Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Frigidaire Dishwasher Problem
When I unload the dishwasher I know that there is no water in the bottom of the machine. After a few days, water starts to collect at the bottom of the dishwasher, so I run the cycle so that the water will drain out. If I don't run it, the water will continue to collect and will eventually start spilling out the door. Any help with this problem? Going to buy a new dishwasher soon because house and wood floor can flood and be ruined! Thanks.
  • Philip Herman Oct 01, 2008
    I have A FrigidaireGallery stainless steel dishwasher. Works fine. When it's off, water collects inside. In about 4 hours water spills out the door onto the floor. I read that the water valve is letting water slowly seep in. Can I fix or replace the water valve? Where can I find instructions?
Water could be draining back in to the unit drom the disposal as well. Need to have a loop under the kitchen sink as well.
Posted on Aug 03, 2007
  • 32 Answers
By the sounds of it.i think the water inlet valve that lets water into the machine has gone faulty leaving water slowly seep into the machine, you could either replace this valve..or a cheaper solution if you can access the rear of the machine most water supplies would have a small value installed on the incomming supply,you could simply turn off the water till the next time u need to use it.
Posted on Jun 28, 2007
6ya staff
SOURCE:
Frigidaire Dishwasher - tub over flowing, water runs to bottom catch pan trips float switch causing machine to stop..Error Code I30. Any ideas.....defective float switch.....defective water valve?
The float switch may be sticking I actually had this happen on my dishwasher a few months back, remove the float from the basin and cleaned it and then reinstalled several times and it starting working again.
Jan 31, 2017 | Miscellaneous
My Frigidaire Dishwasher motor is not spinning rinse cycle
am not sure.. just try this
Check with a multi-meter for 115/220V on motor's tags.
If you don't get this voltage measurement, your problem is not with the motor.
In case you have 115/220V on motor's tags, try first to replace its brushes (2 carbon contacts that transfer the curent to the motor's armature).
try this good luck
Dec 25, 2007 | Dishwashers
Frigidaire dishwasher leak
run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
Sep 02, 2012 | Frigidaire Dishwashers
After the cycle starts, water leaks out of the bottom of the machine and into the basement
I would call for service. many probabilities and none are good. it is fixable but for a diy'er it could get to be a bit much.
Apr 29, 2012 | Frigidaire Professional Series 24 in....
Dishwasher won't run
yes the water going to the machine and the water valve has to be ohmed out with a meter
Feb 28, 2010 | Bosch SHE4AM12UC Dishwasher
Frigidaire dishwasher model [email protected]!%BXWO does not clean dishes properly
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film.(Disregard if this is not an issue)
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Dec 06, 2009 | Frigidaire Dishwashers
Frigidaire dishwasher wont run
I solved my problem by disconnecting from the power source and then reconnecting, apparently it needed to be reset, it now works fine!
Feb 15, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwasher Repair
Don't know how old your unit is but try cleaning the screen at the bottom of your unit.
Feb 10, 2008 | Kenmore 65924 Electric Dryer
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
361 people viewed this question
Top Frigidaire Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Mike
Vitally Alcher
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
