I have pentium computer - D815EEA2 Motherboard P-III, 733 Mhz. CPU Now i purchase viewsonic VA1918WM Monitor and picture is flicking, and only one setting of resolution in 1024 by 768 pixels High (24 Bits) result is good. so what is the problem if i insert nvidia agp card installed all resolution result is good, what is the problem
  • 741 Answers
The reason you are getting the flickering is because the refresh rate is not set correctly. Click on Start>Control Panel>Display>Settings>Advanced>Monitor. In the middle of the window you will see the refresh rate. It should be set between 60-75. Try setting it between that range and try it a few times until the screen stops flickering.
Thanks for using FixYa. Don't forget to vote on this solution before you log out.
Posted on Jan 20, 2009
Thermal faillure, processor is problem. how price? this processor?
Desktop? Laptop?
What manufacturer of motherboard?
What model of motherboard?
Intel or AMD CPU?
What model-number?
Search on www.eBay.com for a compatible CPU.
Jun 07, 2011 | Dell Pentium 3, 500 MHz Pentium III...
I want to upgrade my Cerelon 500 MHZ Processor into intel Higher MHZ
Hi, the best way is to put your motherboard details into a google search, find the best proceesor for your motherboard. Then ebay would probably be the cheepest place to purchase.
Hope this helps
Jul 24, 2010 | Hitachi Pentium III , 500 MHz...
Caqn i put a 700Mhz Dell Pentium III in the same
No, you cannot exchange them. I was not able to determine what socket your notebook uses, but the 500 Mhz mobile Celeron was only available in two formats. One was Socket 495, which has no Pentium III processors available (only Celeron). The other is BGA2, which is not a socket at all, but is soldered onto the motherboard and is thus virtually unremovable.
Sep 16, 2009 | Dell Inspiron 3800 Celeron 500MHZ...
Installed Upgrade CPU - Computer Will Not Boot
are you sure that the CPU artitucture is correct for the motherboard that your putting the processor into?, just because it fits doesn't always mean it will work,
Mar 12, 2009 | Computers & Internet
What are pentium III Equivalents
Athlon 1.3GHz cpu
Celeron 300A processor.
These are a few and courtesy of Tech Enclave here is a link about a place in China that produced a CPU called Godson II which is the equvalent of a Pentium III as well.
http://www.techenclave.com/cpu-mobo-corner/chinese-made-cpu-chip-equivalent-pentium-2595.html
Hope this helps.
Feb 27, 2009 | Intel Pentium 3 , 450 MHz Pentium III...
Problema con cpu
Su placa madre apoyará los procesadores siguientes:
(Your motherboard will support the following processors:)
Pentium III 450~500MHz
Pentium II 233~450MHz
Celeron 266~433MHz
Buenos Dias
Oct 22, 2008 | Pc Ware M748LMRT Motherboard
I have 810 bu mother board
your board is compatible with pentium 3 processors through the "coppermine" revision, the pentium 3 "tulatin is not supported" here is a list from wikipedia of the "coppermine" processors supported by your board.:
Coppermine
  • 100 MHz FSB: 500, 550, 600, 650, 700, 750, 800, 850, 900, 1000, 1100 MHz (E-Models)
  • 133 MHz FSB: 533, 600, 667, 733, 800, 866, 933, 1000, 1133 MHz (EB-Models)
Coppermine-T (the only coppermines with an attached heatsink)
  • 133 MHz FSB: 800, 866, 933, 1000, 1133 MHz
The Tulatin core is NOT compatible with intel 810 boards, and they can be easily confused with the coppermine-t's because they also have attached heatsinks.
Aug 20, 2008 | Intel SuperMicro SUPER Motherboard - 810...
ALFONSO
Ese procesador usa el FSB en 133 Mhz y el motherboard tiene el FSB en 66 mhz, tenés que entrar en la bios y cambiarlo por 133, si no te permite hacer ese cambio es porque el motherboard no soporta ese procesador.
Saludos!
Jun 19, 2008 | Intel Pentium III, 866MHz Pentium III-M...
Upgrade from 600 MHz to 1 GhZ
According to this review, you can upgrade as far as a 2 GHz P4-M at least; http://www.pcmag.com/article2/0,1895,669029,00.asp Other than that, i have been unable to find the details of your motherboard - if you can post the make and model (should be printed on it somewhere) then I would hope to find a more complete list of compatible and incompatible processors. Gateway themselves no longer offer online info or support for this model, but the motherboard details should enable me to find out what you need to know. Waiting for your post :)
Nov 04, 2006 | Gateway Pentium III , 600 MHz (1515824)...
Computers & Internet Logo
341 people viewed this question
David Payne
David Payne
