Question about Samsung HT-E4500 5.1 Channel Blu-ray Home Theater System
Please close tray error, yet its closed?
Nothing but problems with this system. Have already taken one back! before this one goes back i need to check its not something simple. We keep getting a "Please close tray error" tray is closed...help..or send us a hammer...
SOURCE: Samsung SGH-D820 bluetooth static problem
I have exact same problem as agent47, the bluethooth is not active, but the phone says it is. Searching for other devices is not possible. When you try, it asks you to activate bluetooth, when you accept it says already active and cancels.
Posted on Dec 25, 2007
VOTIT
  • 2071 Answers
SOURCE: Disc Tray will not close
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 10, 2008
  • 13 Answers
SOURCE: The paper tray has paper
MP - is the manual tray on the side. Sometime I've had trouble with switch that locates the paper on the side. Joggling the paper has helped me.
Posted on Oct 26, 2008
  • 13433 Answers
SOURCE: DVD Tray in computer not opening
there should be a small hole on the front of the tray that you can push a pin in from and it will eject the tray. if its stuck and you still need to hit it, would be best to use your warranty to get it fixed or take it apart yourself and make sure noting is blocking the tray from opening. you may have to take the tray apart and put it back together to get it to work normally.
Posted on Jun 01, 2009
SOURCE: samsung pixon 12 keeps saying not enough
phone dont charge.. one pin is missing
Posted on Apr 23, 2010
What is code error e03
Printers & Copiers
Code error E03
Nov 14, 2014 | Office Equipment & Supplies
How can I get tray 2 to close in place?
Please make sure nothing is in back of the paper tray.
Sep 10, 2014 | HP LaserJet 3200 All-In-One Printer
W1
Sensor switch inside detects the position of the tray
check for dirt on contacts
check internal connections
if all good you have a fault on the the logic board
Apr 14, 2014 | Panasonic Home Theater System System
Xbox open tray error
Not sure but sounds like you may have bent or broken a plastic tab, or not fully straightened the tray yet. There will be a microswitch or sensor of some type that indicates tray open if it is not closed or within tolerance. The tray must be properly straight and if there is a tab that closes the microswitch it needs to be straight and secure too. It only needs to be slightly bent to fail to register closed. Hope this helps.
Dec 20, 2013 | Video Game Consoles & Games
C-0991 error on screen
First problem is for some reason your KMC 3130 crosses over to a Konica Minolta CF3102 and there is no C-0991 code listed for those machines. However, that C-0991 code is a common paper tray lift failure code on Konica MInolta machines.
So I would recommend opening and checking all of your paper trays to make sure nothing is binding them and that the paper is loaded properly.
Then open and close the large front door to reset the code.
If the code comes back then open all of your paper trays and LEAVE them open. Next open and close the front door to reset the code. The copier should now come to "ready to copy"
Then close each paper tray 1 at a time waiting 30 seconds between each tray closing. Once the code pops back up after closing a particular tray then you will know for sure which tray is causing the problem.
You can use the copier by leaving this tray open if need be.
Good Luck.
Nov 24, 2009 | Kyocera Mita KYOCERA/MITA - KM-C3130...
C0920
Paper Tray Lift error code. Check and reload all the paper in all the trays. Power off then on to reset. If this does not solve the code then pull out all paper trays. Reset machine leaving alll trays OPEN. Close the trays 1 at a time waiting 30 seconds between each tray closing. If the code comes back after closing a tray then that will tell you which tray has the problem. You can leave that tray open so you can use the machine and also you can check that tray more closely.
Oct 21, 2009 | Minolta Di3510f Bizhub Copier
360 disk tray
What I did was took apart my Xbox and put the disc tray back on the tracks, carefully lifting it over the circle thing in the middle. When I lay my Box down horizontally, it opens and closes fine.
Jul 27, 2008 | Microsoft Xbox 360 Console
Recording trouble
Hi again,
I understand. Must be a glitch somewhere. Anyways, I already posted possible solutions here your original posting/problem. They were:
1. Power on the Philips FW-R7, leave the left tray empty and closed. Open the tray and put in a recorded CD (not a CDR but a regular CD from your music collection), close the right tray. Wait a couple of seconds as the FW-R7 reads the CD. Now open the tray, remove the music CD and insert your CDR. The FW-R7 should read the CDR without the error message and record to the CDR from any source. Let me know if this works for you;
2. laser cleaning or realignment (would need a service center);
3. try using lower then 40X blank CDs.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 18, 2008 | Philips FW-R7 CD Shelf System
Cyberhome 300 dvd player
try to pull the tray all way out by hand 1st knda resets it then hit close
Feb 03, 2008 | Cyberhome CH-DVD 300 DVD Player
Paper output tray is closed
I had the same problem with the paper output tray. I solved it by removing the switch by removing one screw and tying the wire leads together. Now the printer thinks the tray is always open.
Dec 31, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
Samsung HT-E4500 5.1 Channel Blu-ray Home Theater System Logo
71 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
