I have a crate BX 160 that shuts down at the point where it starts limiting and then after a about 30 seconds. it starts back up. I would like to get a schematic on this particular piece of equipment however all the online order sites do not list the BX 160. Could you tell me where I might download a schematic for this Bass Amplifier
  • 11 Answers
I just saw your post. I happen to have a Crate BX-160 and was able to call Crate in St. Louis and talked with a tech there at the plant and he actually sent me full schematics for free.
Your problem, based on my electrical background and fixing audio equipment for 10 years, seems to be related to the built-in limiter in the power transformer. In other words, you might just need a new power transformer and it is a piece of cake to install (all push-on connections).
The schematic will show you the many test points for voltage checks, but unless you know what you are looking for, its just information overload. It is a rather simple amplifier and built resonably well. I have been using mine since 2003 and have fixed it a few times (age related problems like loose connections). There just is not much to go wrong on them except for the fact the amp is subjected to extream vibration. THis causes physical connections to fail resulting in vexing issues that are hard to solve. This is not unique to this amp (all bass amps).
I would bet anything your problem is the power supply shut-down circuitry is malfunctioning. In my expereience with amps, unless the amp is drawing current (failing power circuitry) and making strange sounds, the failure is usually not related to the power section failing (like power transformers going out). Likely, the built in limiter is the problem.
I hope this helps!
-mike
(development engineer)
Posted on Mar 30, 2009
  • Art the Man Feb 15, 2013
    Hey Mike. can you help on push -on connectors? i was reasembling my amp and cant figure out where 2 red wires go..? they same colour and i not wont to connect them wrong...can you advise?
    hey Mike. can you advise on push-on connectors schematic? i disconected 2 red wires from main bord..and cant figure out how to connect them properly. couse they are both red. any ideas?thanks .
How do I determine the size of crate I should buy for my dog?
The crate should be large enough for your pet to lie down comfortably and also turn around with ease. If you are buying a crate for a puppy, try to buy one for the size he/she will grow to fit, rather than the size they are now.
Sep 03, 2012 | Pets - Others
DRYER STOPS/STARTS DOESN'T GET HOT ENOUGH
dryer duct blockage caused thermal limiters to trip. four t 20 screws remove the heater bank cover on the back of the dryer. unplug the dryer. unplug the dryer. did i forget to mention, unplug the dryer? remove the heater bank cover, and press the three red buttons in the center of each thermal limiter. at least one of them should click when you press it. replace the cover, plug the dryer in. it will now heat, but if you dont fix the blockage it will trip again.
Jun 14, 2012 | Miele T9800 Electric Dryer
Tv will turn on, for about 30 seconds, then it will shut down
Hello
There are two main reaons for this fault. The first is with its power regulator board itself. If it has any loose soldering points developed, this type of intermittent fault can occur. The second is with its light engine. If you want to do this work by yourself, you must have thorough knoledge in electroncis, and must have all tools and ability to follow its schematic diagram. The most you need is patience. If you have these all, and want to do the repairwork by yoursef, inform me. I've the schematics of your tV, and all repair adjustments and proceedings. The power supply board and lamp ballast boards for Samsung (HL-T) series are shown here for your referecne. The lamp ballast board also may need to be checked.
Nov 16, 2011 | Samsung HL-T5676S Television
I have a gas dryer, model MDG7657AWW that will not stay heated. Every time I put it on, the flame comes on for about 21 seconds & then shuts off. I replaced the igniter, hi limit thermostat, cycling t
On a gas dryer the heat normally only comes on for 30 seconds or until the drum temp reaches 160f at which time the flame is shut down by the cycling thermostat. The drum temp then starts to drop. When the drum temp reaches 105f then another blast of heat is issued for 30 more seconds.That is how they work. Put it all back together and trow a load in there.
Oct 28, 2011 | Dryers
I have a kenwood kac-9152d amplifer and it works just fine for about 10 minutes then just shuts off and subs dont work, about 30 seconds later my amp turns back on with the subs.
make sure it's well ventilated. If there's no air flow, then there is no way of cooling down and to protect itself it will shut off. Make sure the speakers are wired correctly as per amp specs. too many subs or subs connected improperly can draw too much current and shut the amp off, but you will notice this when you turn up the volume to a certain point and the amp shuts down.
Aug 30, 2011 | Kenwood KAC-9152D Car Audio Amplifier
Kenmore 800 dryer shuts down after running down to 40 minutes on the timer. When I restart it at that point it runs for about 30 seconds and shuts down. If I turn the timer back to 90 minutes it runs down...
Sounds like you may have a bad motor. If the motor is overheating it will shut down on its overload.
If its a shorted contact in the timer you could mark the spot where it stops and restart it again. It should stop exactly at that point.
Jan 22, 2010 | Kenmore Dryers
I have a similar problem. But I will provide a little bit of history first. My dryer just doesn't get hot enough (approx 100 degrees just prior to the exhaust vent). Three years ago, I had the same...
If the gas cycles on and off I do not think the coils are a problem.  Sounds like the flame sensor is not working correctly.  The flame sensor keeps the gas valve open after the ignitor shuts off.  Then the temperature sensor shuts off the gas when temperature limit is reached.  When the dryer cools down the gas cycle starts again (usually much more than 30 seconds).
May 29, 2009 | Dryers
Crate BX 160 bass amp. Has intermittent problems and shuts down
check your speakers cables for good condition-no touching between inner wires of each other- after you confirm from good cables condition- try the speakers one by one-make good ventilation around the amp and clean it with air blower-after that if the problem still found contact near service center for help.
Jan 20, 2009 | Audio Players & Recorders
882 people viewed this question
 Grubhead
Grubhead
