Question about Food Mixers
Need a owners manual for kitchen wonder immersion blender
Hi, I need a owners manual for a kitchen wonder electric model no 303 immersion blender, Can you please help. Thanks Tom
  • 3 more comments
  • pglenn739 Jan 30, 2009
    I have the same porblem
  • Carl Z Mar 11, 2009
    I also need a owners manual for a kitchen wonder electric model no 303 immersion blender
  • H?l?ne Larocque
    H?l?ne Larocque Jan 09, 2013
    Has anyone had luck finding the manual for the Kitchen wond
  • H?l?ne Larocque
    Has anyone had luck finding the manual for the Kitchen Wonder>
  • H?l?ne Larocque
    If yes, can you please e-mail me a copy? keikogirl_1967@hotmail.com
2 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: spare beater
http://www.marbeck.com/mixers_kitchenaid_parts.html
heres link for replacement parts
my recommendations i would go with new parts but some will like to do the work them selves
Posted on Jun 11, 2008
SOURCE: I seem to have lost the instruction manual for my
Hi
The blender does not attach to any of the two holes for the whisks.
You need to push back the sliding cover in the center, bottom part between and behind where the whiskers attach. This will uncover a third attachment possibility, where you insert the blender and twist it a quarter turn into place.
Posted on Dec 21, 2010
English manual Kenwood Gourmet FP101
This will cost 2.95 GBP
http://www.belstar-electrics.co.uk/products/Kenwood-FP101-User-Manual.html
or register free at
http://kitchen.manualsonline.com/support/kenwood/blender/please-help-find-the-manual-for-this-kenwood-food-processor-11218
Jun 02, 2012 | Kenwood Food Mixers
I can attach the immersion blender attachment but it does not turn on. The machine works fine with the mini-chopper attachment or the beaters. How can I fix this?
Hi
Make sure you use the pulse function of the power switch. Only this position (forward, away from you) will activate the immersion blender, and then at full speed only.
Feb 09, 2011 | Braun M880 MultiMix Hand Mixer
Once the blender is attached, how do you start the mixer?
You start it by pushing the switch lever forward, and you need to hold it there for as long as you want it to run. This is a momentary mode and is the only way to run the immersion blender.
Jan 18, 2011 | Braun M880 MultiMix Hand Mixer
I seem to have lost the instruction manual for my mixer. I would like to use the immersion blender, but I can't figure out how to attach it to the mixer body. The shaft on the blender is too short to...
Hi
Dec 13, 2010 | Braun M880 MultiMix Hand Mixer
I didn't get a User's Manual with my KSM90 Ultra Power Blender.How can I obtain one so I can start using my new blender?
Hi RSTOCK7. You can easily download a PDF version of your Owners Manual from the KA website at: (http://www.kitchenaid.com/flash.cmd?/#/page/home).
Click on Customer Care>Locate Manuals& Guides> and enter the 6 character model number, in your case, use KSM90PS, and select the last file listed that appears under Owners Manuals (20): KSM90PSWW0.pdf (2930.74 KB) and save that file to your PC. You’ll need to have Adobe Reader to be able to open it.
After downloading your Owner’s manual, I strongly recommend downloading the last file listed under Parts List (16) manual, too: KSM90PSWW0.pdf (354.08 KB).
The Parts List manual provides exploded view diagrams for the various assemblies of your mixer along with the part names and numbers so you can order repair parts and replace them yourself when your mixer goes out of warranty; one year from purchase date.
You can print both files and keep them in a binder along with your cook books or keep them electronically on your computer to look at when ever you need to reference them.
Good luck, I hope this helps. Howard, Burke, VA
If this solution has been helpful, please rate it, thanks! - hslincoln
Jan 14, 2010 | Food Mixers
Spare beater
Jun 04, 2008 | KitchenAid KSM90 Ultra Power Series Stand...
Oster Kitchen Center won't hold a steady speed
My wifes Oster Kitchen Center slowed down and I think finally stopped. I say I think it did because I took it apart two years ago and am finally finding the time to get it back together. I cleaned it, checked the brushes on the motor(all of this is in the base unit with the control buttons on it. The upper blender/beater arm has no electrics in it.) The brushes were coated with some kind of dried crusty stuff which was keeping them from contacting the motor.I put it back together and tried it but it only hummed and did not move.
I took it apart again, this time everything came out. Motor, electric wiring plus the metal gearbox attached to the motor which drives the blender and the upper arm. I took the transmission apart (it's attached to the motor in the base unit) and found the gears in it were so gummed up with who knows what. Probably everything that leaked out of the blender.
You see, what happens is that the seal between the blender black base and the glass jar started to leak after a few years but we don't notice it. Maybe we did but we cleaned it and we thought it was all good. But the liquid can leak down into the bottom unit around the drive teeth and that little square drive that the blender locks onto. And then it goes into the gearbox and the motor. So it is a major job to clean it. Since I don't have a manual for disassembling the lower base unit, I'm just putting it back together. I cleaned all the gunk out, put some grease on the gears and the gearbox is working better but I fear not perfect. It is 30 years old!! So unless you take it apart yourself or find an appliance repair shop (is there such a place anymore?) it might not be worth the effort. But it is do-able. How long have you got?
Mar 01, 2008 | Food Mixers
Food Mixers Logo
606 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
