I have a kinyo multimedia speaker system model ps-36 output 5watts empedence is 4ohms I lost power cord.I have other cords but I do not no or can find voltage in on the speakers.can u let me know what voltage in is out of the cord fo speakers? A
SOURCE: Lost ac power supply adaptor for Mli 190 speakers
http://an-labs.com/multi/sw190.html 12vac
Posted on Jan 22, 2007
  • 22 Answers
SOURCE: need a replacement power cord for harmon kardon sound sticks II
its not that expensive for a power cord. they are running on 12v so you go and buy a 12v power supply with a jack that fits the speakers or you can just find a power supply at home if you have one that is 12v
Posted on Jan 06, 2009
SOURCE: Need the specs on adapter for JUSTer dc-691p speakers.....
Model: PPI-0930-UL
INPUT: AC 120V 60Hz
OUTPUT: DC 9V 300mA
Polarity: Neg.outside, Pos.inside
Posted on May 19, 2009
bob_computer
  • 3153 Answers
SOURCE: i have kinyo model ps-107 speakers with no down
You do not require a disc. plug the green plug into the green socket on the rear of your computer.
Posted on Aug 26, 2009
SOURCE: adapter/power supply cord missing emachine model SP 30A speakers
AC/DC Adapter
Model MA-9200
Input 120 VAC 60 Hz
Output 9 VAC 200 Ma
Class 2 Transformer
Posted on Jan 14, 2010
Channel multimedia speaker system
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fdocs.ts.fujitsu.com%2Fdl.aspx%3Fid%3D8515c87b-d9de-4b4f-8ab9-d60175717876&ei=LCVuU8WSBIiYyAT7_YBg&usg=AFQjCNGfuWC6xiGAcZr9Dsm0N3fMXPvSlw&sig2=mwq7IL9yo5Qym3p4ngqHJw&bvm=bv.66330100,d.aWw
May 03, 2014 | Fujitsu Siemens Computers & Internet
Kinyo ps-56 ac adapter
My kinyo ps-56 works in 7,5 v.
Hope helps
Apr 04, 2013 | Kinyo In Box 2 Ps-56 Multimedia Speaker...
How to connect speaker into my computer.
Speakers generally have a cord with a usb plug on the end for power and another cord with a male audio jack (it should be green) for receiving the sound from the computer. On your computer tower there should be terminals for both. These are located on the back, front, or both depending on computer model. Connect each wire to its respective terminal. If possible you should connect them from behind because it creates less of a mess around your desktop.
Aug 25, 2011 | Kinyo Audio Players & Recorders
Power cord not working that supplies power to the speakers
try to repair it or get it fix from a electrician...
better bpurchase new
Dec 11, 2010 | Kinyo 3-Piece Subwoofer Flat-Panel Speaker...
Appropriate voltage for PS-57
Speakers don't use a voltage level to determine their usage- they use an "ohms" rating, like 4 ohms or 8 ohms. Ohms is written as an omega symbol. You have to match the ohms rated output of the computer to the speakers, or you can either blow the speakers up, or overload your amplifier and burn something up (usually a transistor). The power rating is also used to match components (expressed in watts, or the letter W). You can use a higher power rated speaker with a lower power rated amplifier, but you have to be careful of the opposite case. At some point at the upper end of the volume knob, you will draw too much current and blow the amplifier. Most people do this because it used to be that loud, etc., but in reality, you will never get the same volume with a lower power rated speaker system, and trying to will jepeordize your amplifier. I searched the net, but noone had any technical info on them, but I did see some pictures. My guess is that they're 8 ohm speakers with a very high power rating. Just make sure your amplifier is rated 8 ohms too, good luck! (P.S. if you're amplifier is rated 4 ohms on the output, I would recommend getting an 8 ohm output amplifier on ebay, in the event the speakers are 8 ohms) Hope this helps.
May 04, 2010 | Kinyo PS-205 Computer Speakers
I have lost the power cord and would like to know the replacement price
you dot necesarily need to buy a replacement, these power cords are universal and you should be able to use any other power chord from even a completely different device. PLEASE NOTE THAT THE VOLTAGE OF THE POWER CHORD MUST MATCH THE VOLTAGE OF THE SPEAKERS
Oct 08, 2009 | Kinyo SW-7352 Computer Speakers
I have kinyo model ps-107 speakers with no down load disc. how do i get them to work on my computer?
Aug 26, 2009 | Kinyo PS-107 Computer Speakers
Speakers
The Boston Acoustics power supply that came with Model 7000596 speakers is rated:
Input 120VAC 60HZ 23VA
Output 12VAC 1500mA (1.5A)
The PS model number is WK1201A5-1AN
Dec 28, 2008 | Boston Acoustics MicroMedia Computer...
I lost the power cord to my Panasonic SB-WA920 Subwoofer
partstore.com or panisonicpartstore.com will have any cord you need for a panisonic just have your model # ready
Nov 28, 2008 | Panasonic SC-HT920 System
 Grubhead
Grubhead
