Question about Dryers
Whirlpool dryer wed6200sw1 makes a squealing noise
SOURCE: GE Dryer model#DWSR483EA1WW
you need to replace the inner plastic "shell" and the teflon pieces that the drum rides on. The dryer drum has eaten thru the teflon slides, and has probably started eating the shell away also.
About $40 in parts available on line will fix the problem.
Posted on Jun 21, 2008
jonniewalker
  • 1031 Answers
SOURCE: whirlpool dryer drum making noise
window.google_render_ad();There are many places & parts that could be causing your Whirlpool dryer to be noisy. To find out what is causing the noises, you need to find out where are the noises coming from.
Start the dryer and let it run for a while and listen to try to pinpoint where in the dryer the noises is coming from. Once you have an idea of the area, you will need to disconnect the dryer from the wall outlet and take the dryer apart.
Below you will find the parts that you need to check when your dryer is noisy.
The drum baffles:
The drum baffles are use to tumble the clothes inside of the drum, in other words, the baffles job is to separate the pieces of laundry as the drum turns.
When the dryer is getting older and if you use the dryer a lot, the drum baffles holding screws will become loose. Loose drum baffles will cause noises. All you need to do, is to open the top panel and tighten the drum baffles holding screws.
The drum support rollers:
These dryers uses four drum support rollers, tow on the front and two on the rear. The job of the drum support rollers is to keep the drum tumbling smooth.
When the grease on one of the rollers dry out, the roller start to make squeaking noises and the roller bearing will start to wear out until the bearing on the roller is gone. When the bearing on the roller is gone, the noise will change from squeaking to a clanking noise.
The blower wheel:
The blower wheel is use to circulate the air inside of the dryer drum. The most common Whirlpool blower noises are cause by something falling inside of the blower housing and hitting the blower when the motor runs.
The Idler pulley:
The Idler pulley is use to apply the necessary tension on the belt. There are two types of idler pulleys, the pulley with the wheel and the pulley with the teflon slide. A bad idler pulley could cause a Whirlpool dryer to be noisy.
The drive motor:
Worn out bearings on the motor will cause the motor to run kind of noisy. When the motor starts making noises, the solution to this problem is to replace the motor.
The belt:
The belt on most dryers is only about1/4 inch wide. These belts work very hard making the drum tumble. When the belt stretch just 1/2 inch more that it supposed to, the belt will start slipping and that could cause your Whirlpool dryer to be noisy.
As you could see, there are a lot of parts that could become noisy in your dryer. When your dryer starts making noises, make sure to check it out before it gets worse.
Posted on Feb 09, 2009
  • 69 Answers
SOURCE: my whirlpool cabrio electric dryer makes grinding noise
could be a bearing gone
Posted on Mar 27, 2010
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
How do I remove door switch from Whirlpool Cabrio WED6200SW1.
This video is for a noise issue, but does show how to open one of those dryers, hope it helps:
Jan 23, 2017 | Whirlpool Dryers
Clicking noise in blower wheel area
Remove the rear cover and get the filter chute off there. Clean her up. This dryer is no different than other dryers with filter in the top.
Cabrio service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 23, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
WED6200SW1 TURNS ON BUT WON'T START.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Whirlpool Dryers
Whirlpool WED6200SW1 Door not shutting properly, please help.
You will need to replace the door latch and catch assembly. CLICK HERE for the updated kit that will make your door close easier. Using coupon code 1050 will save you some money!
Jan 12, 2011 | Whirlpool WED6200S Electric Dryer
Really loud whirring/squealing noise
Yes, It is still safe but very annoying...
The source is probably the guide rollers for the drum or the belt tensioner pulley. To know for sure you will need to pull the dryer apart and turn it by hand slowly and see where the noise is coming from...
Heatman101
Mar 03, 2010 | Whirlpool Dryers
My Whirlpool Gold dryer makes a high-pitched squealing noise for about 5 minutes when first turned on, then stops and dryer continues cycle. The noise doesn't sound like metal on metal but more like a...
CHECK BELT,TENCHEN ARM (KEEPS BELT SNUG),ALSO ROLLER WHEELS...
SOMETHING IS GOING BAD BUT ONCE IT WARMS UP IT STOPS MAKING NOISE.
YOU NEED TO FIND THE PROBLEM BEFORE IT BREAK DOWN???
LATER FREDDY
Feb 11, 2010 | Whirlpool Dryers
Whirlpool Dryer squeals
Either the drum is rubbing against something or more likely the belt pulley is cause the noise. Oil the pulley wheel and the drum rollers and it should stop squealing.
Dec 14, 2009 | Dryers
MAKING SQUEALING NOISE
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fgsj
Oct 19, 2009 | Whirlpool GGW9250PL Gas Dryer
Squealing noise
heatman101
98f
Jun 27, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Dryers Logo
302 people viewed this question
Top Dryers Experts
