Question about Home Security
How do I change the frequency of my Unicom door bell model 54665
Door bell
5 Suggested Answers
ButtFuzz
  • 463 Answers
SOURCE: dings sometimes with out pushing the button ??
I believe there are either dip switches (or old-fashioned "jumpers" in both the button (the 'transmitter') and the dinger (the receiver). See if this is the case, and that the dip switches (or jumpers) are in the same position in both units. Then, simply switch one of the dip switches (or jumpers) to another 'position' in both the button and the dinger. There ya go...
Posted on Mar 05, 2009
  • 113 Answers
SOURCE: Wireless door bell not working
Generally speaking the doorbell with the 1 thru 8 and the receiving unit should also have the 1 thru 8 tabs. Just make both units have the same positions for the 1 thru 8 and you should be all set.
Posted on Aug 03, 2009
alpug
  • 1961 Answers
SOURCE: I have 2 door bells, one for the front door and
since they are wireless they are of different frequency so it is not possible to activates the two receiver with one remote..unless it is wired.thanks for using fixya.
Posted on Oct 31, 2010
  • 188 Answers
SOURCE: will my wireless bell push work with another manufacturers door chimes?
Doubtful they are compatible. If they are set by dip switches and you set them the same bot doesn't work-not compatible.
Posted on Jul 17, 2012
House wireless door bell type
Your bell is wireless, I assume? The frequency on your unit and theirs are the same.
Change tge unit to anotger make or model.
Mar 21, 2015 | Cars & Trucks
I have a Paget Trading wireless door bell. How do you get into the door bell button. Is there a battrey in it?
Yes, there is a small battery in the door bell button, use a small screwdriver to carefully pry it apart, make sure the transmitter and receiver are on the same frequency and within range of each other.... really hope this helps?
Feb 22, 2015 | Bell Sports Wireless Door Bell with...
My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
look for a cover that has small switches under it. You can change frequencies there. You must match the door button the same way .
Nov 19, 2014 | Office Equipment & Supplies
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
May 12, 2014 | Heath Zenith SL-6144 Specialty Series,...
Change the chime frequency on a siemens door bell
With Siemens door chimes, there are often no dip switches. Instead you need to take the batteries out of both the receiver and the switch, wait for a few minutes, replace them and then try again. The set should "learn" the new frequency of the doorbell automatically.
Mar 19, 2012 | Home Security
Phantom bell rings on Siemens wirreless door bell chime jsjs-204, I do not have instructions
You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Nov 01, 2011 | Desa International White Wireless Plug In...
Wireless door bell rings when no one there
most likely on the same frequency! They have a pretty good range on them, I'd go but a different brand!
Jan 07, 2010 | Kitchen Appliances - Others
I have a byron door bell. If i buy anmother one
This all depends on the design of the unit, if its a fixed frequency then you would need to ensure that the second unit matches the frequency, however if the design allows you to "select"the frequency, usually by a small group of switches then there should be no reason why it wouldnt work, your best chance is to look at your exsisting setup and see if its got any way of setting the frequency, or if it doesnt buy a different unit that is capable or learning a frequency, i apologise for not being able to give a more direct answer on this but i hope it helps!
Nov 05, 2009 | Bell Cocoon Child Carrier
I have a byron SX85R plug in wireless door bell, i need to change the frequency/ or code, keep false alarming, cant find the instructions , also with the alarm, is a batterie alarm no. SX81R, which came...
From User Guide: Interference from a similar unit operating nearby: a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
Oct 10, 2009 | Bell Cocoon Child Carrier
Home Security Logo
230 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
