Question about Roper RAX4233PQ Top Load Washer
Roper washer Three weeks ago there was no hot water going into the washer. So I was washing with cold water only. Subsequently now no water is going into the washer. I have replaced the hoses which were corroded at the hot water junction to the washer but still not water goes in even though it is coming out from the hoses leading from the wall.
  • LUISA ANES Jun 28, 2007
    WHAT TYPE OF TOOLS WOULD I NEED TO GET THE BACK COVER OFF THE WASHER. I AM GOING TO ATTEMPT TO DO IT WITH MY SON. THE VALVE SEEMS TO BE PRETTY INEXPENSIVE. IT BEATS GETTING A NEW WASHER AT THE MOMENT SINCE I PURCHASED THE WASHER IN LATE 2003.
  • LUISA ANES Jul 03, 2007
    I had the water valve changed and I now get water through the machine. The problem now is that it is not washing in hot water for the white cycle. Only cold water comes in but in the 2nd cycle I get warm water and it feels like it is rinsing in hot water because the clothes come out warm as opposed to cold. The hot water line is attached to the hot water in the back of the machine.
    Novelist:
  • 159 Answers
Remove the 2 screws on the control panel and lift it to the back. disconnect the lid switch connector and use a flat blade screwdriver to remove the two clips that hold the cabinet to the rear pannel. tilt the cabinet tword the front and remove it. the valve is right there on the right on the back pannel held on by 1 1/4 screw. remove the water hoses then the white and red conectors and the screw and remove the valve. then replace it all back in the reverse and you should be set to go
Posted on Aug 04, 2007
    Novelist:
  • 114 Answers
I RECOMMEND A TECHNICIAN TO REPLACE YOUR SOLENOID. "IF IT IS THE SOLENOID OR STRAINER". FIND A REPUTABLE CONTRACTOR IN YOUR AREA THAT SERVICES YOUR BRAND. IT SOULD NOT BE OVER $75 FOR THE JOB AND YOU WILL HAVE A ONE YEAR WARRANTY.
Posted on Jul 03, 2007
  • Joseph Reckinger
    Joseph Reckinger Jul 15, 2007
    NEVER GREASE RUBBER WASHERS AND SEALS THAT ARE AT THE HOSE CONNECTION AN SOME SOLKENOID "SEATS"
    GREESE WILL DETERIORATE THE RUBBER AND CAN CLOG ORFICES.
  • 944 Answers
That corrosion has probably also occured in the solenoid valves that let water in or not (especially sounds like it if it happened over a period of time). You can probably clean them up a couple of times before they need replacing - get any mechanically minded person to do it and get them to grease them well. Couldn't find an inside layout diagram online, so I am guessing a bit, but they are usually easy enough to find - if you can get the back cover off or see up from the base, follow the two water hoses as they go into the washer. the first thing of any size they should come to is a thing that probably looks like a valve with a square plastic box in place of the handle. The box will be only connected by two wires up towards the control electronics. The bit that will need cleaning is most likely to be the part that the water goes through, but the electrical side can also corrode if wet, so is worth a check. (these are not too complicated inside). If you fancy doing it yourself then post me a couple of photos of what you have inside and I can try and talk you through it. If the solenoid valves need replacing, they are fairly standard so any washing machine shop should be able to get them, any problems please ask again and I can hopefully source some online for you. Hope this helps :)
Posted on Jun 28, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Jun 28, 2007
    Also worth doing a descale - easiest is to buy something from the store especially for this (there are many), or you can use vinegar in the liquid tray (no clothes).
    President:
  • 878 Answers
Lanes, you probably have a bad inlet valve, Remove the hoses at the washer and see if the valve screens are plugged. If they are ok, you will want to see if you have power at the valves. To do this you will have to remove the cabinet and test them with a meter. Remove the 2 screws behind the top consol, the consol will flip up. Remove the 2 snap springs and the cabinet will lift off forward. Jump out the lid switch harness and put the timer to fill. At the valves see if you have 120V with the timer pulled out. If not it would be a timer issue. If you have voltage and no fill, then it's the valve. Fill valve part number is 3955673. Catriver.
  • Ron Marek
    Ron Marek Jun 28, 2007
    You will have to get to the valve by removing the cabinet, not through the back of the washer. Much easier. Check out the pic. Catriver.
  • Ron Marek
    Ron Marek Jul 04, 2007
    Double check your water lines to the washer. If you are sure that they are correct, go back to the valve and check the harnesses. They may be reversed. There is no temp. control on this model. Just the timer and the valve. This should be a simple deal. You do have both hot and cold water lines hooked up I hope. Catriver.
SOURCE:
My roper washer stop during after the rinse cycle. Is their a reset button.
remove plug from wall is master reset. but its most likely a sensor or controller issue? get a service manual first.
Aug 21, 2015 | Roper Washing Machines
New roper wash. Mach. Will not fill on warm wash, but does on hot cycle
this could be a simple fix, where your hoses screw onto the back, ensure that there is a screened washer in place as your cold water is pushing the hot water back through the lines so the hot can't come through with the cold running as well, thats why it will only be hot or cold, scoot down to your white goods center and they will provide you with the correct washer screens for your unit, cost should be no more than about $3 a piece. good luck.
Oct 14, 2013 | Roper RAS8445KQ Top Load Washer
Roper washer model RAS8245EQ1 not working, buzzing noise
Her you'll find your answer..
http://www.appliancerepair.net/washing-machines-forward.html
Mar 08, 2013 | Roper Washing Machines
The cold water cycle is not working on my Roper washer top loader heavy duty
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
May 12, 2011 | Roper RAX4232KQ Top Load Washer
Brand new roper washing machine model # RTW4440VQ2 the cold water is very slow filling hot is fine
This model of washer has something called an Automatic Temperature Control. This means the washer puts water into the tub at specific tempreatures instead of just 100% cold, or 100% hot. Be sure and check that the hot and cold fill hoses are connected to the proper places on the back of the washer. It's possible that the ATC (mentioned above) is causing the washer to fill slowly on the cold setting.
May 20, 2010 | Washing Machines
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Roper washing machine mod# RAS8245EQ1
The problem is one of two parts. One is your water temperature switch or your hot water solinoid. To get to the back you must remove the hex screws on the back and then the panel is removeable.
Jan 27, 2008 | Roper RAS8445KQ Top Load Washer
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Cold water problem
more than likely that your inlet valve is faulty it needs replacing thats the more common fault for water not going into the machine
May 29, 2007 | Fisher and Paykel GWL11 Top Load Washer
Roper RAX4233PQ Top Load Washer Logo
95 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
