Question about Teac PD-H300 CD Player
I have a Teac PD-H300 the problem i have is that the unit does not recognise any cd info.
When i put a cd in the drawer it goes in,fails to read info the the drawer opens again. Please help.
  • 3 Answers
SOURCE: Display doesn't work on TEAC PD H300mkIII
I had the same issue today. I found that opening the unit you can see that there is a white ribbon cable connecting the head unit to the main board. removing this cable and re-inserting it the connector fixed the problem. The display now works again...hope this helps
Posted on Nov 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: Is the Teac RW-H300 a unit that can be repaired
It would depend on a zillion things. Only a hands-on technician could answer it. Diagnosis and Labor costs can be open-ended.
Typically, modern electronics is not economically repairable. At $355 on Amazon for a new one, it could easily be cheaper to replace than repair.
http://www.amazon.com/Teac-DR-H300-TEAC-DVD-Receiver/dp/B000PX91GG
Posted on Jun 10, 2010
taran_2005
  • 10515 Answers
SOURCE: I turned on my TEAC
Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminum cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should then be OK. If it has been forced, the aluminum cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
e-Guru
  • 3917 Answers
SOURCE: TEAC PD-H303 #2 disk
Hi
Normally disconnecting the power will reset it, barring physical breakage or jamming. Pull fuses or just pop the radio out and unplug it. If that does not work the only way to get the cd changer to work and for the cartridge to eject was to remove the cd changer and dismantle it.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Apr 21, 2011
SOURCE: Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Posted on Aug 11, 2011
H300 mk 111 hi-fi system. Why is the remote sensor on cd player (PD-H300 mk 111) not recognised by the remote control unit (RC-1091)?
You have this backwards. The remote control sends signals to the sensor on the CD player. It is possible that the remote batteries need replacement or that the remote has a malfunction.
Jul 24, 2015 | Teac PD-H300 CD Player
Disc error appears when cd is loaded. Have tried with different cds
If the disc loads into it properly, the fault is with its laser pickup unit itself.
Apr 29, 2012 | Teac PD-H300 CD Player
Is the Teac RW-H300 a unit that can be repaired easily?
Jun 09, 2010 | Teac RW-H300 CD Recorder
When I press the button to open the cd drawer, the drawer doesn't open - any suggestions??
Just solved mine, turn the unit over and give it a shake and knock the underside a few times. I know you shouldn't be treating a delicate piece of hi-fi like this, but the tray comes out of the guide so you're just shakin it back in.
Apr 26, 2010 | Teac PD-H300 CD Player
Put a cd in playey, plays for around 20 seconds stops playing then restarts playing and keeps doing the same
sounds like the laser tracks might need regreased to me, does it also skip when playing ?
Feb 07, 2010 | Teac PD-H300 CD Player
Can I download owner manuals for PD-H300 mk3
i have found some you can pay to download but it would probably be best to email them at parts@teac.com and request a manual for your product.
Aug 07, 2009 | Teac PD-H300 CD Player
Mar 14, 2009 | Teac PD-H300 CD Player
CD PLayer no longer recognising CD RW discs
use fine cd on ur player. If some cd is not working ten do not try it again an again. Try different one. Thank You.
Aug 12, 2007 | Teac PD-H300 CD Player
TEAC H300CD Player
Hi, Your particular brand/model was made in the very early 2000. It is possible that the eye (optical lens) is already weak and would need replacement or calibration. You may want to try and clean the lens hopefully improving the reading capability. Some users of CD players use a PC CD cleaner to clean the eye (pls read the instructions) though this can be done by going inside the unit). Probably your best bet is to seek the services of a qualified professional. Hope this be of some help and give you ideas. Pls post again how things turn up and/or if you need further information. Good luck and kind regards.
Aug 04, 2007 | Teac PD-H300 CD Player
CD drawer will not open or close
Had The Same With Mine. Its was the belt Inside that joins Motor To Cd Tray. Its Black and directly under the cd tray at the front. Its probably either loose like mine of maybe broken. I replaced mine with an elastic band and its been fine since.
Nov 19, 2006 | Teac PD-H300 CD Player
Teac PD-H300 CD Player Logo
76 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
