Question about Onkyo Audio Players & Recorders
What is the "code" for Onkyo HT-R591 Receiver (for Direct TV remote programming)
nenalex2002
  • 134 Answers
SOURCE: remote control codes
Here is a link for the complete manual :
http://www.us.onkyo.com/download/own_manuals.cfm?cat=Receiver
remote codes start page 61
To control an Onkyo receiver with a universal remote try code 0135
Hope this helps
Alex
www.CustomAutomaticSystems.com
Posted on Nov 11, 2007
Sparky-UK
  • 129 Answers
SOURCE: One for all universal remote model URC-3220 Attempting to program direct Tv receiver to remote. Need Receiver code number
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 30, 2007
SOURCE: remote controller codes
Go to Onkyo's website http://www.onkyousa.com/. rest the cursor over the support button at the top of the page. Adrop down menu will appear. Select owner's manuals. Select receivers on the new page. Select the manual for your model (HT-R530). It is a PDF file. At the bottom of the manual will be a section about the remote with the codes.
Cheers
Posted on May 06, 2008
SOURCE: Unable to configure SAMSUNG 3241D TV with ONKYO remote (RC-608M)
Check out
http://akamaipix.crutchfield.com/Manuals/580/580HTS780B.PDF
Posted on Jun 07, 2008
  • 3 Answers
SOURCE: Onkyo - direct tv code for tx-ds 787
does anyone knows the code to control the onkyo TXDS 787 through the comcast.remote.?
Posted on Aug 21, 2008
Onkyo Codes for Samsung remotes?
Hi, unfortunately this remote does not have the ability to program to your Onkyo receiver. You must use your original Onkyo remote to control the volume of it. If you need a new Onkyo remote you can purchase one from Replacement Remotes. You can also buy a universal remote to program and work for both your units, so you will not have to keep switching back in forth between remotes. If you would like a universal I suggest getting the RFS200, this remote will even work if your receiver is not in direct line of site.
Sep 02, 2012 | Samsung BN59-00852A Remote Control
I have tried all DirecTV codes on my Onkyo HT-RC270 remote control and none of them work. Please help!
If you still have the direct tv remote you can make the onkyo learn the codes from the direct tv remote via the Learning mode on the Onkyo Remote.Consult the onkyo remote user manual on how to do this step by step.This applies to remotes that have the learning feature,not all remotes have this feature,consult the manual to see if your remote has this feature.Good Luck
Feb 12, 2011 | Onkyo Tx-sr507 A/V Receiver
Onkyo HT-S6100. Receiver says NO SIGNAL and so
I have the same exact unit and same exact problem. Any luck yet?
Oct 16, 2009 | Onkyo Audio Players & Recorders
Jun 14, 2008 | Onkyo TX-DS787 Receiver
Comcast remote/Onkyo AV Receiver
I have this exact same problem. Anyone know how to fix this?
Dec 22, 2007 | RCA 20F510TD 20 in. TV/DVD Combo
CORRECT SETUP CODE FOR RECEIVER
Originally Posted by 3FingeredGlove viewpost.gif We can make this work. You didn't mention which setup code you're using, or explicitly say whether the OK/Select button is red or gray (the manual you're using is for gray), so these are somewhat generic instructions. Should work, though. This will provide a power toggle function to the Power key.
Use red numbers for the red OK/Select button remote, grey numbers for grey button remtoes.
Temporarily assign setup code 30842 or 0842 to AUX
1) Tap AUX
2) Press Setup until 2 blinks
3) Enter 30842 or 0842The remote should blink twice
Assign NEC1 IR protocol device 210, subdevice 108, function number 203 to Power (you don't need to understand these numbers)
1) Press Setup until 2 blinks
2) Enter 994 (2 blinks)
3) Tap Setup
4) Enter 00051
5) Tap Power (not All On)
Assign setup code 30135 or 0135 to AUX (this is NEC1, 210.109)
1) Tap AUX
3) Enter 30135 or 0135
Nov 15, 2007 | Onkyo HT-SR800 System
Remote control codes
Hope this helps
Alex
Nov 11, 2007 | Onkyo HT-S780 System
that is because i think that your reciever would have its own code
Jan 29, 2007 | Onkyo HT-S790S System
207 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
