Question about Moen Plumbing
Moen annabelle pull down faucet has lower water flow than old faucet
Installed this faucet yesterday. It has noticeably less water flow than the previous faucet I just removed. What is restricting water flow and how do I fix this?
dragonsthatk
  • 547 Answers
SOURCE: Moen Tub Faucet.. Water won't stop running.
change the washers first if that don't work change the inserts buy all at same time and return if not needed . Thank you for useing fixya please rate me
Posted on Feb 26, 2009
SOURCE: need to fix a broken moen kitchen faucet
I had the same problem with my Aberdeen single lever with a pull-out sprayer a few months back. If you are the original owner of the faucet, it's under warranty; you shouldn't have to pay for any parts. Call: 1-800-BUY-MOEN (1-800-289-6636) and tell Customer Service what the problem is. They will send you the Handle Mechanism Kit at no charge. (Mine was part #93980 for my Aberdeen faucet, but yours may be a different part number.) It's tricky to take apart and get back together but my husband and I have zero plumbing experience and got it all fixed in about 20 minutes. The Moen.com website also has exploded parts diagrams of all their faucets so you can identify exactly what part you need, and they have some little videos and slideshows to show how to replace parts. If you can't reach Customer Service on the phone, you can go to "Contact Us" on their website and email them a description of your problem.
Posted on Jun 18, 2009
  • 82 Answers
SOURCE: moen T2113 shower faucet no hot water
You need to replace the stem. This will not cost you a dime; call MOEN and tell them the issue, with the model number, and they will send the replacement part. Many people don't know that MOEN is guaranteed for life (to the original owner)......another words, say you are the original owner :) They will not ask any questions. Good luck! PS Also works on any MOEN faucets you may have.
Posted on Sep 03, 2009
  • 122 Answers
SOURCE: How do I remove the aerator on a moen pull out
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Posted on Jan 28, 2010
SOURCE: removing an old moen bathroom faucet
i have a moen monticello bathroom faucet that is about 12 years old. I cannot figure out how to get it apart???????
Help me, help me!!!!!!!!!!!!!!!
Posted on Feb 20, 2010
Just bought 4 moen Oxbridge bathroom sink faucets. Water pressure is very low compared to old faucets. Checked the aerator but no adjustment is available. New shower head is the same issue.
These days, you may find a disk with a small hole intended to restrict flow. It may be installed above the aerator. Check the flow with aerator removed.
Aug 13, 2017 | Moen Plumbing
We have a moen 7594E. Lower water pressure than old standard Moen.
The pull out spout/spray has backflow preventers built into the hot and cold supply lines coming from the body of the faucet. The backflows have a tendency to lower the flow rate because of the additional restriction they cause.
Mar 07, 2017 | Moen Plumbing
What size allen wrench do I need to tighten a moen (annabelle) single handle kitchen faucet?
google manufacture or go topumbing supplier and they should help you
Mar 02, 2015 | Moen Plumbing
How to put a moen faucet back together 7185 annabelle
Moen will supply that info on their website or will send you instructions if you ask for help.
Oct 05, 2014 | Plumbing
Need more water flow on a moen haysfield kitchen faucet
have you tried checking to see if the screen is blocked. I installed one and that was the issue. it should just screw off right where the water comes out.
Mar 14, 2014 | Moen 87877SRS Haysfield Spot Resist One -...
Moen faucet
Most dont need that amount of pressure of flow. There is a reducer in it for restriction to reduce water waste
May 04, 2013 | Moen Plumbing
Moen annabelle faucet handle fell off
1st put the DOME cap on by rotating it 180 degrees, to go OVER the white plastic gasket, then press on. Then you have to get that plastic square knob inside the dome, in a downward postition, thus TURNING the WATER ON, to work the handle back in place. Put the set screw on with an (tiny) allen stick wrenchy thingy.
Mar 22, 2012 | Moen 7310 Legend Single-Handle Kitchen...
My moen vestage faucet is dropping water pressure. It worked fine when it was installed but the water volume out of the faucet has dropped to less than half of what it was.
Have you removed aerator ,screen etc., from end of tap, to see how flow is with it off. If good, or same as other taps when taken off of them, then you've got debris in aerator, and screen.
Jan 03, 2010 | Moen 7065 Vestige Single-Handle Kitchen...
Plumbing Logo
98 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
