Question about Health & Beauty
Tefal evolis error 109 how to solve?
After three months using the bathroom scale Tefal Evolis, it shows in the displays the number 109.
5 Suggested Answers
SOURCE: HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Posted on Oct 05, 2009
Testimonial: "The new scale works great and was on sale at Wal-mart for only $29."
SOURCE: We have a Taylor 7542 Bathroom Scale. I need to
I called Taylor; the Model 7542 take a 3v CR2032 battery available at Walgreen's, CVS, WalMart, etc.
Posted on Jun 29, 2009
SOURCE: Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Posted on Oct 18, 2009
  • 5 Answers
SOURCE: Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Posted on Mar 26, 2010
I have a tefal family actifry and a green error flashed up and a long alarm. What is this telling me?
Tefal Actifry GH800215 user manuals GH800215
www.tefal.com/instructions.../Fryer/Actifry/Actifry.../1500634805
TefalThe Actifry Plus GH800015, GH800215 deep fryer allows you to make 1.2 kg of chips with only 1 ... To display Instructions & Manual, choose your language :.
Apr 13, 2013 | Tefal ActiFry Deep Fryer
I have an Evolis Pebble 4. For each card printed, a white thin streak appears. This streak cuts through the entire card.
Try cleaning your printer first using the Evolis A5011 Cleaning Kit. If the line is solid and goes across the length of the card, you might have a burned/damaged pixel. Check with Evolis or your Evolis Card Printer supplier for warranty information, your printhead might still be under warranty.
-- The Pros at www.DiscountIDStore.com
Aug 28, 2011 | Evolis Pebble Color Card Printer
Evolis pebble doesn't printer after standby
Just do one thing . Check the selection ports tab. Change it Apply it and again change it to original value and apply . This should solve problem. Also check if printer becomes offline. .
May 18, 2011 | Evolis Pebble Color Card Printer
At the moment blank cards are not feed into the printer. The cards are always been jammed and the 3 lights are displaying a MechanicalProblem. I would be extremely happy if you can advise me on how...
You may try cleaning all Rollers including feeder roller.
To move rollers just remove ribbon , feeder and press front panel button and keep it pressed with top cover open . All Rollers will start moving and you can clean them easily using cleaning kit.
Also check for thickness adjustment pointer.
Oct 12, 2010 | Evolis Pebble 3 ID Card Printer Package...
I have problem with my Evolis Peb3le. For a long time (+- 3 years) ago, i use ribbon with S/N: RP011IPS, and it's running good. But, now, i can't get that ribbon with S/N: RP011IPS, YMCKO, i just only...
Just check for the ribbon type setting in driver . It may be required to be corrected . Also try downloading new firmware from Evolis site for Pebble3.
Sep 19, 2010 | Evolis Pebble Color Card Printer
My Evolis Pebble 3 ink ribbon breaks after I print 2 cards.
First clean Rollers and print head . Check if you have increased luminosity and contrast too much in printer Graphic properties. If this doesn't solves your problem increase x offset little bit using Px;+ command in Dialog with printer
Aug 04, 2010 | Evolis Pebble Color Card Printer
Printing Problem
Use color ribbon and set ribbon type in properties
Feb 17, 2010 | Evolis Pebble Color Card Printer
I need descaling instructions for Tefal Ultraglide easycord55...Mislaid instruction booklet....Thank you
thank you solved de scale instructions for Tefal Ultraglide easycord 55, found manual on net....
Jan 09, 2010 | Tefal UltraGlide Easycord FV4256 Iron
Evolis pebble 3 displays mechanical problem error?
Clean all rollers
Check if print head is mounted properly
May 27, 2009 | Evolis Pebble 3 ID Card Printer Package...
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
Health & Beauty Logo
1,178 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
