Question about Garden
Owners manual for eska sno flyer snow blower
Sno flyer snow blo
3 Suggested Answers
nickpower
  • 43 Answers
SOURCE: owners manual
Here is a link to find all manuals
ariens manuals
Posted on Dec 21, 2008
  • 133 Answers
SOURCE: I need the owners manual for an Ariens Snowblower
You might need to change the friction wheel. I looked up your model number and the part number for the friction disc is PN# 240394. You might be able to get the part locally from your small engine repair shop.
To replace the disc you will need to drain the oil and place some plastic over the gas tank and put the cap on so no gas will leak out. Then you will have tip the blower forward so it is setting on the augers.
Then remove the bolts on the access cover on underside . Once removed you will have to remove the wheel and see what else you will to remove. It is pretty easy to figure it out. If you have to take out the rod that moves the friction disc from side to side (gear shift rod) MAKE SURE IT IS IN PLACE AND WORKING BEFORE REASSEMBLING. Put in fresh oil and remove plastic. It should be up and running.
Good luck let me know if this helps.
roundo4
Posted on Aug 14, 2009
I have a Jacobson sno-burst snow blower? I need a megneto assembly part#126668 for a j-501st engine
can do an online search for part--notify a small motor --lawn and garden repair shop --
Dec 15, 2016 | Garden
Why sno thro continues to run after ice block is removed
Because that is how it's designed. It's designed to run again, after you remove ice block.
Apr 29, 2014 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
My snowblower run not good when i am not bloing snow
I suspect that it has old fuel in it - drain and replace with fresh fuel.
Mar 31, 2014 | Ariens 926054 Snow Blower 2 Stage 32 In
Looking to see what shear pin the sno trac snowblower model 310-680502
Go to www.doityouself.com Look under who makes sno trac snow blowers. The article tell you what to do.
Mar 19, 2014 | Craftsman 16" High Garden Tractor Snow and...
Auto drive malfunction
the drive wheel is worn out or tension on the wheel needs adjustment
Feb 05, 2014 | Sno-Tek Snow Blowers. 24 in. Two-Stage...
Engine chugging
carb dirty
clean and put fresh gas in it
Dec 18, 2013 | Sno-Tek Snow Blowers. 24 in. Two-Stage...
Auger does not engage on Ariens Model 924121 sno- Thro
first check shear pins in the auger ( try to turn big auger by hand, engine off)
then if they are good then try to turn impeller by hand, engine off
youll need to turn it a few times before the larger ones turn, but thats what you want
if they dont turn then you have sheared the gear box gears
be sure belts are good tooo
Dec 15, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
Auger shaft jamed
Try removing the belt and turning it by hand. If that doesn't work, you may have blown something into bits inside of the gear case.
Nov 03, 2013 | Ariens Snow Blower. Sno-Thro Deluxe Drift...
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Snow blower wont start
carb is probably gummed up from old fuel..take it off then clean it good and i bet it fires up
Feb 05, 2010 | RTO Sno Wovel wheeled snow shovel
Garden Logo
417 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
