Question about Zanussi Dryers
Zenussi tds 383 catching clothes in front of drum
The drum appears to have dropped slightly,is this due to seal or a bearing problem,drum turns fine
aborcass
  • 2651 Answers
SOURCE: Fridgidare dryer problem
there is a front glide assembly, depending on model will have 3 teflon/plastic glides attached t o the felt, this may be your grinding and gap issue
Posted on Nov 16, 2008
philbran
  • 242 Answers
SOURCE: frigidaire electric dryer catches clothes at the edge of the drum
If the clothes catch on the drum edge the felt seal is worn out , and the squeak could be the bearing the drum rest on or the belt tentioner , it may need oiled , you can buy the felt seal replacement kits online and they are not hard to install.
Hope this helps.
Phil
Posted on Apr 10, 2009
  • 744 Answers
SOURCE: clothes keep catching in front ring area
>>A repair man replaced the plastic ring but the gap is still there, ruining several items per load. Is it repairable or a fatal defect?<<
The repairman should check the drum rollers, the guides, and the baffles to be sure the dryer drum is rolling true (round). Also, the replaced ring should be re-checked to be sure it's installed correctly.
Posted on Apr 11, 2009
hektor1961
  • 70 Answers
SOURCE: My dryer keeps grabbing clothes strings and
The drum slides on your dryer are worned and possibly ate away the front bulkhead and drum.
These parts keep the dryer drum aligned.
Front panel needs to be removed to determine how extensive the damage is, hopefully changing the drum slides will solve the problem.
Posted on Aug 18, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Frigidaire front load dryer catches clothes
You need to repair/replace the drum seal.
Posted on May 17, 2010
Leaving spots on clothing
Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Dec 24, 2010 | Kenmore Dryers
Maytag dryer is leaving black marks or rings on clothes
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Maytag Dryers
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Dryer only works when the door is open
  • Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
  • Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
  • Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Apr 22, 2010 | Whirlpool LEW0050P Electric Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
I'm finding pinholes in my clothing.
I'd be more suspicious of what you're putting through the wash, rather than the machine.
Aug 01, 2009 | Electrolux Frigidaire Affinity AGQ8700FE...
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
Rollers
Rear seal
Front glides
Front seal
Jun 07, 2009 | Dryers
Drum spins off center and clothes get stuck between drum and casing
Rollers
Rear seal
Front glides
Front seal
May 28, 2009 | Kenmore Dryers
Dryers Logo
29 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
