Question about Brookstone Stunt Copter RC Helicopter
Stunt copter won't sync and red loght continues flashing
Red light in helo is flashing all the time. RC beeps for some seconds and stop Helo does not respond to the RC
Wireing guide for a brookstone stunt copter
If under Warranty (Brookstone or Extended) have them replace it. If not, suggest a Hobby Shop that specializes in R/C Helis
Apr 17, 2013 | Brookstone Stunt Copter RC Helicopter
I want a manual for my stunt copter for the 4ch/2.4G
Just added it to this site. Should be up in 24 hours or so. Otherwise, go here: http://www.brookstone.com/webassets/pdf/796083p_manual.pdf
Dec 30, 2012 | Brookstone Stunt Copter RC Helicopter
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Dec 26, 2012 | Brookstone Stunt Copter RC Helicopter
My Havoc Heli won't charge
http://www.buynicer.com/SWIFT6020--1-New-3--Channel-RC-Helicopter-w-Infrared-Remote-Control_pid8096.html
Aug 12, 2012 | Spinmaster Air Hogs Red Defender Remote...
Rc helicopter not getting signal from remote
I think you have damaged the copters electronics when you crashed it.
Jun 27, 2017 | Toys
When I power on the tv, the light goes to green and then a few seconds later goes to a red flashing light
When a set is powered up, there are internal checks that are performed. The initial green light indicates that power has been applied. The flashing red light indicates that a problem was found that is preventing the set from functioning properly and it has shutdown to prevent further damaeg. If you can supply the model number, I may be able to provide additional details. Also, check to see if the flashing red light has a pattern. Quite often the pattern will indicate what problem was detected.
Thanks,
Dan
Aug 07, 2009 | Panasonic Televison & Video
Brookstone Stunt Copter RC Helicopter Logo
61 people viewed this question
Top Brookstone Electronics - Others Experts
Are you a Brookstone Electronics - Other Expert? Answer questions, earn points and help others
