Question about SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW)
Cannot transfer pictures to smart parts digital frame thru usb
Comp recognizes the connection and the removable disk icons show up but it will not let my do anyhting in those disk folders
  • emccarson Jan 20, 2009
    there is no no lock that I can find and not using a external memory card just the internal memory of the frame itself.
    Problem Solver:
  • 7 Answers
Ensure that neither the memory card or the frame have a lock on them that will disable the transfer of any files. If there is a lock it will allow you to browse through the directories but will not allow you to alter them in any way. Windows may also post a "right protection" error when trying to do so.
Posted on Jan 20, 2009
How do i download pictures to tablet
Pandigital photo frames are an ideal way to display your collection of digital photos. You can view photos with or without a computer using just a memory card, but it's always a good idea to transfer the photos you'll want to view frequently to the internal memory of your frame. This is also a handy way to back up your favorite images.
  1. Transferring Photos from a Memory Card
    • Your digital photo frame's built-in software will recognize six types of memory card: CF I/II, SD, MS Pro, MMC and XD. Locate the slot on the back of the frame (to the left of the stand) that corresponds with your type of memory card. These are labeled as follows: SD/MMC/MSPro/XD, CF I/II, USB and mini USB. Insert your memory card into the appropriate slot, power on your digital frame, and it will automatically begin a slideshow using every available image on your memory card. Note that only JPEG formats under 16 megapixels are compatible.
    Transferring Photos from a PC
    • Use the USB cable that came with your frame. Connect the mini USB end to the mini USB port on the back of your frame; connect the large USB end to your computer's USB port. Double-click the "My Computer" icon on your desktop or in your Windows "Start" menu. You'll see that your computer has automatically assigned a drive to your digital frame---look for a device called "Removable Disk" followed by a letter (Removable Disk E:, for example). This is the folder that represents the internal memory of your digital photo frame; you will be dragging your photos into this folder.
      Next, open the folder in which you store your photos ("My Pictures," for example). Select the photos you want to transfer to your frame. Drag them to the drive associated with your digital photo frame---this is the "Removable Disk" drive you located within the "My Computer" folder. Every photo you selected will then be copied onto your digital frame.
      After the files are copied, disconnect your digital frame properly. If you don't, your frame's internal memory could be damaged. Look for the system tray in your desktop's lower right-hand corner. Left-click the icon that shows a gray box with a green arrow on top of it. Select "Safely Disconnect Hardware." A dialog box will appear, asking you to select the device to disconnect. Select the digital frame and click "OK." When the dialog box appears, click "Close." You'll see a message in the lower right hand portion of your desktop telling you it's safe to disconnect your frame.
    Copying Photos to Your Frame's Internal Memory
    • You can use your frame's remote control to copy photos from your memory card or computer to the photo frame's internal memory. Connect your photo source (computer or memory card) and have your frame's remote control handy. Access the "Home" screen on your frame using the "Home" button on your remote control or by pressing the "Home" button on top of the frame. Next, choose "Photos" and press "Enter." You'll see all your photos in thumbnail form. Scroll through them with the up and down arrows. Press the "+" key to mark photos you want to copy (use "-" to de-select a photo). When you've selected all the photos you want to copy, press "Set Up," then "Copy Photo," "Enter," "Selected" and "Enter." A dialog box will ask you to confirm your selection; with the cursor on "Yes," press "Enter." The photos you selected will be copied to the frame's internal memory.
Dec 04, 2011 | PANDIGITAL 7270FW Tablet
Cannot down load pictures to frame from computer
The following instructions should be able to help you transfer pictures/images and music from your computer to the frame.
Power ON the frame.
Connect the small end of the USB cable to the USB port on the side panel of the Digital Photo Frame.
Connect the larger end of the USB cable to the USB port on your computer.
You will see some extra "Removable Disc" drives in "My Computer" -- One for each of the memory card slots on the Digital Photo Frame. And the last one is for the Internal Memory of the frame. Double-click on the last "Removable Disc" icon to access the internal memory of the frame. From here you can copy images and music files to the frame. You need to transfer the images or music files into this folder (which is the internal memory of the frame). Copy the files from your computer and paste them in this folder.
The picture files should be in the "standard JPEG" format and the music files should be in the "mp3" format.
To disconnect the Digital Photo Frame from your computer:
In Windows, on the bottom taskbar, right click the icon which appears in a green color, (this icon has an arrow pointing towards the left) and select "Safely Remove Hardware".
The Safely Remove Hardware" dialog box will appear. Select "USB Mass Storage Device" and click "STOP"
On the next dialog box, click "OK" to remove the storage device.
On the next dialog box, select "CLOSE" and disconnect the USB cable from your computer.
Now you should be able to see the pictures on the digital photo frame.
Thanks.
Mar 13, 2011 | Coby DP-772 Digital Picture Frame
How to transfer a picture taken & stored with a v9 motorola phone to a computer ?
Using your phone's USB Connection as 'Memory Card' or Using Motorola Phone Tools.
1. Install the Motorola Phone tools to your PC.
2. Connect the USB cable to your phone and to your computer. Your computer will recognize your phone as a "Removable Disk" icon
3.On a PC, this icon can be found in the "My Computer" window under "Devices with Removable Storage".
4. Open the "Removable Disk" icon to access the memory card.
5. Drag and drop the desired files to the folder in your PC.
using Motorola Phone Tools
1. Connect the USB cable to your phone and to your computer.
2. click Transfer Pictures from the welcome screen
3. In the Mobile Phone View select the file/folder you want to copy.
4. click the arrow key to transfer the files from your device to PC and vice versa or you can simply drag and drop
hope this help
Sep 08, 2010 | Cell Phones
Comp does not recognize the connection
There was a corrupt file on the picture frame that needed to get deleted. The corrupt file was not allowing anything to work properly.
May 07, 2009 | SmartParts INC. digital frame. 7.0 in....
Can't get photos from MAC to load to Digital Photo Frame
To connect to a Macintosh computer:
1 Plug in and turn on the digital picture frame.
2 Connect the small end of the usb cable to the usb port on the side of the digital picture frame.
3 Connect the larger end of the usb cable to a USB port on your Macintosh computer. The Macintosh will recognize the digital picture frame as an external storage device, and an icon will appear representing the device.
4 Drag and drop your photos on to the icon...
5. After you finish, press the eject button, and disconnect the usb cable once the icon has dissappeared
If there is still a problem, try restarting the macbook. and make sure no other programs are running in the background that may interfere with the process. Also, make sure the laptop is plugged in, or the battery power is sufficient.
Hope this helps!
Let me know!
enov8
Feb 19, 2009 | Computers & Internet
Can't transfer photos from computer to digital frame
Copying pictures from EasyShare software:
1. Install EasyShare software (free download at www.kodak.com/go/sw)
2. Connect the USB cable.
3. On your computer, open EasyShare software. Select the pictures in My Collection and drag them into the Picture tray.
4. In the menu bar, select File and then Copy to the Kodak Drive letter.
The picture frame appears as removable drives—one drive for each connected picture source in the frame, in this order: internal memory, memory cards, and USB devices.
5. Select the frame source to which you are copying.
6. Select Best for Digital Picture Frame to reduce the resolution of the pictures you are copying. Full resolution is unnecessary and quickly fills up the frame's memory.
7. Click Copy. Pictures are copied to your frame.
8. Unplug the USB cable and on the frame check the pictures that were just copied.
Jan 17, 2009 | Kodak EasyShare M853 Digital Camera
I'm trying to transfer pictures from my computer to the picture f
You can start copying pictures to SV811 digital picture frame if you get the message “Use PC interface to copy files.” Here are the steps:
Copy pictures, videos, and music between your frame and computer, using your computer's normal file copying tools:
1. Connect the USB cable from the frame to your computer
2. On your computer, open My Computer or Windows Explorer.
3. Navigate to the pictures you want to copy. Then drag and drop them to the new location.
4. Unplug the USB cable to view your copied pictures.
1. Install EasyShare software (free download at www.kodak.com/go/sw )
8. Unplug the USB cable and press “Home” icon to navigate to your copied pictures.
Dec 20, 2008 | Kodak EasyShare SV811 (8858946) Digital...
Trying to move photos from Apple Mac to Pandigital frame
Its easiest to transfer the pictures to a usb drive or sd card and insert them into frame and copy them to the internal hard drive. Using Mac OS X Snow Leopard v10.6.2
Nov 25, 2008 | PANDIGITAL 7" Digital Photo Frame With...
Pictures
If your PC has Windows XP, just plug your camera in USB port and PC will recognize it as Mass Storage and you will see Removable Disk icon at My Computer panel. Click Removable Disk and go to picture folder and copy/ cut picture files and paste / save in desired folder in PC.
Sep 09, 2008 | Samsung Digimax S730 Digital Camera
SmartParts INC. digital frame. 7.0 in. picture. wood (SPDPF70EW) Logo
238 people viewed this question
Top SmartParts Photography Experts
Joseph Hoffmann
Tony
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
