Question about Hotpoint Washing Machines
Hotpoint wmf720 code error f06
Code error f 06
catriver
  • 878 Answers
SOURCE: Het3 Washer - F06 Code
dragon, drop the bottom panel by removing the 3 screws on the bottom, pull down and off. On the right side attached to the bottom of the door switch (on the inside) is a teardrop release tab. Pull down on it and the door will open. The F06 code is a motor tachometer error. The control is unable to detect the motor speed. While you have the panel off, check the harness that goes from the motor to the motor control board. The motor control board is the one on the bottom. Reseat the harness's for a good connection. If you can use a meter, check the motor windings, pins 1 to 2, 2 to 3 and 1 to 3 should read approx 6 ohms. Next, take the top off the washer by removing the 3 screws in back and sliding the top off toward the back. The main control board is in back. Make sure all the harness's are seated good. The third harnes from the right is the motor control power, reseat it. On the left side of the board, last harness toward the back is the serial communication link. Reseat it. On the motor control board on the bottom the communication link is the one toward the bottom, the center one is the motor connector and the top one is the power supply. If this doesn't solve the problem and your motor ohms out. I would tend to believe that the motor control board is the problem. Catriver..post back.
Posted on May 27, 2007
Benimur
  • 6966 Answers
SOURCE: whirlpool front load washer GHW9100LW
Appreciate the "Ask Me".
My compliments that you have determined that error code F06 indicates drive motor tach error. This relates to the controller board not sensing that the motor is spinning. This could be attributed to three (3) possibilities:
  • motor is not really turning/stuck, a replacement is required;
  • motor is turning but the sensor attached to it is defective and therefore not sending signals to the controller board. Pls check the terminals/connectors/wirings; and/or
  • the controller board input circuitry is defective. It does not register any input from the motor's RPM sensor. This could be a diode, resistor or logic IC. This would be component level repair requiring familiarity with electronic circuitry and components, use of a DVM and a soldering iron. It wold be easier to replace the entire controller board..
In some instances, it could just be the motor's capacitor that is defective. The capacitor provides the initial kick for the motor to start running. Failure on the capacitor will not kick start hence motor will not start hence RPM sensor says to controller board motor not running.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 16, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
  • 1525 Answers
SOURCE: error code f06
hello fo6 means drive motor techometer error check wire harness connections between the drive good luck
shaun
Posted on Mar 22, 2009
jsrock516
  • 5911 Answers
SOURCE: F06 Error Code
"F06" is a Motor Speed Error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
Read through the link provided and let me know if you have questions. In most cases this problem is attributed to a tachometer failure on the Motor Control Unit (MCU). If the this is the case, the MCU must be replaced.
If you require additional assistance, let me know. I hope you find this information helpful.
Posted on Sep 11, 2009
Where is the pressure switch located on a hotpoint WMF720
SHOULD BE ON LEFT SIDE OF MACHINE IN THE PANEL ON TOP? ITS A ROUND PC WITH A PLASTIC TUBE RUNNING INTO IT
Aug 11, 2014 | Hotpoint Washing Machines
At end of washing error code flashesf06
Hotpoint uses different error codes for different models. Can you post your model number?
Jul 25, 2014 | Hotpoint Washing Machines
Im getting error code f-06 what does this mean?
sorry but f-06 is not coming up as an error code for this model, if you can post up the full model number or product number illlook into it again
May 23, 2012 | Hotpoint Washing Machines
Repair Manual GHW9400Pl1 Error code F06
F/06 error code, Drive Motor Tachometer Error. I checked the manual which states to check wire harness, check drive motor, check MCU. Checked wire harness from motor to MCU and MCU to CCU.
May 29, 2011 | Whirlpool Washing Machines
Washing machine is flashing F-06 do you know wot it means please
F06 is Program selector error.Need to call a technician for this
Thank You
Sep 10, 2010 | Hotpoint Washing Machines
Servise code f 06
"F06" is a Motor Speed error code. The following link explains how to troubleshoot:
Read through the link provided and verify all your wiring and connections, first. Sometimes the problem is as simple as a loose plug. Make sure resistance checks are done with the washer unplugged. If you have any questions, please let me know. I hope this helps you.
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
F-06 error code
ck all wiring connections from motor to motor control to main control on top rear rail f06 means main control can't detect motor speed when you say mcu i assume you mean the motor control bd next to motor they and the motor both have given very few problems in our area i suspect the ccu (central control unit) is the most likely cause
Sep 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
97 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
