSOR.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Dryers
Can you show me where the thermal fuse goes for model #11072802101
That would be on the back of the dryer, inserted into the exhaust duct. This is usually within a foot up from the bottom. You will need to remove a couple of sheet screws to remove.
Apr 27, 2010 | Kenmore 72802 Gas Dryer
Have a kenmore gas dryer, model # 11072802101, that will not heat at all. have already changed the thermal fuse with no change.
The 'operating' thermostat and the high temp limit thermostat could be bad. There is also a contact on the motor in the element circuit. The two therm. mentioned should read '0' ohms with a meter. (with machine unplugged.)
Jul 09, 2009 | Dryers
Kenmore 74812 Gas Dryer. Was told it ignites,
The coils are not so that it will leak when they are removed. Two screws release the bracket on top of them and they slip right off.
Eric
Jun 22, 2009 | Kenmore 74812 Gas Dryer
No Heat
Hi, I worked on one of these yesterday and have found that the thermal fuse blows first. If your dryer has the lint filter on top then the thermal fuse is behind the back panel and is located on the same duct as the lint filter.It will usually have blue wires on it instead of black or red.
Oct 17, 2008 | Dryers
No Heat
have same problem with my dryer. Check your sensor out,
Jun 14, 2008 | Kenmore 75944 Gas Dryer
Kenmore Gas Dryer not heating. (74602)
i have a kenmore dryer the outside air vnet was cloged real bad , ive since cleaned it out but the only resone i found out was becoues my dryer will not heat up , is there a over heat swich ? can any one help .
Sep 24, 2007 | Kenmore 74602 Gas Dryer
Kenmore 63942 Dryer Logo
80 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
