Question about Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw: DW7881 Worklight
I have a 20'' dewalt scroll saw that will not start
The saw has been setting for about 12 months, was working fine, took it down to use it and get no results when I hit the switch. I get voltage out of the switch , the motor is free, brushes look fine. Any ideas would be appreciated
  • 3 more comments
  • geoschmidt Feb 17, 2009
    Saw seemed to lock up. Moving arm up and down fixed problem temporarily but now won't move at all.
  • budgetboy1 Feb 20, 2009
    same thing checked everything out and hear motor hum, but no movement.
  • Anonymous Feb 22, 2009
    plug it in.
  • Anonymous Mar 11, 2009
    Same here, the saw action is stiff; blew fuse, now won't run after replacing fuse.
  • Anonymous Apr 17, 2009
    turned it off when went back to use a little later the saw would not turn on.
    Problem Solver:
  • 12 Answers
If you are getting voltage then it is most likely the control board. You would need to take it into a repair service center and they would have to pull the whole thing down to repair.
Posted on Feb 25, 2009
Dewalt Scroll saw. Suddenly I can barely get a piece of 2 inch stock (actual 1 1/2) under the hold down.
I know this sounds patronizing, but have you cleaned it and made sure no wood shavings are clogging anything up. Also my husband sharpens his teeth with a special little file, I am talking about his chainsaw but its still a saw, one more thing, does it need oil? I hope something helps if not, sorry I am only trying to offer solutions!
Mar 26, 2015 | Dewalt Dw788pk 20-inch Scroll Saw With...
Does my 20" DeWalt scroll saw have a reset switch?
check if there is a reset on the motor..usually push to reset.
Jul 29, 2014 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Where are the brushes in the dewalt 788 20" scroll saw? Mine keeps blowing fuses & I think the brushes need cleaned but don't know how to get to them
Blowing fuses is not caused by brushes unless there is a huge spark show going on and if that is the case your armature will be trashed as well - the electronic module in that saw is notorious for failure and that is where I would start
Nov 23, 2013 | Dewalt DW788 Heavy Duty 20" Variable Speed...
I don't use my dewalt table saw during the winter. It is kept in a dry place. The top still shows rust. What can I do to stop the rust?
The best thing I've found to seal saw table tops is a good car wax. It keeps the rust down and is great to keep your work sliding easily on the top and won't stain your wood like oil based coatings would.
Aug 27, 2012 | Dewalt DW788 Heavy Duty 20" Variable Speed...
How to install air hose on dw780 scroll saw
To get the plastic hose in:
Hammer in one or two of the plastic joints from the plastic hose with a rubber mallet to build the foundation to the metal connector.
Once you get the plastic foundation joints into the Dewalt Scroll Saw. It's easy to add rest of the plastic hose in.
Jan 24, 2011 | Dewalt DW788 Heavy Duty 20" Variable Speed...
I lost my manual to my Dewalt DW788 Scroll saw. Could I get another one sent to me.
he-manuals.com/dewalt-dw788-manual/ -
this should get you back on track
good luck
May 15, 2010 | Dewalt DW788 Heavy Duty 20" Variable Speed...
No power it just died, what could be the problem? We tried other outlets and it still won't work.
CHECK FOR ANY BREAKS OR WEAR IN CORD , IF NONE IT MAY BE THE CARBON BRUSHES ARE WORN OUT .
Oct 28, 2009 | Dewalt DW788 Heavy Duty 20" Variable Speed...
Dewalt DW788 Heavy Duty 20" Variable Speed Scroll Saw:  DW7881 Worklight Logo
672 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
