Question about Broksonic CTVG-5463GVC 19" TV
I have a Broksonic TV/VCR combo. The original remote is broken. The TV is hooked to a dish--on channel 73. Recently, we changed to "line" to view pics from a digital camera. Now we cannot get back to 73 without a remote. We purchased a Sony Commander universal remote. The Broksonic codes are not working, the "scan" for codes is not working. I need to get this TV back to 73. Help!
  • Anonymous Feb 06, 2009
    I have a broksonic tv/vcr. The original remote is lost and I want to program the dish remote to turn on the tv. Problem, can't find a code to work.
SOURCE: trying to figure out the v-chip code to my broksonic cygv-5463tct tv
Contact Broksonic directly at:
HATZLACHH SUPPLY INC.
935 Broadway New York, NY 10010-6061
TEL: (212) 254-9012 * (800) 333-9099
They are sending me a new remote free of charge and you can order an owner's manual.
Posted on Feb 01, 2008
SOURCE: remote control codes
I found the code "130" to work on my tv by searching through every VCR code NOT TV code. It works on my tv but the only thing is that it will NOT change the volume, but it's the best that I can come up with for my own broksonic.
Posted on Mar 03, 2008
SOURCE: I cannot switch my TV mode to video mode
I have a broksonic and the remote is broken. I have it on Aux and need it on Video. I contacted the company and there is no way to do this without the remote. I had to buy a new remote from them. The cost was almost $25.00. They are sending it to me and I will have TV again. I did tell them that this is a problem that needs addressed to the company and they were not very receptive to that suggestion. The number to call is 1-800-333-9099. Make sure you have your model number. This is what they wrote in an e-mail when I request assistance: "Unfortunately, our models are not compatible with any other manufactures." I took this as to not try any other type remote.
Posted on Mar 24, 2008
  • 267 Answers
SOURCE: UNIVERSAL CODE
GO TO WALMART FIND YOUR REMOTE ASK CLERK TO LOOK AT THE CODE BOOK FOR THAT REMOTE OR GOOGLE THE UNIVERSAL REMOTE #
Posted on Jan 22, 2009
rulds2008
  • 3866 Answers
SOURCE: who makes Broksonic tv ?
can you plese visit this website http://www.broksonic.com/
there the manufacture. you may want to call them for the current codes not all codes are garanteed to work thanks.
Posted on Apr 23, 2009
Broksonic 13" tv remote controll replacement?
Try website like Remotes.com to buy an exact or very closed to the original.
Feb 09, 2011 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Tip
Dish Network Combo TV/DVD Remote Codes
CODE Broksonic TV/VCR 748 Goldstar TV/VCR 747 Panasonic TV/VCR 747 Quasar TV/VCR 747 Samsung TV/VCR 738, 755 Sylvania TV/VCR 756 Zenith TV/VCR 747 Aiwa TV/DVD 751 Apex TV/DVD 757 Broksonic TV/DVD 752 Konka TV/DVD 753 Panasonic TV/DVD 734, 765 RCA TV/DVD 749 Sansui TV/DVD 754 Sylvania TV/DVD 764 Toshiba TV/DVD 750 Go Video DVD/VCR 692, 693 JVC DVD/VCR 689 RCA DVD/VCR 690 Samsung DVD/VCR 738, 667, 691 Sony DVD/VCR 768
on Jun 06, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Need Comcast DTA remote to control Panasonic TV/VCR combo
Try website 1-800-Remotes Factory original.To buy an exact remote or very close to the original.
Apr 25, 2010 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
I accidently changed the channel that I receive satalite tv on, dishnetwork can't solve the problem. TV will not take more than one number & dish tells me the channel should be 60 or 73 help
Is this a tv2 off of the primary reciver from another room?
If so there is a 2 step process to help you fox this.
Generally yes it is 60 or 73 but some installers do change it.
If it is on 60 The it will be on 60 AIR not 60 CABLE , if it is on 73 then is will be on 73 CABLE not 73 AIR..
To simplify this for you go into your tv's menu and select your air/cable type to air and have the tv do a channel scan. once complete use your remote and go up and down the channels in air mode it may find more than one. check and see if any of them are your dish box. If not then go back into the tv menu and select your air/cable setting to cable and repeat a channel scan. again once complete use the tv remote to go up and down channels untill you locate your dish box. If you do both of these and still do not have your signal verify that there is no VCR or DVD player "ON" at that location. They can be hooked up, just not on. Also some tv's have an antenna A and antenna B on the back of them , if your does make sure you test with both antenna connections. If you go thru all of this and still cannot get a signal then a line may have gotten cut or dissconnected and they need to send a tech out.
Sep 24, 2009 | Akai 20" TV
I have dish tv need codes to broksonic model# CTSGT-9369CTTC TV ? SO THAT MY ON/OFF AND VOLUME WILL WORK???
can someone tell me what the pass code is for a Broksonic 19in TV/VCR COMBO model no. ctsgt-9369ctt
Jun 09, 2009 | Broksonic CTSGT9369CTT 19 in. TV/VCR Combo
Can't view tapes on vcr
I assume that you are coming in on channel 73 because you don't have a line level input on the display (tv) you are using. If that is the case, your options are limited. If you DO have a line input to the monitor, run the VCR to that input and just switch to that input when you want to use the VCR. If you have RF in only, -that would be the screw on type connector- you would have to have the same kind of output on the VCR. Understand, the VCR will be outputting to channel 3 or 4, so you would need a 2x rf switch, and you would have to change from channel 73 to 3 or 4 whenever you wanted to watch a movie. There may be other options, but I don't really know what you have.
Dec 04, 2008 | Sanyo VWM-950 VHS VCR
Had dish network update - can't view vcr tapes
the output of the vcr...
what is it physically wired to?
Remote control codes
Jan 22, 2008 | Broksonic CTSGT8118T 13 in. TV/VCR Combo
Televison & Video Logo
286 people viewed this question
Top Broksonic Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Broksonic Televison and Video Expert? Answer questions, earn points and help others
