Question about Toshiba Satellite M35X-S349 Notebook
MY LAPTOP WILL NOT TURN ON
MY BATTERY IS FULLY CHARGED THE BLUE LIGHT COMES ON BUT I GET NOTHING FROM THE COMPUTER. I ALSO TRIED TO RUN IT WITHOUT THE BATTERY, I SIMPLY PLUGGED THE POWER CORD INTO THE COMPUTER AND INTO THE WALL
  • 1 more comment
  • mattlumpkin Mar 26, 2009
    Same problem. I tried the solution above but get the same result: power on, fan noise for approx 10 seconds then the blue power button light stays on along with the adapter and power led's on the front of the laptop. They apparently stay on as long as the laptop is pluggd in.
  • Anonymous Apr 05, 2009
  • antnylee Apr 14, 2009
    I've had the same problem since I tried to plug the powercord into my computer one day and everything suddenly shut off. When I press the power button, I hear a fan for less than 10 seconds and nothing boots up. I brought it to a service center here in Asia and the guy says the motherboard probably needs to be replaced, so it's not worth fixing.
  • 41 Answers
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
If this doesnt work can you hear any fans or hard disk activity when you press the power button?
Posted on Jan 20, 2009
Flashing led's on battery pack
Charles,
The battery turns on steadily or blinks to indicate battery charge status.
If the computer is connected to an electrical outlet, the light operates as follows:
  • Solid blue - The battery is charging.
  • Flashing blue - The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
  • Off - The battery is adequately charged, or the computer is turned off.
  • Flashing orange - The battery charge is low.
  • Solid orange - The battery charge is critically low
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jul 28, 2013 | Dell Inspiron 1420 Notebook
Gateway NV5337u Laptop worked yesterday, now only the blue lite comes on when plugged in. No fans or any other sounds.
We might need to talk more, to clarify to solve this promblem. First of all, have you done any update at all to the system? So by what you mean is that when you would go ahead and press the power on button, you get nothing at all... I mean dead, no lights, no fan, completely dead right? But when you have the charger plugged in, the battery light come on only saying it's charging? Is this blue light the battery indicator light, if it is, then that means your battery is fully charged. Try taking out your battery and just using the power adapter and press the power button to see if anything comes on, like fan, lights etc, then try it without the power adapter and only the battery. If you get nothing at all coming at all, I would assume your power button is bad or loose, or the wiring that connects to your powerbutton is loose because i have a gateway Nv series too, and the power button is located where the screen hinges is at, and I'm afraid that when opening and closing, it became loose. This happened to my Emachine, and all I did was took the plastic portion above the keyboard out, and followed the cable ribbon to see if it was loose, or became little disconnect. I kinda just tugged in a little bit and everything worked. I believe it may become loose. Now if the case is that the computer does power on and you get blinking lights, then we are looking at something else.
Jan 31, 2011 | Gateway NV5337u (LXWGD02026) PC Notebook
The power light is on but my satellite A75-229 won't turn on. It was on last night running fine. The battery ran out because I forgot to turn it off so I plugged it in and pushed the power on button and...
Try letting the computer sit without the battery for a few minutes, and also without external power. Then try plugging in your external power WITHOUT the battery and try to start it up. If it does, add the battery while it is running. Then try it with the battery only.
Nov 30, 2010 | Toshiba Satellite A75-S229 Notebook
Lenovo Y530 T 3200 3GHZ 4G Laptop not charging battery when plugged into outlet;also does not work on battery alone even though it is charged to 85%
Try to perfrom power drain. You must first turn off the computer. Take out the battery and unplug the power adapter. Press and hold the power button for 30 secs. Put the batter back in, plug in the power adapter and power ip the computer then observe.
Let me know if same issue will happen.
May 11, 2010 | Lenovo IdeaPad Y530-3231U Laptop Computer...
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
The computer will only run from a fully charged battery.
friend
the problem clearly shows the fault is in the motherboard
thanks
Apr 10, 2009 | Toshiba Qosmio G35-AV650 Notebook
Power Supply Plugged In And Battery Fully Charged No Power
has it gone into hibernation? ... try holding the power button down for 10 seconds
Sep 23, 2008 | Toshiba Satellite 1415-S173 Notebook
Toshiba laptop power light is on but nothing is working
When you turn the computer ON, can you hear something running on the laptop? If yes, have you tried taking out the battery & just turn the computer ON with the ac charger plugged-in? If you tried to turn ON the computer with the fully charged battery with the above troubleshooting but still there's no display on the screen, then I think there's something wrong with your hardware (maybe the LCD or the motherboard). You could also try using an external monitor to test if it's your LCD that's defective, if not it's your systemboard. Try calling their tech support hotline.
Hope this helps.
Sep 21, 2008 | Toshiba Satellite A135-S4527 Notebook
My n610c won't light off
it seems that your battery has become deep dischare to charge it leave it power on for atleast 12 hours
Aug 20, 2008 | Compaq Evo N610C Notebook
Open Questions:
See all Toshiba Satellite M35X-S349 Notebook Questions
Toshiba Satellite M35X-S349 Notebook Logo
505 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
