Question about RCA 27V520T 27" TV
Lighting hit tv
27"RCA mod.27R410T Lighting ran in on the tv . I took the back off (after 24 hrs.) to look for a reset but didn"t see one.Are there any way to fix this myself ? If not is it worth takeing it to the shop or get another one (price and trouble)its 4 yrs. old. thanks very much ,Mike in kershaw S.C.
    President:
  • 3,130 Answers
Sets that have been hit by lightning can be very tricky to repair sometimes. it could be as simple as a shorted bridge rectifier, a current limiting resistor, or maybe an open PC trace on the board. I have seen some sets hit by lightning that took out almost every IC, tuner, several resistors, and burned several PC traces up. This repair will be up to you, if you want to spend the estimate fee, as it is highly possible that this set will not be worth the repair. Good Luck
Posted on Jun 28, 2007
SOURCE:
Rca 27r410t hdmi
This TV cannot be connected directly to streaming media.
Jan 24, 2013 | RCA 27R410T 27" TV
I have a 27 inches RCA TV (model:27R410T) , Firstable when i turn the tv on ,it works fine but just for about 2 minutes , after that video has gone , no video only audio ,and start changing channels...
It maybe some semiconductor IC got hot, need service or repair. It may repair itself if you leave it on standby for a month(at operating temprature a week)? This is low tempeature(the lower the temperature the longer the time) annealing or moisture curing technology, used by Nasa on transistor failure in satellites, or long range unmanned vehicles. You can always repair the unit later.
Aug 26, 2010 | RCA 27R410T 27" TV
27R410T 27" TV: our RCA Model 27R410T has maybe 20 hrs of total us...
Ok, well the good news is prize or NOT it is still covered by a warranty, that's the law, you need to contact your local RCA office, and ask them for a referral to an Authorised service center, and you will be able to make a claim, and in any event, that's where you are going to have to take it to be repaired in any event. The Consumer Act, indicates that anything sold must be of "Merchantable" quality, clearly any unit that fails after less than 24 hours use, falls into that definition. You simply have to find a Dealer, Service center, whatever, and in all fairness, they should take care of it, there may be some costs involved, but usually not. Below is a technical Service manual, this is what I use to train the engineers to repair these units, have a look, www.electro-tech-online.com/.../36401d1261034747-rca-32-television-32v434t-need-help-repairing-atc010_training_manual-1-.pdf
May 06, 2010 | RCA 27R410T 27" TV
Still can't get parental block to turn off on my RCA 27r410t. Have tried most of the steps found here on Fixya. Front panel is blocked also.
Unknown password-- ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
Feb 09, 2010 | RCA 27R410T 27" TV
Front panel locked and I have no unlocking code
pls. serch webside to "RCA 27R410T" see the users menual and check how to unlock your tv.
Oct 06, 2009 | RCA 27R410T 27" TV
I Forgot my parental control code!!
to reset it just unplug it. the memory only works when there is power to it.
Jun 26, 2009 | RCA 27R410T 27" TV
TV CODE
need password
Apr 08, 2008 | RCA 27R410T 27" TV
RCA 27r410t 27" won't turn on,just makes high pitch noise
that high pitch is comming from the flyback replace the flyback and the HOT.and you will restore back the life of your tv.good luck.
Jun 04, 2007 | RCA 27R410T 27" TV
RCA 27R410T
hi Sounds like a dry solder joint on or near the flyback try here: http://www.eserviceinfo.com/ good luck windman
Mar 04, 2006 | RCA 27R410T 27" TV
Televison & Video Logo
71 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
