Question about Motorola Mobility RAZR V3
Logo stays on outside display window of cell phone
I have a Motorola RAZR V3. Whenever you open or close the phone the Motorola logo stays on the outside display windown of the phone. No longer does the time show up. I have taken the battery and the sim chip out and re-seated them. I have also done a Master Reset on the phone. Not sure of anything else to do.
I'm having the same trouble, and I've found it's because the v3 no longer recognizes the opening and closing of the phone itself. You see, when you close it, something is triggered that tells the phone to shut off the main screen and change the outer screen to the usual mode where it shows the time. You can also test this by trying to take a picture and closing the phone - the external lcd no longer doubles as a second camera display to easily take pictures of yourself. I dropped mine into the toilet, and I'm not sure if there's anything to do but take it to a tech. Sounds and looks like a hardware problem to me.
Posted on Jul 01, 2007
When you flip phone open inside screen stays white
Moto RAZR phones are notorious for this. Best thing to do - Get a new phone. Inside of the hinge, there is a sensor that detects if the phone is open or shut. When you open the phone, it still thinks its closed, so the screen stays white, and if im correct the outside display should still work. Pretty much not-fixable unless you know someone who can take it apart and re-position the sensor (will void the warranty)
Best thing to do....Upgrade.
Nov 26, 2009 | Motorola Mobility RAZR V3
I have a Moterolla V3,my LCD screen is not displaying correctly, I see white and red, but I can't make out anything else. When the phone initially turns on the screen displays the Verizon perfect...then it...
The flex that connects your screen to the phone board is bad and has worn out. It is commom with flip phones. All you need do is to replace the flex and be very mindful of how you close the flip phone.
Take care.
Nov 16, 2009 | Motorola Mobility RAZR V3
Display
I suggest you do an easy reset by doing the following:
GO TO
settings>initial setup>master reset master clear
May 30, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Motorola Razor V3 Lime Green
this is a very simple problem to fix just take it to a mobile service center and have them correct the issue for you.
Mar 06, 2008 | Motorola Mobility RAZR V3
V3 Motorola Razr won't load past Sprint Welcome screen
check software it must be 24-2-00-43r if not this mean it needs software
Jan 31, 2008 | Motorola Mobility RAZR V3
External display
you can try and do a master reset and master clear that should fix the issue.
Jan 08, 2008 | Motorola Mobility RAZR V3
RAZR V3M thinks it's always open - Screen will not turn off
in the top right corner you are suppose to have a little circular magnet that changes the screen when the phone is open or closed. I just changed my housing yesterday and took the magnet out and put it in my new housing but for some reason i have the same problem as you. so maybe you lost the magnet when you replaced the lcd and if that is the case then you are screwed. try have Motorola fix it, don't tell them you replaced the lcd
Dec 04, 2007 | Motorola Mobility RAZR V3m Cellular Phone
Razor phone external display
I had the same problem. I sent it back to Motorola for warranty. They fixed it and said it was a connection issue.The connection between the screen and the keys came unplugged. This is a regular problem they have with this phone. The phone is poor quality!!!!
Nov 21, 2007 | Motorola Mobility RAZR V3
Outside display screen will not show anything but the motorolla logo
Does anything show on the external display if you go to take a picture, but before you acually take it, close the phone and look on the external display as if you were taking a self-portrait?
To make fully sure, while the phone is closed, press a volume button - does anything show on the display? If so, the external display functions and it would be a setting that may have been overlooked.
Go to Menu > Settings > Initial Setup > Display Timeout
or:
Menu > Settings > Personalise > Home Screen
Nov 01, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
174 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
