Question about Indesit 24 in. IDL700 Built-In Dishwasher
INDESIT IDL705 machine stopped before draining and has not made any attempt since. initially displayed the 2 far left phase lights flashing. I managed to get rid of them by resetting & turning off & on a few times. it makes the right buzzing sounds now regarding pressing reset and no flashing lights but doesn't action anything at all.
  • MIKE BELL Aug 01, 2007
    Weedy 22w water pump was clogged/seized.
    Dismantled, cleaned claggy stuff & removed bone fragment.Lifted diaphram under impeller & cleaned/ lubricated with ipa.
    Job's a good-un!
  • Anonymous Mar 23, 2014
    THE MACHINE WILL NOT RESET
    Problem Solver:
  • 18 Answers
Sounds like an water inlet valve problem
Posted on Jul 12, 2007
SOURCE:
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
Indesit WIA121 Flashing Door Lock, Prewash and Spin Lights - Machine not draining
hi something similar has started happening to our washer, after the initial wash starts the machine doesn't do anything for a while then the red door light flashes on and off very quickly as does the 1st and 3rd green wash cycle light?
Jul 04, 2012 | Washing Machines
Indesit IDl705 flashing lights 1+2 during heating cycle and will not carry on. Have checked pump and all is fine, also checked float device.
If a machine cant do what its trying to do then it wont carry on. It will just sit there.
If its doing this while its supposed to be heating then my money is on the heater being at fault.
Oct 26, 2011 | Indesit W 123 Front Load Washer
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
Indesit wd12 (old) timer just goes round without stopping. door light flashes 9 times, help!
Hi, this is the list of the Indesit wd12 error codes...
Error codes and their meaning..
f01 light 4, motor triac f02 light 3 motor, jammed/ tacho f03 lights 3&4 Ntc fault f04 light 2. pressure sw stuck on empty f05 lights 2&4, pressure sw stuck on full f06 lights 2&3, N/A? f07 lights 2&3&4 heater relay f08 light 1. heater relay f09 lights 1&4 eprom/setup error f10 lights 1&3, pressure switch not sensing f11 lights 1&3&4, pump/draining error f12 lights 1&2, communication error f13 lights 1&2&4, dryer ntc/ fan motor f14 lights 1&2&3, dryer heater f15 lights 1&2&3&4, dryer heater relay f16 N/A f17 light 4, door lock f18 light 3 comms error (3 phase motor) power board
Door flashing 9 times means 1&4 eprom/setup error
Dec 20, 2010 | Washing Machines
Flashing star sign
Try turning off the breaker to it for a few min… and then turn it back on that might reset it.
Nov 07, 2007 | Indesit 24 in. DE73 Evolution...
Flashing lights indesit wil103
you will need to unplug the machine at the mains, give it two minutes and the auto door lock will release your duvet, however start saving the pennies as your pcb is knackered and you'll be looking at about £200 to fix it
Oct 25, 2007 | Indesit W 123 Front Load Washer
Indesit D167. When cycle selected no water pumping or filling but 1 & 2 green indicators on.
Tilt your dishwasher forwards. Be aware that water will come out ouf the bottom. Once this is clear your washer should be Ok.
Good Luck
Sep 23, 2007 | Indesit 24 in. DI67 Free-standing...
IDL705 dishwasher showing error code
Indesit IDL700 first two green lights flashing and cycle stops with dirty water left in the machine. CAUSE - blocked or jammed drain pump. SOLUTION - First remove all the filters inside the machine, syphon or sponge up all the water in the sump and check for any obstruction over the fine grill at the very bottom. (we had a pistachio shell covering the hole!). If this doesn't cue it you will need to gain access to the pump. First, turn off the power. Gently lift the machine onto it's side (be ready for some water to spill out!). Remove the bottom plate (6 screws) and disconnect the sump float switch. Remove the single screw retaining the pump to the bottom of the machine and rotate to remove. You should be able to see the rotor blades. With your finger check to see if the pump rotates freely. To dismantle the pump, remove the 3 screws and separate the two halves. Our pump was jammed with an apple stalk!. Reassemble and connect any cables. Apparently this is a known problem with these machines and can be prevented by assembling the filter system correctly and pre-rinsing plates etc. before placing in the dishwasher.
Sep 19, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit idl705
this sounds as though it is in "flood mode" and may have a water leak into the base. unplug unit and check for leaks by tipping the dishwasher at a 45degree angle backwards and seeing if any water seeps out from the base. if it does you have a hose/ pump / seal leak.
Jun 06, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Indesit 24 in. IDL700 Built-In Dishwasher Logo
376 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
Paul Bade
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
