Question about CorningWare Corning Oval Browning Grill for Microwave Ovens 10.5 X 13.5 inches
I need the instruction manual for corningware microwave grill model mw-11
I need to know how long to preheat it in the microwave
  • lynn wolf Jan 08, 2013
    It is an oval platter with a coating on its underside that needs to be preheated for a length of time in the microwave and then meat is put on it and it is supposed to brown/sear the meat. I need to know what corningware has for the required preheat time for this size and any other instructions on how to cook with it. I think they were made by Corningware in the 80's and are no longer made but this was a like new one without any instructions. I dont want to blow up my microwave 1200 watt or start a fire in it.
Can the microwave grill mw11b be used under oven broiler
No, specifically states on user instruction booklet not to. Microwave only.
Jul 08, 2014 | CorningWare Vintage Corning Ware Pyroceram...
I need instructions for 10in. microwave browner
Only place I've found is here: CorningWare Browner Instructions
As these dishes were designed by Corning for a 650 watt over, you can recalculate preheat and cooking times for your oven with the following formula:
650/(your oven's wattage) x (listed preheat time or cook time)
For example, for a Corning MW-9 dish, they list 4 minutes maximum preheat time. I have a 1,580 watt oven. So 650/1580 = .41 x 4 minutes = 1.64 minutes and about a minute and a half preheat. (MAX).
Mar 09, 2014 | CorningWare Microwave Ovens
How do i operate the convection part of model 863-5973-50 jcpenney microwave
Press convection button, then press button with temp you want, then press start to preheat. Once preheated, either press cancel once, to allow time to be input, or engage door button, an press Time and enter your cooking time. Then press start again
Nov 18, 2012 | Microwave Ovens
I need instructions on how to use Sharp Convection microwave Grill 2?
Best way short of Sharp is Google the model number of the unit with "manual" to try to locate free one online.
Nov 04, 2012 | Sharp R-930AK Convection/Microwave Oven
I have a Corningware MW-A-10 Microwave Browner which I have never used - could I use it in a conventional / thermofan oven?
No. The bottom of this utensil is coated in tin oxide. It is not recommended for use in any appliance other than a microwave. Tin oxide (SnO) is flammable and particles may contaminate your food. It is suggested that you use the MW-A-10 only in the microwave, or look for a different CorningWare piece that is not in the MW series.
Oct 07, 2010 | Microwave Ovens
I need a manual for Emerson Microwave mwg9111sl
When replacing the bulb in an Emerson, Microwave. Model mwg9111sl. Can you replace the bulb or the socket and bulb?
Jun 01, 2009 | Emerson MW8168B Microwave Oven
JVM1850BH02 Microwave completely shut down, not working after...
The extreme heat has opened up one of the thermostats / thermal cutouts (TCOs) in the oven.
If it was the bottom TCO or magnetron TCO, you should be able to access them by just removing the control panel.
But if it's the one on top of the cavity, the oven will have to come out of the wall, then you need to pull of the outer cover..
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download GE owner's manuals and installation instructions here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You should locate and look this over first.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Dec 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Preheat Freezes
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Otherwise, the temperature sensor / thermistor may have failed.
If you don't have the manual, you can download GE owner's manuals and installation instructions here.
Let us know if wee can help further.
Oct 11, 2008 | GE Advantium 120 Convection/Microwave Oven
Find glass turntable replacement part
These are the glass trays listed to match the models you gave (NR961T is actually MR961T) and they are all shown as no longer available from standard suppliers:
MW-7600-04 MW-7600-06 MW-7600-11 MW-7600-13. MW-7600-12 should also work.
You can order one of the -11 or -12 trays by part number here.
It may take a week or two, and they may reply back that they were unable to find one, in which case they will not charge you.
If you can't find one, you can check eBay or Wal-Mart and other stores to see if they have a Rubbermaid or Nordic Ware (NordicWare) wind-up turntable like this "Micro-Go-Round". (I've seen them at Wal-Mart).
In some cases, two microwave-safe plates can serve as a makeshift replacement for a missing tray. You have to find a saucer that fits securely on your turntable support, though. Here;'s a photo of that, too.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 17, 2008 | Welbilt MR755T Microwave Oven
CorningWare Corning Oval Browning Grill for Microwave Ovens 10.5 X 13.5 inches Logo
166 people viewed this question
Top CorningWare Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a CorningWare Microwave Oven Expert? Answer questions, earn points and help others
