Question about Panasonic Televison & Video
How to turn off the SAP on a panasonic tv - Panasonic Televison & Video
Can't get it out of SAP mode. tried two different remotes. TV doesn't respond.
1. If you're watching TV via a Cable or Satellite box , then the SAP (Secondary Audio Programming) is activated in the box, not the TV. Check with your TV service provider how to activate/deactivate SAP in their box.
2. Only if you're using the TV's own built-in tuner to watch TV (you're changing channels by using the Panasonic remote for CH up/down), then press the SAP button on the Panasonic TV remote to cycle through the SAP options.
Mar 15, 2016 | Panasonic Viera TH-50PX80U Plasma TV
Tip
Cycle SAP function to restore sound on CBS channels
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
on Sep 22, 2009 | Panasonic TH58PX600U 58 in. Plasma HDTV
Vizio tv cannot hear volume on all of the channels just some.
Try this:
Apparently the TVGOS (TV2_bing.gif Guide On Screen) signal on CBS stations (since the 6/12 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
Feb 22, 2010 | Panasonic PT-50LC14 50" Rear Projection...
My volume stopped working on my panasonic viera plasma TV
Make certain that it is not muted or turned off. If it isn't check to make sure that the audio type matches what you are watching. If you are on SAP and there isn't anything on the channel in SAP the audio will be dead. If all those check out you probably have a bad control board. $130 to $200 to fix. Let me know how things work out.
hardrocko
Jan 31, 2010 | Samsung SlimFit TX-S3082WH 30" TV
No audio on only some stations
Apparently the TVGOS (TV Guide On Screen) signal on CBS stations (since the 6/12/09 digital changeover) can cause the sound to be missing on those channels. Use the SAP button on the remote to page through the SAP options. When you return to the normal setting the sound will be restored. This problem should not occur again unless the SAP button is pressed.
Oct 29, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
HD TV is in Spanish, but corresponding non-HD is English
SAP (Secondary Audio Program, see http://en.wikipedia.org/wiki/Second_audio_program) set for HD channel.
Refer to TV instructions or look for a button that says SAP on it.
-=/ Daft Tech /=-
Oct 22, 2009 | Panasonic Televison & Video
MONO - SAP
In the audio menu, you should be able to select stereo or turn off sAP -- you may have to unplug the set for about 20 seconds and restore power to reset it, or return it if the problem doesn't go away. If you end up replacing the set, try for a JVC, Panasonic or Toshiba if you can switch. I think they will last longer for you.
Jan 09, 2007 | Akai LCT2701TD Television
Televison & Video Logo
1,373 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
