Question about Refrigerators
The display / control panel is not working on our wse6100wa
The fridge is freezing and the display panel no longer works
aborcass
  • 2651 Answers
SOURCE: Hot fridge seal
sounds like its overheating badly, check the condensor coil under refrig asuume its toatll clogged also check the condensor fan motor located behind refrig next to the compressor, its supposed to blow away the heat and keep things cool under there if its not spinnig youll need to replace that as well
Posted on Mar 15, 2008
tech master
  • 120 Answers
SOURCE: Kenmore 546033 Side by side Control/Display panel dead
yes the only way is to repl the control board and make sure your outlet is properly grounded but you might wan t to unplug and plug it back to see if it resets but still it has to be repl ok
Posted on Jan 19, 2009
relaga58
  • 158 Answers
SOURCE: FRIDGE FREEZES EVERYTHING...DIGITAL PANEL DOES NOT CHANGE THE TEMP.
try off and on power
Posted on May 05, 2009
  • 2468 Answers
SOURCE: My westinghouse sid-by-side fridge is freezing
the mother board located inside the lower rear portion of the unit is bad,if you have recently had lights blow out this can cause a surge and ruin the mother board,also if there are relays clicking and lights are blinking dimly this is a good sign the board is bad
Posted on Jan 17, 2010
SOURCE: Westinghouse Wse6100WA side by side Fridge-icing up/not cooling
This is a bad design flaw, the fridhe is cooled by fan forced air from the freazer. Two ducts vent into and out of the fridge fron the freezer and ice can block them up (which you can find if you take off all the plastic at the top and back of the fridge).
Hence, when they block up, the frindge does not cool, hence the thermostat tells the fridge to keep running which makes the freezer colder and colder, making the blockage worse.
You need to not only fully defrost the freezer (which can be done quicker by removing the plastic panel in the back of the freezer and using a hairdryer) BUT also fully dry the fridge before turning it back on.
To stop it happening again, avoid puting unvovered liquids or hot items in the fridge. Also avoid leaving the fridge and freezer doors open for long especially in humid conditions. As I said, it's a bad design.
Posted on Feb 20, 2010
I have a whirlpool 6th sense single door fridge. the icons on the control panel on the door are no longer visible (i.e. the control panel is dark). the fridge is still working. Do I need a new fuse?
No. Fuses have nothing to do with it. You would need to meter the voltage from the control board to determine if the display is receiving the power it needs to run properly.... Help Me Find My Model Number RepairClinic com
Nov 01, 2016 | Whirlpool Washing Machines
The fridge has quit working. Light is on inside the fridge and freezer but control panel on ice and water dispenser housing is out
It's either a bad control board in the back, bad display board or lack of communication between the two. Check all of the electrical connections on the main board and at the hinge area above the door. Then next I'd check the connections at the display board. I'd unplug the refrigerator before you do the checking to prevent any possibility of electric shock to you or arc to the board.
Mar 24, 2016 | Whirlpool GI5FSAXVY Stainless Steel ...
I operated the "Holiday Mode" button on my Model WSE6100WA fridge. After returning the temperature display etc does not illuminate so I can't operate any temperature controls
The eco/vacation mode only exits when the door is opened if it was started automatically by the refrigerator. Since you pressed the eco button, you'd have to press the eco/holiday button until the display shows no icon for the feature.
How long did you have the power off to the refrigerator? Try pulling the plug for a 5 minute power outage. If that doesn't solve the problem, I suspect your appliance may have been damaged by a power fluctuation while you were away. Without additional information, I can't tell if only the display panel is damaged or if something else is wrong. The parts diagrams for the refrigerator are available here: http://spares.bigwarehouse.com.au/index.php?cPath=64685_78487_78846 .
I hope this helps.
Mar 10, 2014 | Refrigerators
Food freezing in Refrigerator Freezer ok. Westinghouse model wse6100wa. Have misplaced manual and need to know what temperature is correct and how to fix this problem.
There is a normal setting of the thermostat for the fridge and freezer and you can select the fridge setting to be lower than normal than what is set presently.
If there is no change then the thermostat is not cutting off the cooling and so there is no control of temperature within the fridge. Allow the lowest setting of the thermostat in the fridge section to confirm this fault.
Aug 18, 2011 | Refrigerators
Jan 16, 2010 | Refrigerators
Freezer not working
Your refrigerator has a Control-defrost,adaptive timer ,PC board part number 241508001
This is providing your model is the one listed above your post WRS3R3EW. The model you listed in post does not come up. Until we can determine that the freezer is not defrosting you need to unplug and remove the back panel of freezer compartment to see if the evaporator coils are frozen or clear. If frozen this alone will cause a chain reaction that keeps vents to fresh food compartment open and cause freezing in that area. Go to link below and enter model number WRS3R3EW0 Then you will see a list of diagrams on left side, chose #11 this will show the control parts. Click link below Thanks, Sea Breeze
We offer free help and assistance also.
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Control panel not working Samsung refrigerator model rs2533sw. Not cooling.
I have a samsung refrigertor rs2555sl and my control panel stopped working after I turned the power off to the house (to install a light fixture elsewhere). There was one green light blinking on the refrigerator temp display.
Hold down the "power freeze" and "power cool" buttons at the same time for at least 8 seconds. This is a self diagnostic program. A number should appear on the refrigerator temp display (1-9)...it will hold for 30 seconds and then the panel should function again.
In my case the number that appeared was "3" which can indicate a multitude of things including a short circuit or power outage (which was it was for me).
Hope this helps!
Apr 02, 2009 | Samsung Refrigerators
Mar 31, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Samsung RS263BBWP Side by Side Fridge: Water line continually freezes
higher numbers on the tempature set make the fridge
colder lower numbers make wormer
May 23, 2008 | Samsung RS2556 Side by Side Refrigerator
Refrigerators Logo
83 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
