Wesco Star Wars R2d2 Projection Alarm Clock Logo
Received this clock as a gift. It worked fine for about one week and then it stopped making any/all sounds. The lights still work fine. Have replaced batteries. Still no sounds. Please help.
My son received this clock as a gift. It performed normally for about one week and then abruptly stopped making any sounds. The lights and clock both still work fine. I have tried changing the batteries. There is a rattling sound inside the clock as though something is loose, but it is deep inside the clock. Please help. My son is very disappointed by the poor quality of this clock. Thank you.
2answers
Remote not working
I would suspect a fault but check the batteries in the remote are fitted
correctly.
Pixelated proscan tv problem
Look for loose contacts in power outlet, RC Jacks, sockets, cables.
About 2 weeks ago i received some logitech z323 speakers as a gift and was very pleased, however the right speaker has now stopped making any sound at all, i have checked the connection to the sub and...
a possible WARRANTY issue
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
NN-T774 INVERTER STOPPED WORKING AFTER 4 WEEKS
Check to make sure one of the plastic hooks on the door was not broken off. If both door hook latches are functional then the most likely cause of your problem is one of the latch switches located behind the control panel. These switches will fail if the oven user opens the door frequently BEFORE the cook cycle ends. Always push STOP/RESET before opening any microwave oven door.
Fridge has problems
sounds like the defrost clock may be going bad and or a door switch. Look for a hole that has whatr looks like a big screw that you can turn.
Keyboard works then doesn't
take the phone and have it service then if that does not help the issue take it to a mobile service center and have them reflash the keypad with the flash file.
Top Wesco Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Wesco Audio Player and Recorder Expert? Answer questions, earn points and help others
