Question about Sewing Machines
How to thread a 67GK373 Adler sewing machine
I am unable to thread or wind a bobbin with my machine as it came with no instructions.
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
akylas
  • 26 Answers
SOURCE: brother sewing machine ls2125
Don't go directly from the thread spool to the bobbin.
You have to go via the thread quide, (near the end of the head at left side) and under the small roller.
Pass your thread to the bobbin turn your thread 3 turns to the right, clockwise,
then pass the end of the thread, under the coming thread and give it another 3 turns to the right.
For better results, always remove old thread from bobbin before filling it up.
Push the thread winder lever to lock the bobbin.
Start winding slowly. If the thread is loading in the down position,
put your finger under the thread between the bobbin and the the thread quide, untill you see that the thread is feeding evenly.
Posted on Jun 14, 2008
SOURCE: Elna Primula 410 Bobbin Winding Question
Wind the Bobbin
For the usual jobs, it is the best to use a medium sized thread.
2. Disengage the flywheel by unscrewing the coupling knob as far as it will go.
3. Place the bobbin on the bobbin winder, and push the bobbin winder to the right.
4. Pull out one of the spool pins and place the spool of thread on it.
5. Pass the thread through the bobbin winder tension discs, as indicated.
6. Wind the end of the thread around the bobbin by hand, in the direction indicated.
7. Wind the bobbin, at a medium speed by pressing lightly with a finger on the spool so as to stretch the thread better and thus fill the bobbin to a maximum. The full bobbin stops automatically.
8. Re-engage the flywheel by tightening the coupling knob.
9. Cut the thread and remove the bobbin from the bobbin winder by pushing the latter to the left.
Posted on Aug 23, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 68 Answers
SOURCE: i just bought a white sew ez and am unable to wind
If you look on the top of the machine, there should be a little round metal disk near the far left side. That's the clamper it's talking about, also known as the bobbin winder tension. As for the hole in the bobbin, you can use any of the holes. I'm assuming you're using a metal class 15 bobbin, the plastic class 15 bobbins only have 1 small hole on each end. Both will work with your machine.
Posted on Feb 25, 2010
Athena 2000 won't wind bobbin. Needle goes up and down, but won't catch in bobbin
If you are unable to wind bobbins on your machine, for ~$25 you can purchase a stand-alone bobbin winder at the local fabric store (JoAnns or Hancocks) or online (Amazon.com).
Nov 08, 2015 | Sewing Machines
Winding bobbin on Pinnock Craftmatic MK11
How to wind and install the bobbin, and thread the sewing ...
? 8:42
www.youtube.com/watch?v=eaEjvpwXrYA
Feb 19, 2010 - Uploaded by lanido13 This is part #1 of the tutorial. It shows how to wind the bobbin. Please check out part #2 of this tutorial for ...
Pinnock sewing machine instructions 'Sewing Machines
www.offou.com/pinnock-sewing-machine-instructions-sewing-machines...
I have picked up a Pinnock Majestic Craftmatic MK11 Model HZ-140 and I am ...Machine - Setting the Needle and Awl - Threading the Machine & Bobbin.
Oct 03, 2015 | Sewing Machines
Bobbin not winding tightly
Consult your owner's manual. Possibly, you are not threading the bobbin winder correctly. The thread does go through a tensioner somewhere along the way that creates tension on the thread.
Janome MEMORY CRAFT 9700 Instruction Book Threading For Bobbin Winding
Or perhaps the tensioner is not working properly.
If neither is problem, then you can always pick up a stand-alone bobbin winder (Amazon, JoAnn's, etc) for ~$30. One brand is called Sidewinder. These bobbin winders are marvelous because you can wind bobbins without unthreading your machine. It also saves wear and tear on your machine.
Or take your machine for service.
Mar 28, 2012 | Janome Memorycraft 9700 Computerized...
MANUAL FOR ADLER SERGER 81-80
bobbin thread, the thread to it. there are two holes in the needle and a fixed loop in the machine. is there any instructional picture? very old adler nr 81-3s
Oct 26, 2011 | Sewing Machines
After following instructions on winding the bobbin for the fast bobbin winding system, the bobbin is not threading
If the bobbin spool is spinning, it will thread.
Take the end of the thread through one of the little holes in the side of the bobbin spool and pull out about 8" of thread. Hold onto it as the bobbin begins to spin.
After the thread has wound 5 - 6 turns, stop the machine and cut off the thread end. Continue the winding process.
Mar 14, 2010 | Brother CS-6000
I just bought a white sew ez and am unable to wind the bobbin following the instruction manual. The instructions say to pull the thread down through the clamper (what's a clamper; it's not shown in the...
Feb 22, 2010 | Sewing Machines
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Unable to wind bobin og CS6000 Brother sewng machine
I have the same machine and this is how I do it. If this doesn't work, then it must have a problem and not because you have done it incorrectly.
Thread the main thread on machine as shown.
Pull the end of the thread throw the top hole in the bobbin roll ( you know the little clear thing where the bobbin thread will be wind on.
Place it on the bobbin holder and push that unit to the right to touch the thing there on the right....Now turn on your machine. Either by using the sew button or using the foot pedal.
This should work...
Good luck.
Feb 06, 2009 | Brother CS-6000
Singer Concerto 9217 - problem threading bobbin
thread the same way as for sewing. put empty bobbin case in bottom. close slide plate only to red button, not all the way. wrap thread from needle around bolt that holds on the presser foot (or just hold it tight). press pedal to sew. bobbin should wind. when done, shut slide plate all the way and sew.
if this doesn't work, try using a pin to push down the center of the bobbin when the slide plate is in winding position - the little catch on the bottom of the plate breaks easily and then the bobbin won't wind without a little help.
Feb 01, 2009 | Brother CS-8060 Computerized Sewing...
Instructions for theading a Sears Kenmore Sewing machine model 158.14000
Sewman7
Jun 05, 2008 | Kenmore Sewing Machines
Sewing Machines Logo
160 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
