Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
No picture, just sound, can still see cable directory
We got this TV as a hand me down so I don't have an Owner's Manual and cannot find one at Hitachi's website. We have the set hooked up to cable and can hear sound and see the cable directory just fine, but no picture. All connections appear secure, and all other sets in the house have picture so it doesn't appear to be a problem with cable.
Thanks for any suggestions you can offer!
  • 1 more comment
  • dugan2b Jan 20, 2009
    It has a cable box. We also have a DVD player and Wii set up to other inputs and those are all working. We tried changing the AV cables but still only have sound and cable display (menus, etc) but no picture. Thanks for the help!
    Thank you!!! I think you are right, it is a bad box. I was able to get a picture by connecting cable directly to the TV. It is a Motorola box but there is no a/b button (it's a newer DVR converter box.) I'll take the converter back to Comcast tomorrow. Thanks so much for your help. :)
  • Frank James May 11, 2010
    How exactly is the TV hooked up? Is it just cable from a wall jack or a cable box?
    Problem Solver:
  • 7 Answers
Sounds to me like you may not have service on your cable box. I worked for a large cable provider for years and that was generally either a faulty box or the box just needed a "signal" sent to it. Try to bypass the box complety and just hook your service directly into your TV. You may need to go into you TV's menu, switch it to the cable setting and then auto search, but most likely the TV is new enought ath you should be able to get a picture. We do know that it is not a problem with the TV since you are able to view other devices on the TV. If you get a picture then we have narrowed it down to the bow. Although this may not mean that the box is bad. First let's ensure that if is installed correctly and that the input jack is the cable from the wall and that the output runs to the TV. Again you have sound so i know this seems dumb but so can be cable installers. :) Since we know all of that is correct and you still have sound but no picture, I'm going to say that you most likely have a motorola box and on the front of it there is a small button that has a/b next to it. (most commonly found on motorola box but not limited to). If that button does exist on this box i'm almost certain that will correct your problem. If not you have a faulty box and should ask you cable provider to replace it.
Posted on Jan 20, 2009
NO PICTURE ON TV / JUST BLUE SCREEN / W/RED SYMBOL.Have an Advent TV -- seems locked up, can't get a picture, just a blue screen with a red symbol in upper right hand corner
Look to the owner manual if you have it as it will likely have the answer you need--if no manual Google the model number with "manual" to try to locate the owner manual---if get or have it read it carefully as it sounds like to me the parental lock is on or something similar to it.
May 23, 2012 | Televison & Video
Where can I get an owner's manual for a RCA ATSC11 digital tuner?
On the RCA ATSC11 you can see the menu if you switch to 480i resolution and connect a video cable to the monitor output. Otherwise the menu is visible only on the digital output.
Dec 23, 2011 | RCA ATSC11 DTV Receiver
The picture is visible but there is a black small screen just covering the picture
Hello; If there is a black box covering part of the picture, it is likely a " TEXT " box that is used with " closed captioning " Read your owner's manual to see how to TURN OFF all closed captioning functions. Download the manual if you don't have one. John
Sep 18, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Today I found a firmware update v102 for the EX-S200 Silver model. I want to update this firmware as the color of the picture taken is extremely bad compared to a 3 year old Nikon 10 megapixel. My less...
I doubt this will take care of the problem. The root directory of the drive is the removeable sd card from the camera and it is above the level of the BIN folder. You then plug the sd card back in the camera and hold down the set button. The whole process is outlined http://support.casio.com/download.php?rgn=1&cid=001&pid=987
Mar 01, 2017 | Cameras
I have a 46' lcd sanyo... we have sound but no picture...and the off and on button keeps flashing...hadnt had any problems until now...how can i fix this..we havent had the tv 7 mths yet??
The tv less than a year old?Call the hot line in the owner manual for warrenty repair.The tv Tuner board have pronlems,that the board,where the coalaxial broscasting signal cable plug into it.
Jul 16, 2010 | Sanyo DP46849 46 in. HDTV
Plasma tv has sound but no picture
Check all the cable connections at the back, if you are using an external receiver , then check the Video cable, eventually try a replacement one.
Try leaving the TV set unplugged for a couple of hours, this will drain power completely and, if there is no real fault , this can fix the problem.
If that does not fix it, then thereis an internal fault.
Common faults that cause audio but no picture concern, digital board, controller board, sustain boards, Plasma screen ribbon cables, and plasma display.
Call the number listed on the owner manual to get assistance.
If the warraty is expired no longer than three years, ask the price fod r a warranty extension calling same number in the manual.
Nov 22, 2008 | Televison & Video
No sound or picture
Try 2 things:
1. If you have a cable box with the yellow/white/red outputs, use a compatible cord to run the 3 to another input on your TV (ie input 1 vs cable). and/or
2. Do a Factory reset. Hold the "menu" button on your TV then on your remote hit "menu" then "8" then "select" and go to "factory reset". You may have to unplug the TV as it may freeze on "factory reset". Replug it then try it out.
Hope it works.
Apr 03, 2008 | Hitachi 51F510 51" Rear Projection...
No Picture on TV
? What is the model # off the back ?
Does the video work on the RF coax cable input?
For instance,as a test,can you hook-up from VCR coax RF out
to TV coax in,put the TV on Chan. 3,play a tape and get audio and video?
Are you matching colors when trying the A/V inputs?Yellow,red,
and white out of DVD to yellow,red and white in on back of TV?
Then select video input on tv===dial "00" or use input button on
original RCA remote. Are you using original RCA remote that
came w/TV ? Do you have the owner/operator manual for the TV?
   Sorry to ask so many  ?????   Let me know how it goes!!  T.
Oct 17, 2007 | Televison & Video
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
392 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
