Question about Vivitek V37655 56" DLP TV
Vivitech 56 DLP
I have a Vivitech 56 DLP TV I had the bulb replaced and now the color is gone and the picture is flickering.
  • 1 more comment
  • Anonymous Feb 25, 2009
    Dear Sir or Madam
    Please look at the video I attached to this e-mail my model number is " RP56HD21-A "
    S/N M529FMBR00139
    . After about 30 minuets it starts this colorless flashing effect.
    I called C S they could not under stand this condition. I cleaned ( vacuumed ) the interior components. It worked one night then it started again the next day.The video is in adobe photo shop album starter edition 3.2 The T V is 2 years old none of the LED lights flash the codes while this is happening .the lamp is 1 year old and work fine. I found two fans, one for the lamp and one for the heat sink in the picture generator
    component. can you tell me what you think is wrong.
    thank you
  • Anonymous Mar 06, 2009
    may tv flash every second
    my tv flash every second and then go 0ff
  • Jack Richard May 19, 2009
    I have a very similiar problem and Vivitek is no help what have you done with your tv.
    Problem Solver:
  • 5 Answers
I had a similar problem.
My TV started to flicker and I put a new bulb in. The new bulb did not help, even if ot is good to replace after a couple thousand hours.
I found out that mu heat sink, which is sitting on the CPU with the mirrors came loose and the unit overheated and shut off after flickering a while.
Try to take the lower back panel off and you see a heat sink which is sitting in the center of a aluminum sheet metal piece. Disconnect the wires which are attached to the circuit board behind the sheet metal. Then take off the screws holding the sheet metal and pull it gently off. It will take a little force, but it does not damage anything.
Now you see the heat sink on the circuit board heald by a latch going across the heat sink.
On the upper right corner you will find the handle to open the latch. Once you did it, you can take the heat sink off and see the main CPU (as I took the latch off, my heat sink fell off).
On my heat sink the Heat Sink Compound Paste creating the connection between the CPU and the heat sink dried out and became brittel, so there was no connection anymore and the couldn't be transported out through the heat sink, which is cooled by the fan sitting on the left.
I took the brittel Heat Sink Compound Paste off and applied a generous portion of the one that I bought at Radio Shack. I used Silicone-Base Heat Sink Compound which ran $4.99 excl. tax.
After applying the paste put the heat sink gently in and when you do, you will feel like a suction indicating that you have a connection between the CPU and the heat sink.
Now you need to put all parts back together.
If you are not familiar with electronics and those wires it wouldn't hurt or would be wise to mark the connectors and make pictures before removing them. This will save you a lot of frustration.
I hope this helps you and brings your TV back to live. My TV was cutting out after 25 minutes and runs now like a charme.
Good luck.
PS: If you experience a black screen with vertical stripes (mine were white and green) then most likely the light engine needs to be replaced, I had this after 9 months and got this fixed under warranty.
Posted on Jul 04, 2009
Hi I had same prob. after trying a bunch of things we took off the back of the tv and lightly sprayed can air into the color wheel area ( where the bulb faces) I used the long stick for the air can and put it near (not in ) the silver holes. I saw a piece of dust come out and tv is now fine. I think something gets in and blocks the color. I figured it out when I turned on tv ( after problems) and was trying to see if the lamp was going to blow (dumb yes) but when the tv light on the screen lit up (the one that tells you what channel you are on etc...) it went blue, it had always been green. That is why I thought the color area and sure enough!! I am elated to have fixed it. Hope it helps. Be careful though barely push the spray. The dust flew downward so maybe you could tilt can that way before you spray.
Posted on Mar 05, 2009
I have a Vivitek RP51HD41-A TV. The TV keeps turning off and on. The color and sound is fine. I have replaced the lamp and this has not fixed the problem.
If its a DLP it may have a color wheel which could be your problem (the colors will change etc)
Color wheels move at high speed and if slow down set will shut down.
The wheel if there will face the lamp. If often if failing will make a high pitched whine or a fan like sound.
May 29, 2012 | Vivitek V37655 56" DLP TV
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Have a dlp samsung HLT6176S no picture already replaced the bulb still no picture what gives
Remove the lamp and look at the color wheel that faces it.
If wheel is shattered or missing pieces set will know it is not moving or moving too slow and shut set and lamp off.
Not all color wheels when fail make a sound
May 06, 2012 | Samsung DLP HL-P5663W 56" TV
My samsung dlp lost it's color and the picture is flickering and breaking up sound is fine It's also making a louder humming sound than usual. what is the problem
It sounds like the color wheel has failed and will need to be replaced. Color wheel will cost around $175.00-$200.00 plus 1-1.5 hours labor. You can call 1-800-samsung for the nearest service center.
Aug 06, 2010 | Samsung DLP HL-P5663W 56" TV
Replaced the lamp bulb on my samsung HLP5663. It went on right away. Though the problem was fixed. Turned the tv on a little while ago and the picture is gone. The timer light is blinking. Any ideas what's...
Now tv turn on.Hear alots of clicking or squiling,loud motor noises turn on?Alot of clicking,the Ballast board it dead,this board help ignite the projection lamp.Tv also have a colors wheels.The colors wheel is dead,if hear squiling noises,loud motor noises.
Jul 14, 2010 | Samsung DLP HL-P5663W 56" TV
I have a Samsung 50 inch DLP - I heard a pop and the picture immediately disappeared. The 3 lights were flashing on the front which according to the book said it needed a new lamp installed. I ordered it,...
Sounds like the color wheel may have also gone bad. I recently saw a 56" Samsung where the bulb and color wheel went at the same time. The color wheel could produce a crying noise while trying to spin up.
May 05, 2009 | Samsung DLP HL-P5663W 56" TV
VIVITECH
56 inch vivitek screen blured and hard to see replaced bulb twice
Oct 22, 2008 | Vivitek V37835 46 in. LCD Television
SAMSUNG HD DLP HLN5065 50" TV
The problem of your DLP TV is a defected color wheel,replaced that so it will works normal again.
Hope it may help you;
Regards,
VOTIT
Sep 22, 2008 | Samsung DLP HL-P5663W 56" TV
Vivitek V37655 56" DLP TV Logo
467 people viewed this question
Top Vivitek Televison & Video Experts
Jim Goldsmith
Jim Goldsmith
matt martin
matt martin
Are you a Vivitek Televison and Video Expert? Answer questions, earn points and help others
