Question about Whirlpool GSW9800PW Washer
How to get the back off a waher
My Whirlpool washer is only 2 years old, and the water pump when pumping water out, make a loud noise.. I need to get the back off the washer to see if something is stuck in the water pump. I can't figure how to, I have removed all the bolts, but it is still attached. Please advise
    President:
  • 1,294 Answers
The back is resting on some slots, try lifting the plate out of these slots.
Posted on Jun 28, 2007
SOURCE:
Starting the dishwashing cycle, extreme loud noise when dishwasher starts pumping water. Loud noise stays during pumping cycle. Dishes are clean and dry and no water in tub when cycle finishes.
If your unit is a Kenmore or Whirlpool (there are several other brands that use many of the same parts) and is less than 6 years old then it may pay to first check and clean out the chopper assembly for hard debris. If that doesn't do it then you may want to consider replacing the motor and circulation pump as a complete unit for between $160 and $200. Not too difficult a task for a moderately handy guy with some tools. Maybe 2 hrs. The bearing itself is not serviceable I understand, and would be considerably more difficult. Over six years old then you can buy a great quality machine for about $500.
I’m happy to assist further over the phone at https://www.6ya.com/expert/howard_977676954994c5b2
Oct 23, 2013 | Kenmore Dishwashers
Sudden loud vibration from the door of my Whirlpool dishwasher. Replacing the part didn't help.
see this causes and fix it. God bless you
Drain Pump If the dishwasher is loud during operation, the drain pump might be defective or might have some debris in it. This is a common problem.
Circulation Pump If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the circulation pump sound, it's likely that the circulation pump motor bearings have failed. Once this happens the circulation pump will have to be replaced, the bearings are not repairable.
Drain Impeller If the dishwasher is loud during operation, the drain impeller might be broken, or there might be debris in the pump. Generally, to gain access to the pump the top of the pump housing will have to be removed.
Pump and Motor Assembly If the dishwasher is loud the motor bearings, drain impeller or wash impeller might have worn out. All three of these components are part of the pump and motor assembly. It may be possible to replace one of the impellers, but the motor bearings cannot be repaired. In that case the pump and motor assembly will need to be replaced.
Wash Impeller The wash impeller is a small, plastic blade. The motor spins the impeller forcing water through the spray arms to clean the dishes. If one or more blades has broken off of the impeller the dishwasher is loud. The impeller can also scrape against the pump housing if it is damaged, warped or bent.
Circulation and Drain Pump Motor If the dishwasher is loud during operation, and the noise is a continuous drone similar in speed to the motor sound, it's likely that the circulation and drain pump motor bearings have failed. Once this happens the motor will have to be replaced, the bearings are not repairable.
Water Inlet Valve The water inlet valve is an electrically controlled water valve. When it is new, the water inlet valve is very quiet. Over time, the diaphragm inside the valve deteriorates and deforms. This deformation interacts with the water rushing in and can cause a loud vibration, buzzing, squealing or other noises. If the dishwasher is loud during the filling cycle, replacing the water inlet valve may solve the problem.
Sep 28, 2012 | Whirlpool Dishwashers
Whirlpool washer; spin cycle not draining
It sounds like your water pump is broken. there is a motor inside that pumps the water out when the machine computer changes to spin cycle
Aug 06, 2009 | Whirlpool 4.0 Cu. Ft. Plus Washer
Does not drain,
HI,
check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line...
thank u
rate me!!!
Jul 28, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
We mistakenly ran our 2 year old kitchenaid through a cycle
It's possible. A pump like that should never be run dry, especially if it ran dry for an extended period of time. Does the noise go away as more water moves through the system? If not absent then less?
Jul 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Waher not working
does it make a humming noise if so there might be something in your pump
Dec 19, 2008 | Whirlpool Washing Machines
Will not agitate or spin,makes loud noise during those cycles
Sounds like coupling gears between transmission and motor... they did away with the belt and went direct drive with coupling gears. It can pump water out but nothing else. water pump is mounted to front of motor is why it will pump water out.
Jun 19, 2006 | Whirlpool LSN2000LW Washer
Whirlpool GSW9800PW Washer Logo
46 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
