Question about Apple M8536 23" LCD Monitor
M8536 Display not allowing computer to boot, black screen with blinking powerlight, 2 short one long then long pause and cycles again
  • notrude Jan 20, 2009
    no, I've made no changes. I had a 20" and the 23" running together with no problems, considered using just the 20" and sellling the 20, so I disconnected it, couple of days later hooked it up again with the computer powered down that's when problem arose.
    Genius:
  • Apple Master
  • 1,102 Answers
Have you updated or changed anything recently
Posted on Jan 20, 2009
  • DEKR
    DEKR Jan 20, 2009
    okay have you made sure you plugged it in properly
    do you have a motherboard cd
    if not thats okay
Insignia ns-55l260a13 does not power on. Power led blinks 5 shorts, pause, 2 shorts and stays on. Screen blinks and nothing else happens afterwards.
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Nov 23, 2016 | Ideal Sales New Insigniatm - 55 Class -...
Toshiba no powerlight when pressed just loops and power light and keyboard blinking light
very likely your video chip is gone. This is a motherboard issue. You have to take it to a local computer store to fix. the might have to reset your computer video chip.
Dec 30, 2013 | Toshiba Satellite A135-S2276 Notebook
My 23" Apple cinema display (2002) has black screen and code flashes three short flashes. How do I find out if the monitor is dead or the power supply?
The only way to test is to use a known working power supply or known working cinema display with the parts you already have.
Dec 11, 2012 | Apple Cinema Display 23" HD Monitor
No disiplay on the screen of the laptop and on the external monitor
No display on either? Does it sound like the computer completed the boot cycle? Do you hear fans running and the hard drive spinning?
What happens when you hit the power button? Do you hear any beeps or see any blinking lights? Does anything post to the screen during the boot cycle?
If the boot cycle completed and you see no display on either monitor, then your video card is bad.
Apr 09, 2012 | Acer Extensa 5630-6806 Notebook
Display on dell d 610 wont turn on
Display won't turn on? You mean the screen is blank? If so it can be that the lcd screen is bad, the lcd inverter is bad or the vga video card is bad. You can narrow down the problem by plugging in an external monitor into the laptop then press FN+F8 keys to get the display on the external monitor. If it shows on the external that means the video card is ok. If the video is ok remove the external monitor and reboot again. Use a flashlight and shine it on the display if you can bearly see the icons in the background, that means the lcd inverter is bad and needs to be replaced. If you see nothing and the computer has booted up, the fans are running the lights on the right under the lcd shows the disk blinking and the powerlight is on, then you probably have a motherboard issue. Contact the guys at: http://www.generalsystemsconsulting.com
They will fix it and return ship it by Fedex or UPS. Get a quote a your local computer shop, then call them
Mar 10, 2012 | Computers & Internet
When I turn my Sony E55A20 on the fan kicks on in the back but there is no picture or sound. The green powerlight blinks about 100 times and then goes to solid green but still nothing.
Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
Mar 04, 2011 | Sony KDF-E55A20 55 in. LCD Television
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Green light comes on then goes right back off.
The TV indicates an error code 22 (short circuit protection). Check 2 STK392-570 convergence IC for shorts and 5amps pico fuse for open. I usually replace both STK's.
Dec 25, 2009 | Televison & Video
Hello
What that means is that the set doesnt recognize any shutdown error if it does 1blink short pause the 2 blinks, but if it does 2 blinks short pause the 1 blink thats an error code. can you dtermine which sereies of blinks it is?
Apr 07, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Toshiba Satellite A55-s1066 wont boot
Check out this Toshiba document - http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=kc&externalId=571487xml&sliceId=&dialogID=19454183&stateId=0%200%2019450573 Look about half way down the document to the section that starts with: * If the AC power light is blinking, try the following steps:... See if any of those suggestions help.
Sep 17, 2007 | Toshiba Satellite A55-S1066 Notebook
Computers & Internet Logo
411 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
